Antec Power Supply
  • trwilson70
    • Mar 2010
    • 69
    Antec Power Supply
    Newbie here. Have repaired various LCD's recently - never a power supply. Picked up a used Antec Aria case - but has a bad AR300 power supply. Upon inspection I noticed a bulging cap - and the component next to it unsoldered, obviously it got hot. Did the bad cap cause this or vice versa? What is the other component? The other caps look fine - from what I can see - they are all teapos. This is an odd shaped PSU or would just replace. Thanks!
  • mockingbird
    • Dec 2008
    • 5484
    Re: Antec Power Supply
    Is that a picofuse?
    • Toasty
      • Jul 2007
      • 4171
      No, it's a zener diode. Marking on the board is ZD4.
      There are other threads in here about these PSU's:
      https://www.badcaps.net/forum/showthread.php?t=6646
      https://www.badcaps.net/forum/showthread.php?t=7169
      These are limited to Antec for supply due to the oddball casing. These people still show stock (51) even though it's the AR350 model (check the case size):
      http://www.provantage.com/antec-ar350~7ANT900Q.htm
      I'd replace the cap and put the diode back in place and test the unit. If it comes on and voltages are (near) correct, recap the entire unit. If not, get the new one and recap it.
      Toast
      veritas odium parit
      • trwilson70
        • Mar 2010
        • 69
        Thanks Toast - have a cap coming. I had read one of the threads, not the other. If it works will recap - hate to buy new.
        TR
        • Khron
          • Sep 2006
          • 1350
          • Finland
          An overall photo of the board from the top and bottom might help trace the real cause of that zener getting cooked. I have a thread in this forum where, among other things, i had a burnt zener close to the 5VSB transformer, in an Antec SP500P.
          Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
          • trwilson70
            • Mar 2010
            • 69
            Thanks all for the replies. Received the cap and got a chance to install this morning. After installation plugged it in - with a load - got a familiar high pitch whine - which is better than before. Have heard this before on other PS's - what is the cause - I always figured it was the big cap. Got photos of both sides of the board prior to installing the cap and diode. Thanks
            • seanc
              • Nov 2008
              • 1319
              Did you replace the toasted zener diode yet? I'd be interested to see if it makes any impact on reducing the whine.
              I have a re-capped Jeantech PSU with a failed zener that whines, another working one of the same model does not whine.
              • Marstee
                • 3
                You need to replace the zener diode ZD4 1N4746A 18v 1.3W. Replace EC4, 100uf 50v, EC3, 22uf 50v and on the print side of the board R29 may be burnt, it is a 6.5R SM resistor connected to the primary side of the 5VSB transformer. Make sure when you replace the 18v zener you leave about 2mm clearance to the board surface and meter the diode after replacement. You should get 400 to 700mv fwd on a diode tester. If you get similar both ways the board is carbonised and is conducting! Push the diode down towards the board very gently to break the bond between the copper print and the board on the side that is most burnt and refix with a small gap using super glue. I know this sounds very "heath robinson" but it works. When the glue is dry, re meter the diode and it should be fine. Check all the secondary caps for bad ESR or bulges and replace. Then test the PSU, all should be good.
                Good Luck, Steve
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Is that a TFX form factor?
                  If so Enhance made some good ones with all Jap caps.
                  Mann-Made Global Warming.
                  - Dr Seuss
                  • Marstee
                    • 3
                    Correction! The surface mount resistor R29 value is 5.6R, my apologies for the typo.
                    Steve
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                      by sam_sam_sam
                      07-01-2024, 06:34 AM
                    • JimBanville
                      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                      by JimBanville
                      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                      Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                      I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                      09-13-2023, 07:21 AM
                    • CMCM
                      Russound CA4 Power Supply Repair
                      by CMCM
                      Hello Everybody,
                      Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                      Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                      The outputs marked 12v and 20v are all measuring only 1v.
                      The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                      The capacitors physically look clean (no bludgesor leaks) and...
                      07-03-2025, 01:12 PM
