the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
PeteS in CA
Re: the gutless, bloated, and fried power supply hall of shame
Got something which I think fits well in this thread. Notice anything wrong on this XBOX one power brick board here ? I'll give you a hint: REVERSED !Wait, it gets better: this power brick didn't show any signs of previous servicing, since the solder job looked factory-made, which makes me 99% sure it came like that from the factory ! Has anyone heard of something like this before ? :| It was such an easy fix it was positively brilliant and the added "stupidity" of the fault further added to the satisfaction I got in the end
Wattevah...Comment
Their quality and QC is really good, typically. It would be a shame to see them go downhill. I hope they aren't.
Now imagine if this is a widespread problem and there are hundreds of people throwing away their Xbox Ones because of this- that would be silly, actually.
Thanks for sharing.Let's hope yours was just an isolated incident and not a widespread problem. That would be great for repair businesses, but terrible for the environment, considering how many Xboxes can get thrown out because of this.
Wow, someone at the factory screwed up big time here. And this is a Chicony (HiPro) PSU!Their quality and QC is really good, typically. It would be a shame to see them go downhill. I hope they aren't.
I spy a Samxon GF or GK and a large load reistor in the background (and if I'm deciphering the colors of the bands correctly, it looks like it's a tad underspec'd). The notion of using Samxon GF/GK or Ltec (right next to a freestanding diode), in a hot power brick (even though it has a tiny fan), makes me cringe.Last edited by Wester547; 11-16-2016, 07:44 PM.Comment
I had a 2008 FSP 500W that did well, even with Teapo caps, no sign of them failing as far as I can tell. Was powering a Sabertooth 990 FX R 2.0 and FX Vishera 8350 (made in 2014, so a late batch) this year!
Still no sign of problems when I last saw it in 2016!
I gave the system away. I miss it...
Just got the Sabertooth 990 FX R 2.0 on July, 2015 and installed on August 25, 2015... And 16 GB of G.Skill RipJaws DDR3 in December, 2015... Got the FX 8350 on September 8, 2014...Last edited by RJARRRPCGP; 11-16-2016, 08:27 PM.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"¡Me encanta "Me Encanta o Enlistarlo con Hilary Farr!" -Mà mismo
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
I got this psu for free. It's a Deer (lc-b300atx). I decided to crank it open and see what's inside. Anddd oh dear... (pic 1) Of course, there's no input filtering at all, undersized heatsinks, small transformer and undersized input caps (330uf 200v. The primary switchers are, of course, 13007s. The four diode treatment (4* 1a, 100v). Now the secondary side. And wow. Look at that discoloration. The 12v rectifier are 2 3a ultra fast recovery diodes. The 3.3v and 5v rectifiers are sr1040ct (10a 40v). 3.3v pi coil is toasted. I removed the 5/12v coil because it was toasted as well. No inductors on the secondary. The secondary side is populated with g luxons and jun fus (not kung fu). None of them are bulging or leaking and all are good on esr (interesting through). The 5vsb rail has a 470uf 16v g luxon. Of course, the old, crappy 2 transistor forward. Definitely the worst psu i've ever seen.Comment
Intact, that POS might have been good (using the word generously) for 200W. There is nothing in it that is adequate for 300W. It was also unsafe. Those two tan ceramic disc capacitors near the AC wire in used as Y-caps, but aren't safety agency approved. The O/P inductor probably got so hot for so long that the magnetic properties of its powdered iron core are probably badly deteriorated.PeteS in CA
****************************Comment
I got this psu for free. It's a Deer (lc-b300atx). I decided to crank it open and see what's inside. Anddd oh dear... (pic 1) Of course, there's no input filtering at all, undersized heatsinks, small transformer and undersized input caps (330uf 200v. The primary switchers are, of course, 13007s. The four diode treatment (4* 1a, 100v). Now the secondary side. And wow. Look at that discoloration. The 12v rectifier are 2 3a ultra fast recovery diodes. The 3.3v and 5v rectifiers are sr1040ct (10a 40v). 3.3v pi coil is toasted. I removed the 5/12v coil because it was toasted as well. No inductors on the secondary. The secondary side is populated with g luxons and jun fus (not kung fu). None of them are bulging or leaking and all are good on esr (interesting through). The 5vsb rail has a 470uf 16v g luxon. Of course, the old, crappy 2 transistor forward. Definitely the worst psu i've ever seen.Wattevah...Comment
I think I just had a deja vu moment. Oh wait, I know why!
https://www.badcaps.net/forum/showpo...&postcount=491
Actually, it looks like those diodes are RL205, which are general purpose didoes capable of 2 Amps at Ta=75°C. Even with those and at 120 V AC line input, they would still probably be the last thing to fail. I had a JNC PSU with the same diodes, and after its 5VSB committed suicide, I used those diodes along with the 13007 BJTs to fix a 12V halogen lamp PSU that had its bridge rectifier and 13007 go nuclear for whatever reason.
