(ASK) what mod should be do in this psu ?
  • ibet
    n00b
    • Mar 2010
    • 8
    my first post
    Power Logic Magnum 300w
    Max DC Output :
    +3,3v = 14A
    +5V = 28A
    +12v = 18A
    -5V = 0,5A
    -12V = 0,8A
    5Vsb = 2A
    P/G = OK
    i've got this gutless wonder for about 1 years and this psu starts to acting weird .
    the 12+v rails drop heavily even at idle condition,
    idle @ 11,76v load @ 11,56v and this makes me stressed out .
    the spec of the computer :
    Intel Pentium D 925 @ stock
    Asus P5GC-MX
    2x 512Mb PC5300 Hynix
    onboard VGA's
    1 ODD, 1 HDD
    1 Datech 92mm 2A fans
    this is the pic inside the psu :
    overall look inside PSU units
    diodes ? well i don't know what is this ..
    the transformers
    primary side, unknown brand of caps, 4 diodes theraphy, and off course,
    empty side of input filtering .
    secondary side of PSU, fulltec caps at the output points
    what mod i can do to this units ?
    what size that will good enough to fit this units ?
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: (ASK) what mod should be do in this psu ?
    This power supply looks to have an ok design, just uses parts that are a bit small. Heatsinks are ok sized, transformer is a 33 size, 4 baby diodes on the input.
    I would start with a recap. Then move up to a transient filter. Then, replace 4 diodes on input with bridge rectifier. If you really want to get extreme, replace some secondary schottky diodes with larger capacity ones.
    • ibet
      n00b
      • Mar 2010
      • 8
      thanks for the reply
      okay then, i can do recap my self ..
      but i don't understand the mod of transient filter ( the component, size of the component ) and the bridge rectifier too ..
      what component should i do for the transient filter and bridge rectifier part ?
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        Do you have any old psu's laying around you could gut for parts? That would be the best place to get parts for things like transient filters or bridge rectifiers. (though I don't recommend taking apart good psu's just to fix up a bad one, one that dosen't work or a old AT power supply might work)
        Things like X caps, Y caps, and bridge rectifiers can be bought pretty easily and cheaply (don't know about the availability where you live,) but line filters are a little harder to find cheaply. My stash of them are all salvaged from psu's.
        This is a bridge rectifier:
        I labeled which legs are which. To replace the diodes with the bridge rectifier, quite simply remove all 4 diodes. The positive leg of the bridge rectifier goes in any hole that connects to the positive leg of the primary caps, the negative leg goes in any hole that connects to the negative leg of the primary caps, and the AC legs go in the holes that are live and neutral coming from the transient filter.
        That I how I *think* it would connect with your power supply. A underside shot would clear it up.
        • ibet
          n00b
          • Mar 2010
          • 8
          okay, just changed the four diodes to one PBU 805 bridge rectifier ( 8A @ 600V ) .
          now the line filter part which i still don't understand at all ..
          does it have specification ? and what recommended part for a 300-400w unit for the line filter part ?
          and one more thing ..
          what caps did u recommend for the recapping part ?
          i can't find any japanese caps here in my town ..
          gotta go to Jakarta to buy the caps ( and also the line filter )
          • japlytic
            • Oct 2005
            • 2086
            Several corners have been cut in this power supply, especially having no EMI/RFI filtering.
            • ibet
              n00b
              • Mar 2010
              • 8
              @japlytic
              what does that mean ?
              i don't understand ..
              • etnietering
                • Apr 2009
                • 379
                EMI = ElectroMagnetic Interference
                RFI = Radio Frequency Interference
                Switching power supplies operate and many KHz, and if they're just hooked directly into the mains, they can feed this many KHz signal back into the 50/60Hz mains. Which can cause other devices (especially AM radios) to not work properly. An EMI/RFI filter filters out this noise, making sure it doesn't escape back to the mains. Also, it keeps interference that other devices may be creating from interfering with the operation of the power supply.
                If I remember correctly (I looked it up once), this is how it works:
                X caps - usually film caps, connected across Hot and Neutral, filter out common mode noise. Must be rated X1/X2
                Y caps - usually ceramic, although sometimes film caps, connected between Hot and Ground (Earth), and Neutral and Ground (Earth), filter out differential mode noise. Must be rated Y1/Y2/Y3
                Filter coils - coils with 2 windings, wound in such a way that they filter out both common and differential mode noise. You must be careful installing them, otherwise you could hook Hot directly to Neutral and blow a fuse or circuit breaker or start a fire.
                The X and Y caps are not polarized, but like I said you have to watch the filter coils. And be sure to remove the lame jumper wire, otherwise they won't do any good Good luck!
