Antec true550 ESp12V Recap - need help with replacement caps (have all info needed)
  • emplosion69
    • Jun 2008
    Hello All,
    been doing some de-soldering and getting info off all the caps inside the recap subject - Antec True550 ESP12V
    so here is all the #'s off all the caps I could get too..
    there was 1 that was a tiny little dood that was down below the 3 coil area that I said forget it on..
    Antec True 550 ESP12V
    http://www.antec.com/specs/true550EPS12V_spe.html
    Quantity---------Uf------Volts
    2-----------1200------200<---big ones as you know
    4-----------3300------16 TMR
    2-----------2200------10 TMR
    1-----------470-------16 TNR
    2-----------1000------10 TNR
    1-----------220-------16 TNR
    1-----------100-------16 TNR
    1-----------47--------50 TNR
    1-----------10--------50 TNR
    1-----------1---------50 TNR
    1-----------22--------50 TNR
    The PSU is in great condition as I have had it since 2004-ish new
    but the bad cap did plague it a few years back, well I scoured around and found some (temp) replacement caps to find if it was worth re-capping...so here I am
    Need to know what caps are the best for this job as I have not a clue what all the esr values and stuff are/do..
    I can solder and all but the knowledge of the specs on caps are beyond me..
    Rubycon is the best right?? If so then thats the way to go, if there is better for the purpose of the PSU and heat, etc..whatever will get the job done and get this PSU back to maximum potential
    Thanks for the great forum, if it wasnt for baccpas.net I would have thrown the Antec to scrape pile..
  • c_hegge
    • Sep 2009
    • 5219
    Re: Antec true550 ESp12V Recap - need help with replacement caps (have all info needed)
    I usually use Panasonic FC in PSUs, although they are a bit bigger physically and you may have trouble fitting them in. Nichicon HE, Chemi-con KZE and KY, Rubycon YXF and WXA would probably be fine as well, although all will probably be bigger than the Fuhjyyu originals.
    • emplosion69
      • Jun 2008
      Thanks for the reply
      So the Fuhjyyu originals are the only size that fits as manufactured..hmm well looks like a fit mod re-cap then lol..
      none the less its worth it as I have been testing all the volts across my board tonight,
      I have one molex connection that is for fan only x 2 that gives only 4.76.
      ok after a quick search I found this ..
      Panasonic FC..
      and right after that is this..are these better for this ??
      Steve
      • 370forlife
        Large Marge
        • Aug 2008
        • 3113
        https://www.badcaps.net/store/produc...products_id=56
        Samxon RS series, 16v, 3300uf 10mm caps. They are perfect for psu's because their ESR isn't too low (having too low of ESR in a psu can actually cause more ripple)
        https://www.badcaps.net/store/produc...products_id=57
        Second verse, same as the first but these are 10v caps, you can replace the 2200uf's with 3300uf's as long as there is room height wise. Only problem is topcat is all out of them.
        • emplosion69
          • Jun 2008
          Just my luck and I was thinking I could order these today, if not I'll have to wait until next week, work etc..
          Checking out Digikey is like W0W..has a butt crack load of everything to figure in to get what you want, didnt know that these little legged cans could be so many choices of them.
          EDIT:. as I look at the Panasonic, I seen the M in the box on them as that is what is on the 200V 1200uf main in (I guess that is the mains)
          CAP 3300UF 16V ELECT FC RADIAL Panasonic I see how the size is bigger I'll deal with that after I get these
          http://search.digikey.com/scripts/Dk...name=P10260-ND
          CAP 2200UF 10V ELECT FC RADIAL
          http://search.digikey.com/scripts/Dk...name=P11189-ND
          • emplosion69
            • Jun 2008
            And here is the rest, I hope these are all good to go for this re-cap, I need to order some other resistors and "pots" also so I'll just do it there too..make a bulk order out of it get the most of my few bux
            CAP 470UF 16V ELECT FC RADIAL
            http://search.digikey.com/scripts/Dk...name=P10247-ND
            CAP 1000UF 10V ELECT FC RADIAL
            http://search.digikey.com/scripts/Dk...name=P10224-ND
            CAP 220UF 16V ELECT FC RADIAL
            http://search.digikey.com/scripts/Dk...name=P11199-ND
            CAP 100UF 16V ELECT FC RADIAL
            http://search.digikey.com/scripts/Dk...name=P11198-ND
            CAP 47UF 50V ELECT FC RADIAL
            http://search.digikey.com/scripts/Dk...name=P10321-ND
            CAP 10UF 50V ELECT FC RADIAL
            http://search.digikey.com/scripts/Dk...name=P10316-ND
            CAP 1UF 50V ELECT FC RADIAL
            http://search.digikey.com/scripts/Dk...name=P10312-ND
            CAP 22UF 50V ELECT FC RADIAL
            http://search.digikey.com/scripts/Dk...name=P10318-ND
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              Panasonic FK are the smallest you can find to replace the Fuhjyyu caps.
              FK is good series but expensive (at least were expensive at rs store)
              FM is better than FC, if you can get FM go for it.
              Try to check the diameter of all the original caps and then look for same diameter good ones.
              My antec story here: https://www.badcaps.net/forum/showthread.php?t=8223
