Interesting...
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Interesting...
    http://cgi.ebay.com/Teapo-Electronic...item2c4e49a1d6
    Teapo made psu's apparently. Used in some old HP servers.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Interesting...
    date=1991. no bad caps at that time. explains a lot.
    sigpic
    (Insert witty quote here)
    • Spacedye69
      • Nov 2005
      • 698
      • US
      Re: Interesting...
      I had some old NCR Microchannel 486 machines that had Teapo made power supplies also. Guess what brand of caps they used?
      • mockingbird
        • Dec 2008
        • 5484
        Re: Interesting...
        This is inaccurate. I believe someone here once said that the only reason Teapo caps didn't bulge in older systems was because of the low heat/low power. Had they been subjected to today's systems extremes, they would have shown their true colors.
        In fact, I challenge you to pull some old teapo caps from FX or TX Pentium motherboards and test them, they're probably junk.
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          Re: Interesting...
          I trust them in power supplies, but not really in motherboards.
          • Wizard
            • Mar 2008
            • 2296
            Re: Interesting...
            The PSU is a pull from a Intel developer machine boxens that Intel sold at a time long ago.
            This is AT case factor. Bigger brother of XT case.
            Cheers, Wizard
              by momaka
              03-15-2023, 10:17 PM
              A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
              by momaka
              More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
              And a shot of the label:...
              01-26-2022, 03:26 AM
            • Hondaman
              Hardware firewall to block ad servers?
              by Hondaman
              I found an interesting summary on a wiki that Youtube "right to repair" enthusiast Louis Rossman put up. He suggested I could use a hardware firewall and pfSense as a firewall, and use pfSenseNG as an ad blocker. Or use OPNSense as a similar alternative. Seems like it would be easy to set up, but it only runs on the hardware supported by BSD. (I'm sure the developers and maintainers of BSD are super-busy and cannot support every single piece of hardware out there, so I can't fault them.)
              The trick, apparently, is to "assign IP address lists from sites like I-blocklist...
              02-05-2025, 05:04 AM
            • iMic
              IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
              by iMic
              Hi folks,
              I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
              The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
              11-29-2023, 06:44 AM
            • bauto601
              KDM 480W PSU upgrade succes! (opinions?)
              by bauto601
              Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
              A "nice" YoungYear unit? - Badcaps
              The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
              12-26-2023, 03:05 PM
