Kolink Continuum KL-C1500PL can anyone identify this device BC729/8C729?
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys can anyone identify this please
    It's in a 1500W ATX PSU
    Marking looks like BC729 or 8C729 but the B or 8 is a funny symbol with the top ha1lf smaller than the bottom half
    I suspect it is a voltage regulator
    The centre pin/tab goes to ground
    The right pin goes to a CM6902 PWM chip VCC pin and only has 0.5V
    The left pin has 0V but I think it should go to a 16V rail on the 5V STB
    transformer but the PCB is too densely populated to see how it would get there on the other side.
    On this side it only goes to two capacitors in parallel, the other end of the caps goes to ground. These look like they are input caps to me
    best regards
    Richard
    Follow me on YouTube
    Learn Electronics Repair
    • 20781
    Re: can anyone identify this device BC729/8C729?
    It looks more like an A or underlined A to me,but it could be the makers symbol
      • 20781
      Pin 2 counting from the bottom left goes to pin 10 of the 16 pin IC below it. Post the part number of that 16 pin IC, if there`s a datasheet available with a typical application circuit,it might help to ID that part
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        Re: Kolink Continuum KL-C1500PL can anyone identify this device BC729/8C729?
        The PSU is Kolink Continuum 1500W Fully Modular 80 Plus Platinum
        The 16 pin chip is CM6901T (typo in OP) Pin 10 is ground
        https://pdf1.alldatasheet.com/datash...MP/CM6901.html
        The possible output from the regulator goes to pin 15 (Vcc) on the CM6901T
        The middle pin (pin 2) is ground
        The left hand pin which I only see connects to two capacitors (input?) has 0V - and the other side of the caps is ground
        Vcc on CM601T on 15 is 0.5V - it should be 10V-20V according to datasheet
        The 5VSTB generates another rail 16.9V which is present
        I think the mystery component is a 12V fixed regulator and there is a bad via or damage on the other side of the PCB that I can't see which is beraking the connection from input of BC729 to 16V - which also goes two two vias to the component side (visible)
        The PCB is too densely populated to check without removing a lot of components - if it is confirmed input pin on a 12V regulator I will bridge a wire to 16V rail.
        • dicky96
          Sun Seeker
          • Mar 2017
          • 1825
          • Spain
          This is what I know and what I am thinking...
          See pic
          I showed 5V STB on the ground end of the capacitors, it is of course on the other end
            • 20781
            Cm6901 datasheets http://www.champion-micro.com/product-en/CM6901.htm
            • dicky96
              Sun Seeker
              • Mar 2017
              • 1825
              • Spain
              I posted the datasheet
              Post #4
              I would just like to confirm my suspicion BC729 is a fixed 12V regulator
              I suppose I could unsolder it and test it if no one knows
              • dicky96
                Sun Seeker
                • Mar 2017
                • 1825
                • Spain
                Hmm seems an obscure part number if no one knows.
                I'm thinking now to inject 17V on the supposed input, set my bench PSU to a few hundred milliamps and see what happens. If I then get 12V or similar on the CM6901 Vcc then I can solder the wire from 16.9V
                I could do this either with the mains supply to the ATX PSU off, or with it on using a light bulb limiter and see if the main rails power up
                But if someone can identify the BC729 device all the better and a bit less risky
                thanks
                • lotas
                  • Jan 2016
                  • 4585
                  • Russia
                  8C729 (8Cxxx) - L78L05ABUTR
                  • R_J
                    • 9535
                    lotas beat me to it, but I agree 8C729, and the 8C being a +5 volt regulator, 729 date/mfg code
                    • PeteS in CA
                      • Aug 2005
                      • 3579
                      • USA, Unsure of Planet
                      Or perhaps a SMT version of the 2SC729, an NPN transistor? Omitting the "2S" from transistor markings is common practice.
                      PeteS in CA
                      • dicky96
                        Sun Seeker
                        • Mar 2017
                        • 1825
                        • Spain
                        Ahh now that makes this more interesting but doesn't really make any sense
                        A: If 8C729 is a 7805 equivalent, the output on pin 3 (assumedly 5V) is not enough for Vcc of the CM6901 which needs 10-20V and it connects directly to there (pin 15 CM6901). Doesn't appear to be correct
                        B: If it is a 2SC729 then it needs some base voltage to supply 10V-20V to pin 15 CM6901, acting as an emitter follower but this does not make sense as the TAB (collector?) is connected directly to ground
                        I think now back to an earlier plan I need to put some voltage on pin 1 from my bench PSU with current limit 100mA-200mA just a guess of something reasonable and see if 12V approx appears on pin 3 (output)
                        • lotas
                          • Jan 2016
                          • 4585
                          • Russia
                          best regards
                          Richard
                          The "8Cxxx" has a different pinout, the input voltage is supplied to the right pin, and the output voltage of 5 volts comes out from the left pin.
                          Look for where the voltage comes from, which is applied to the right pin.
                          • dicky96
                            Sun Seeker
                            • Mar 2017
                            • 1825
                            • Spain
                            Thanks for that info. It suggests that I should put about 12V on Vcc of the CM6902 (as I know this should be 10V-20V from the datasheet) then the 8C729 regulator will generate 5V output for whatever.
                            Two things for sure, the PSU can not power up unless the PWM is running, and PWM Vcc can only come from the 16V output on the 5V Standby PSU one way or another
                            • thesame
                              DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                              by thesame
                              Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                              The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                              02-27-2024, 04:31 AM
                            • silver60618
                              Lenovo Legion 7 - Help Identify IC
                              by silver60618
                              Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                              I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                              Any help would be appreciated...
                              07-02-2025, 12:16 PM
                            • chth96
                              How can I identify varistor which have been blew up?
                              by chth96
                              I mistakely pluged 100v japanese retro game console to 220v outlet.
                              So It seems that glass fuse and varistor have been blew up.
                              I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                              Is there any way to identify varistor type in my sega saturn PSU?
                              Any reply would be appreciated.
                              EDIT:
                              It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                              11-26-2023, 08:52 AM
                            • freakorio
                              Need Help To Identify Component on Ymain LJ41-05120A
                              by freakorio
                              Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
                              05-21-2024, 02:32 AM
                            • baiceanu_stefan
                              nm-f251 Schematic, boardview or help identify componente
                              by baiceanu_stefan
                              Hello, I have a legion pro 5 16arx8 serial number pf4bf4aw mb code nm-f251 rev1.0 which was dissasembled by the client for cleaning. Now it does start but for 20 secs after that fans run at maximum and then shut down. Found PU8302 burned but cannot identify it the part. It is written eHFAA on it but didn't found any info, no boardview, nothing. Can anyone help identify the part so I can order it from somwhere? Ataching some pictures of the motherboard, serial number and part. Than\k you...
                              04-24-2024, 12:49 AM