(and I just coined a new term here)
You know why?
Because that spot calls for a much larger toroidal inductor, not a tiny PI coil. Given that the 5V/12V coil also burned along with the FR diodes on the 12V rail, looks like this was probably in a somewhat more power-hungry system, possibly with a high-end GPU. Perhaps an Athlon XP (heavy 5V rail use) and a modern 12V-heavy AGP video card. Or maybe the other way around... a Pentium 4 CPU (12V-heavy) and a Radeon 9700/9800 video card (3.3V/5V heavy).
Deer's call: Ripple suppression? We don't need no ripple suppression! Look, the PSU still works perfectly fine.
Yeah, it's definitely high on that list. Though these are some note-worthy opponents, IMO:
https://www.badcaps.net/forum/showth...ight=echo+star
https://www.badcaps.net/forum/showth...ight=cyberlinkLast edited by momaka; 11-17-2016, 05:24 PM.Comment
Oh Deer…shoot it on sight lolHaven't though I'd see another diode treatment ever again. Guess they are still around…
Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
Back in ancient times Boschert used ~1/2 inch diameter powdered iron (-26 material) toroids with 2 or 3 turns instead of several turns on a ferrite rod. That was back when they built their P/Ss in Manteca, CA.PeteS in CA
I thought the other purpose those ferrite coils (or coils with an "air" core in some cases) serve is that of a voltage divider, but for the output caps. So the cap(s) before the coil handle most of the switching frequency ripple (or the pulses from the transformer and rectifiers) and the cap(s) after handle very little (although the magamp circuit or toroidal inductor before the output caps would handle the majority of the switching frequency ripple by comparison). It seems to be the consensus that caps and inductors that form a PI filter can better suppress high frequency ripple than simply using multiple caps in parallel or only one beefy cap, but I suppose it would depend upon the rest of the design.Comment
That said, the self-resonant frequency of a filter circuit with and without the PI coil is going to be slightly different. This has to be considered when the rest of the PSU is designed (otherwise you can get nasty ringing on the outputs and/or the PSU filter may not filter the switching frequency that well). Thus, it is possible to make a PSU output filter without PI coils and still get really good ripple and noise suppression. But the PSU just needs to be designed for it (probably both the capacitor specs and the main toroidal inductor inductance will need to be altered). Also, the compensation may need to be tweaked too. And of course, the switching frequency plays a big role too.
Now that's about as far as my knowledge stretches. As for calculating values for any of the above stuff... I haven't that much a clue.Last edited by momaka; 11-19-2016, 04:36 PM.Comment
Well, many PSUs that don't have them (and were designed to have them but they weren't installed) usually have much higher output ripple and noise. Typically, that's something the low-end junk PSUs found in this thread often do. So those "PI coils" certainly must be doing something useful.
It's not really a voltage divider as the voltage on the input and output of the circuit is the same. Technical term is a CLC low-pass filter. Actually, in the case of SMPS it's LC-LC low-pass (two inductor-capacitor low-pass filters chained). But technically speaking, you are correct that the cap before the "PI coil" (the first LC low-pass) handles most of the switching frequency filtering and the cap after it (the second LC low-pass) is there just to further curb the high-frequency ripple and noise.
Now that's about as far as my knowledge stretches. As for calculating values for any of the above stuff... I haven't that much a clue.PeteS in CA
And of course, the switching frequency plays a big role too.Last edited by Wester547; 11-19-2016, 05:41 PM.Comment
I guess it's my turn to post something...
What I have for you: a Raidmax RX-380K (i.e. a Sun Pro KY-480ATX).