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  not to offend but the powersupply is not worth fixing IMHO. the tiny heatsinks, thin wire, counterfeit tranformer (that is so not a 35, maybe a 25), and small amount of secondary filtering make it nearly unfixable. the rest would be fixable... but it would not do much without fixing the rest... so find yourself a better psu. what kind of system do you run? if newer, then hypermicro.com has a nice 550w acbel for only $20! only catch is it has 8pin 12v, not 4 pin (you could splice in a 4 pin). if you run something needing an older 20 pin (not 20+4), check ebay for a good delta, hipro, enlight, etc.
                  gutless wonders never work in the end...
                  sigpic
                  (Insert witty quote here)
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    sorry, hypermicro won't work for you, forgot you were in indonesia.
                    also i misjudged the heatsinks, a tad small but ok. the transformer also was misjudged. my bad. the wire is still thin, might want to remove the crap and solder in some thicker wires.
                    sigpic
                    • ibet
                      n00b
                      • Mar 2010
                      • 8
                      i decided not to upgrade this old junker ..
                      maybe i should search another good one ..
                      have you heard Enhance 250w ?
                      got this for free from my friend ..
                      and it does small board, different i think .
                      i'll take some photos later ..
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        You should still keep that PSU, though. It's actually not that bad at all. If you know of any TV repair shops around you, ask them if they have any TV/monitor boards that they don't need or want to get rid of. Those will usually have the components (X caps, Y caps, coils, etc.) needed to complete the input filtering of the PSU.
                        Old AT power supplies can be used for parts too, as 370forlife suggested.
                        If I remember correctly, they were a good brand. Your pictures will tell everything, though.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          enhance is a good one. much better than the POS you started this thread with.
                          some pics would be nice, though.
                          sigpic
                          • paul_h
                            • Oct 2007
                            • 86
                            What's the benefit of a bridge rectifier over 4 diodes?
                            I know if you had a large rectifier you could mount it to a heatsink, but what else?
                            Inverter air cons have a bridge rectifier and it's one of the most common things to fail in their circuitry.
                            edit: Also why do the primary caps vary so much, nearly every PSU I've bought in the last few years have had 1000uF, 1200uF and 1500uF primaries, while nearly all the old (and cheaper) PSUs in my junk pile have ~400uF caps like that one.
                              • 31015
                              the rectifier will handle more current,
                              and bigger caps can absorb more crap on the mains before it effects the psu.
                              • ibet
                                n00b
                                • Mar 2010
                                • 8
                                sorry for the late response ..
                                i had school exams last week .
                                this is the photo(s) of the free Enhance 250w
                                • 370forlife
                                  Large Marge
                                  • Aug 2008
                                  • 3112
                                  Looks like you don't need to do anything to it. That thing is pretty crammed.
                                  • ibet
                                    n00b
                                    • Mar 2010
                                    • 8
                                    i think the same, PCB is full of component, just put better fans into it and it works pretty well with quadcore + IGP + 1HDD + 1ODD + 2 stick of ram ..
                                    • caspian
                                      What Zener Diodes on a Linear Power Supply
                                      by caspian
                                      Dear members,
                                      I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                      Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                      In addition, I discovered that its zener diodes are defective.
                                      I can replace the burned transistors.
                                      But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                      Therefore, I cannot replace the zener diodes.
                                      I do not want to test the zener diodes in a test circuit to discover their model or value.
                                      no schematics are available...
                                      05-26-2025, 12:38 PM
                                    • Fontana
                                      BN44-00505A dead. Need to know voltages on output diodes (Samsung T22B300EW)
                                      by Fontana
                                      1. g´day! I have a samsung 22" tv monitor to fix. power supply model bn44-00505A. some stuff blown up on the primary, according to research something typical on this model. secondary seems ok. writings on the board say in outputs a5v (standby), b5v (switched) both on the lower 3 diodes on the picture, vamp and b13v (12.8v, both are the linked at the connector that goes to the main board) my question is, are both the upper diodes for 13v? I believe so but wanted to make sure before injecting voltage there to test. I injected 5v on the lower side and standby circuit is working fine
                                      2. if
                                      12-18-2023, 05:45 AM
                                    • Nikolai Danylchyk
                                      Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
                                      by Nikolai Danylchyk
                                      Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
                                      Thanks in advance!...
                                      05-08-2025, 06:18 AM
                                    • DjKrish
                                      Zener diodes component equivalents
                                      by DjKrish
                                      Hey guys, i have a sony home theater power supply thats a few smd zener diodes blown but its so hard to get them. any recommendation for me to use normal zener diodes?
                                      1. UDZSTE-1710B (9.99V 5mA) (SC-90, SOD-323F)
                                      2. UDZSTE-1724B (24V 200mW) (SC-90, SOD-323F)
                                      3. UDZSTE-175.1B (5.1 V 200 mW) (SC-90, SOD-323F)
                                      These are the diodes. If i use normal zener diodes, it will work right? Question is, can i get these values on normal zener diodes?
                                      08-15-2021, 11:06 PM
                                    • madyoyo
                                      Samsung QE55Q65B with shorted D001 diodes on panel board: Worth saving or not
                                      by madyoyo
                                      Hi
                                      I have a Samsung QE55Q65B with a seemingly common problem: it turn off and back on after a few seconds, (sometimes more, and in rare instances works for hours). D001 on the left side of the panel is very hot. I may be able to remove it with a very fine iron, but i don't have the equipment to re-solder such small parts.
                                      Is there a risk to run the tv without this diodes diodes? And is it worth to pay someone else to replace it. I read many people who ended up with bad lines after trying to remove/replace them, , or the panel failing in another way, so i want to weight...
                                      12-01-2023, 09:28 AM
