Help Please with recapped Acbell in Imac G5
  • x33
    • Jan 2010
    • 37
    Re: Help Please with recapped Acbell in Imac G5
    PROBLEM SOLVED!!!
    Toasty, you pointed me to the right direction (3845 ic), THANK YOU!
    As I said, there were no signs of overheating, burn marks or anything like that and everything checked out ok...apparently
    So, I started pulling out the smd transistors around 3845 to measure them.
    One little sneaky bastard 1p transistor (2n2222a smd type, NPN bi-polar) right next to 3845 was damaged internally!!! Junctions B-C and B-E checked out ok but when checked the E-C, I've got 1.9kohms one way and infinite the other....
    Replaced it in a second (thank you my trusty hot-air soldering station) and the psu started working like a charm
    I hope this will help some other poor souls went down the path of madness trying to figure out these psu issues.
    Cheers everyone and I'll stay in touch!
    • godonr
      • May 2009
      • 111
      Just saw your post on getting the 661-3350 p/s up. I'm curious-- are you talking about Q1 and/or Q2 next to the PWM? Did replacing it restore 24v to pin 22 on a jumpered supply? That would be the best news ever.
      • x33
        • Jan 2010
        • 37
        Yes the power supply works beautiful actually and I am using my Imac on a daily basis with no issues so far.
        I regret that with all the excitement I forgot to take a note on which transistor is,before putting it back together.
        I do, however, remember its location visually, so if you can upload the picture of that area, I'll be able to point it to you.
        • Toasty
          • Jul 2007
          • 4171
          https://www.badcaps.net/forum/showpo...1&postcount=27
          veritas odium parit
          • x33
            • Jan 2010
            • 37
            Q1 was the culprit and by the looks of it, it's the same on your PSU as well.
            See the attached pic.
            Let me know if this worked for you too.
            • godonr
              • May 2009
              • 111
              #26
              Have confirmed x33's findings on three supplies already. If after a recap on the 20" power supply you still get 20vdc on pin 22 when jumpered ON, replacing smd Q1 (it will show signs of overheating) next to the PWM will restore the 24vdc needed for backlighting. Thanks to Toasty and everyone else who knocked their brains out troubleshooting this supply. Way to go, x33.
              • x33
                • Jan 2010
                • 37
                #27
                Please note that the signs of an overheated Q1 may or may not be so obvious.
                In my case Q1 was showing a very slightly fogged band across the center of the transistor, which was of course extremely easy to overlook until I used the watchmaker loupe.
                There's also an extreme situation pictured here:
                https://www.badcaps.net/forum/showth...6&page=3&pp=20
                where Q1 actually exploded..
                Anyway, I am glad I have brought my modest contribution in solving this bizarre problem, and if more repairs are confirmed, I'd suggest to turn this thread into a sticky, for the solution to be more accessible.
                Cheers everyone!
                • murf64
                  • Jan 2011
                  #28
                  OK I've learked in here long enough. I'd like to thank you guys. I've been recapping motherboards for six months. Last month I ran across my first bad power supply, it was a celetronix. I checked another 20" I had fixed up for my wife also had a celetronix. I took both apart and I started using the good unit to get an idea of what the voltages should be at certain spots on the board. And then the good one died, damn. I don't know what I did but I killed it.
                  After reading this forum, I got the impression I would be unable to repair either celetronix, so I bought a dead Acbel on eBay. I knew I could do a recap job. Unfortunately, when I got the new dead power supply the capacitors looked perfect. I realize they could be why it didn't work, but I really doubted it. At my wits end, I read this thread. This morning I pulled the Q1 transistor and it tested bad! I replaced it with a similar one off one of the dead celetronix. I put the psu in my wife's 20" iMac and it started right up. Amazing.
                  I still have one 20" iMac I need a psu for. I'm waiting on an eBay auction for an Acbel, but I'm hoping you guys come up with a fix for the celetronix units before then. I still have two of them.
                  Thanks for the great work.
                  • jetadm123
                    • 2169
                    #29
                    Interesting reading. Wonder if it's a bad batch of Q1's or using a transistor that's underrated for the the application? Or, maybe a lousy design?
                    • Toasty
                      • Jul 2007
                      • 4171
                      #30
                      Q1 supplies Vcc to the 3845 PWM chip. It's Collector is connected directly to the positive of the 100uF @ 50v cap near the TOP. Emitter is hooked to Pin 7 (Vcc) of the 3845.
                      I don't think its a bad batch of 1P's, as they are used all over these PSUs. Internally, the 3845 has 34v zener across Vcc and Gnd. If the supply voltage spikes above that, I'm wondering if that causes Q1 to overheat and die. There have been a few cases where Q1 and the 3845 have popped/cratered. Could that be from not just a spike but a constant overvoltage or continuous spiking?
                      Toast
                      veritas odium parit
                      • godonr
                        • May 2009
                        • 111
                        #31
                        may be a clue here... to date I've replaced 49 1Ps but never a C37 (100u/50v). this is in the AP13PC96-290 AcBel version. usually it's C40, C52, C49, C47, C45, C56 and C55 that have failed also. many repaired supplies have been on constantly for nearly a year now.
                        • godonr
                          • May 2009
                          • 111
                          #32
                          Should add... all showed signs of overheating and EC was shorted.
                          • Toasty
                            • Jul 2007
                            • 4171
                            #33
                            Yes, but those caps filter the power to the PWM and surrounding, and control the TOP. It's worth it to me for <$2 worth of caps to never see it again for that reason.
                            veritas odium parit
                            • godonr
                              • May 2009
                              • 111
                              #34
                              Duly noted
                              • ryogadan78
                                iMac A1418 - No LED, no power after overvoltage on Ethernet port
                                by ryogadan78
                                Hi guys, I need your help again.
                                I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                                When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                                06-10-2025, 03:49 AM
                              • Stephen
                                iMac M1 DFU restore issue
                                by Stephen
                                iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
                                this is the message it gives me with the error
                                Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
                                Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
                                03-07-2025, 12:19 PM
                              • Stephen
                                iMac 27” 2020 Boot issue
                                by Stephen
                                Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
                                08-16-2024, 09:32 AM
                              • tommy97
                                iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
                                by tommy97
                                we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
                                Any ideas what might've...
                                04-20-2024, 04:48 AM
                              • прямо
                                Viper22A 5VSB circuit
                                by прямо
                                So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                                In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                                01-13-2024, 07:05 PM