outside: https://www.badcaps.net/forum/attach...1&d=1388363334
label: https://www.badcaps.net/forum/attach...1&d=1388363334
top side (taken a few years back): https://www.badcaps.net/forum/attach...1&d=1388363334
another top side (a little more recent - you can see another cap has failed in there just from the PSU sitting in storage): https://www.badcaps.net/forum/attach...1&d=1388363334
primary side showing diodes in bridge rectifier and the bent leads on the parts attached to the heat sink: https://www.badcaps.net/forum/attach...1&d=1388363334
secondary side shot: https://www.badcaps.net/forum/attach...1&d=1388363334
botton side (solder side): https://www.badcaps.net/forum/attach...1&d=1388363334
This is probably the crappiest power supply I have around. The case is made out of paper-thin steel. The heat sinks are equally anorexic. Soldering on the bottom side is plain awful. Lots of loose solder balls came out when I first opened it. It's a miracle it didn't short out at the factory. The primary transistors have their leads so bent that they are nearly touching each other! As you can also see from the bottom-side picture, the separation between traces on the primary is very small. I'm pretty sure this thing never passed UL, CE, or any other safety marks. Then again, it's clear from the label the safety marks were forged. The wires are all 20 AWG (with 22 AWG for floppy connector) and completely unlabeled!(not a single safety agency or UL number in sight)
380 watts output??? Yeah right. It may not be very clear from the pictures, but the PCB has some serious "burn-in", and this was not caused by a stuck fan since the fan is spinning fine (although, I should note that the fan was quite dry... looks like it never saw lubrication from the factory). Speaking of which, the fan is a Te Bao Metallic Plastic model M802512M rated for 12V and 0.14A. IIRC, this PSU was powering a mediocre Athlon XP 1600+ system with a GeForce 5200FX video card and 1 HDD, so nothing too heavy.
Primary/input side:
Not much to talk about input filter. We have us two blue (but fake!) Y caps, and a sugar-cane-colored input choke. No X cap. Better than nothing, still.
Moving on... two bigger and two smaller diodes for the bridge. Too lazy to read part numbers, but I'm guessing 3A and 1.5A or 2A diodes. The two bigger diodes are always used, so this PSU should be capable of pulling 300W from the wall with these diodes (of course it won't, as you'll see from the rest of the parts list).
Also on the primary: 2x 200V 330 uF Metacon GK primary caps that read 200 uF and 196 uF on an ESR Micro V4. Primary transistors are a pair of 13007 BJTs in half-bridge configuration. Main transformer is size 33. 5VSB transformer is the standard cute small stuff you always find in all cheap PSUs. Speaking of 5VSB - it's that good old friend, the 2-transistor design. It doesn't have a critical capacitor, though.
Secondary/output side:
12V rail has a 12A 200V fast recovery rectifier. 5V and 3.3V rails share a single 20A 40V schottky. The 3.3V rail is derived from 5V rail in a linear fashion with a CEP51A3 (48A, 30V, N-channel MOSFET).
Output caps:
12V rail: 1x brown CS "LOW ESR" 16V 1000 uF cap placed after a PI coil.
5V rail: 2x JEE "LOW ESR" 10V 1000 uF caps (1x before and 1x after PI coil)
3.3V rail: 1x JEE "LOW ESR" 10V 1000 uF cap after PI coil.
5VSB: not exactly sure. I think 2x CS 16V 470 uF caps originally (1x before and 1x after PI coil), but one of them failed, causing the 5VSB to crazy with anything higher than 50 mA of load. I think I saw the auxiliary rail for the PWM controller (an AZ7500BP) go as high as 30V when this was going on. I recapped the failing CS cap with a questionable STONE 16V 470 uF cap out of a Philips TV that had other STONE caps of the same ratings failed. But it's a crap PSU, so why waste good caps on it? I just wanted to get it working again, which the STONE cap did. 5VSB is good for up to 1.5A of load now, though it does get warm with that load. Before you jump and scream at me... don't worry - I'm not going to put this PSU back in a PC ever again.
Actually, the case from this power supply is now housing the guts of a beefy HiPro HP-P2507F3P 250W PSU that a friend gave me.
Sorry for that wall of text above. Hope you liked this one
Something is wrong here - I just got a PSU with the same PCB (7700A transformer) - however the transformer itself isn't EI-33. I looked at the core and the size - and I was shocked to find it's a EI-40.
Any idea how much can a EI-40 do? Heatsinks are quite small but are thick enough.Main rig:
Gigabyte B75M-D3H
Core i5-3470 3.60GHz
16GB DDR3-1600
Samsung SH-224AB DVD-RW
Delux MG760 case
Well the transformer core size is credible for 400-500W. With heatsinks, both thickness and surface are matter. Thickness matters for the thermal resistance within the heatsink - can the heat flow from the point of origin to the farthest fins. Surface area is important where exposure to cooling air is concerned.
What of the switch devices and rectifiers?PeteS in CA
by bauto601Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
A "nice" YoungYear unit? - Badcaps
The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish.... -
by eccerr0rIntroducing... the POS-124Z which really is a POS:
Yep it's a POS allright.
I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
So I had to take a peek:
EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?... -
by tamerelaputeHi,
I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
Except the cpu, I cant feel anything getting warmer.
I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
I believe that if the cpu was fried,... -
by LapsmithWhile installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
by Per HanssonWhile our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
The caps for this have gone a bit high ESR
The measured ripple is around 1700mV, or 1.7v!
After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
-And that's how you know you have a qualifying... - Loading...
