Newbie here. Have repaired various LCD's recently - never a power supply. Picked up a used Antec Aria case - but has a bad AR300 power supply. Upon inspection I noticed a bulging cap - and the component next to it unsoldered, obviously it got hot. Did the bad cap cause this or vice versa? What is the other component? The other caps look fine - from what I can see - they are all teapos. This is an odd shaped PSU or would just replace. Thanks!
Antec Power Supply
Tags: None
Re: Antec Power Supply
No, it's a zener diode. Marking on the board is ZD4.
There are other threads in here about these PSU's:
https://www.badcaps.net/forum/showthread.php?t=6646
https://www.badcaps.net/forum/showthread.php?t=7169
These are limited to Antec for supply due to the oddball casing. These people still show stock (51) even though it's the AR350 model (check the case size):
http://www.provantage.com/antec-ar350~7ANT900Q.htm
I'd replace the cap and put the diode back in place and test the unit. If it comes on and voltages are (near) correct, recap the entire unit. If not, get the new one and recap it.
Toastveritas odium paritComment
Thanks Toast - have a cap coming. I had read one of the threads, not the other. If it works will recap - hate to buy new.
TRComment
An overall photo of the board from the top and bottom might help trace the real cause of that zener getting cooked. I have a thread in this forum where, among other things, i had a burnt zener close to the 5VSB transformer, in an Antec SP500P.Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - ShenanigansComment
Thanks all for the replies. Received the cap and got a chance to install this morning. After installation plugged it in - with a load - got a familiar high pitch whine - which is better than before. Have heard this before on other PS's - what is the cause - I always figured it was the big cap. Got photos of both sides of the board prior to installing the cap and diode. ThanksComment
Did you replace the toasted zener diode yet? I'd be interested to see if it makes any impact on reducing the whine.
I have a re-capped Jeantech PSU with a failed zener that whines, another working one of the same model does not whine.Comment
You need to replace the zener diode ZD4 1N4746A 18v 1.3W. Replace EC4, 100uf 50v, EC3, 22uf 50v and on the print side of the board R29 may be burnt, it is a 6.5R SM resistor connected to the primary side of the 5VSB transformer. Make sure when you replace the 18v zener you leave about 2mm clearance to the board surface and meter the diode after replacement. You should get 400 to 700mv fwd on a diode tester. If you get similar both ways the board is carbonised and is conducting! Push the diode down towards the board very gently to break the bond between the copper print and the board on the side that is most burnt and refix with a small gap using super glue. I know this sounds very "heath robinson" but it works. When the glue is dry, re meter the diode and it should be fine. Check all the secondary caps for bad ESR or bulges and replace. Then test the PSU, all should be good.
Good Luck, SteveComment
Is that a TFX form factor?
If so Enhance made some good ones with all Jap caps.
.Last edited by PCBONEZ; 12-14-2010, 07:20 AM.Mann-Made Global Warming.
- Dr Seuss
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
by Gust zhangI have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
- Loading...
