MPJA 10 AMP @ 0 to 30 Volts Switching Power Supply Cap Fault
    • Jul 2011
    • 6070
    I have this 10 amp 0 to 30 volt switching power supply that decided to have a 630 milliamperes draw on it at 0 volts
    I open it up to find non brands name capacitors in it
    I am not sure how this switching power supply is set up
    Could someone please explain how this power supply works
    Here is the capacitor ESR results
    (1) 47uf@50 volts 0.46
    (2) 47uf@50 volts 0.45
    New 47uf@50 volts 0.35
    (1) 100uf@25 volts 0.34
    (2) 100uf@25 volts 0.35
    New 120uf@50 volts 0.08
    (1) 220@25 volts 0.13
    (2) 220@25 volts 0.13
    New 220@35 volts 0.03
    (1) 1000@35 volts 0.03
    (2) 1000@35 volts 0.03
    New 1000@35 volts 0.02
    3300uf@35 volts 0.02
    New 3300@35 volts 0.02
    • 31285
    Re: MPJA 10 AMP @ 0 to 30 Volts Switching Power Supply Cap Fault
    interesting.
    see the current shunt coil?
    it connects to the small board - i suspect the 2 ends feed an op-amp to monitor the voltage drop.
    btw, the internal tactile switch is just asking to be pressed!! they should have painted it red!
      • Jul 2011
      • 6070
      Yes
      I wonder about that button as well just what does it do
      The button does not seem to do anything at all but there is another connector that might be how you program the controller but this is only a guess
      On the small board the small IC chip is a LM 358
      The switching power supply is back working again
      The only problem this power supply has is that it has to be ON a little while for the voltage to stabilize it drift a little bit a couple hundredth of a volt for first 5 minuets or so and then it fine
      But it has done this when I first turn ON new out of the box
        • Jul 2011
        • 6070
        I used the following caps
        KY
        KZE —> maybe
        LXZ
          12 volt switching power supply modification to 14.5 volts before blocking diode add
          by sam_sam_sam
          I saw this switching power supply on eBay and wanted to see if could be modified to run 14.5 volts before the blocking diode was add and this switching power supply seems to have no issues doing this
          I did recap the switching power supply except the the main filtering capacitors and I managed to break the selector switch for the voltage setting but just jumped it
          One note I used 25 volt capacitors on the output side of this power supply because they used 16 volt capacitors and because I am running the voltage up a little bit higher 12 volts to 14.5 volts there would...
          04-11-2021, 11:01 AM
          by sam_sam_sam
          03-31-2024, 02:12 PM
          DVR camera recorder switching power supply capacitor failure really
          by sam_sam_sam
          These cheap non brand capacitors at it again
          Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
          Well at least I have the cameras back on line I to try the...
          01-22-2022, 06:28 PM
          Using a 5 volt @ 12 amp switching power supply and two USB doctor volt / amp meter to three IPads on one power supply
          by sam_sam_sam
          I have been wanting to do this project for some time using a Mean-well switching power supply that I bought at least ten of them that were originally in a device that was abandoned for some reason they were listed new but removed from equipment that was never used
          I do not understand Mean-well the capacitor next to the voltage reference ic chip was a brand that is known for failure over time the other capacitors are brand name needless to say it got replaced before I even powered it on for the first time
          I used a four USB outlet and electrical plate that is made for...
          08-03-2024, 07:54 PM
          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
          by sam_sam_sam
          I was working on this CNC machine today found no keyboard functioning no control relay powering on
          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
          Found shorted diodes on main controller relays there are 3 of them that...
          01-07-2023, 05:43 PM
