the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • mariushm
    • May 2011
    • 3799
    #441
    Re: the gutless, bloated, and fried power supply hall of shame
    Here's article discussing it:
    http://www.eetimes.com/design/power-...ork-in-the-US-
    You're right, seems PFC is not required but it really makes it easy to obide by all the rules if active pfc is used and possibly also passive pfc.
    The European Union (EU) has developed a current harmonic content specification (EN61000-3-2) to improve line power utilization. Meeting these harmonic current criteria can be easily accomplished by using power factor correction (PFC) boost pre-regulators. However, achieving this specification does not necessarily require a power factor controller or a high power factor.
    So those harmonics have to be met, pfc passive or active can be used for it but it's not required.
    To reduce design costs, some power-supply designers found they could meet EN/IEC61000 requirements by using other means with some filtering. The designs could pass the harmonic requirements with a PF as low as 0.8.
    However, Energy Star (Reference 1) is proposing a new PF legislation of 0.9 at full load in 2008 that will become part of the 80 Plus initiative (Reference 2). As this becomes a reality, some of the old IEC 61000 designs may not meet this new stringent requirement. In order to have a PF greater than 0.9.PFC, pre-regulators will need to be added to these designs
    So if you want to label the psu as 80plus you need to use some form of pfc
    later edit: this url seems to be a powerpoint presentation discussing the IEC 61000-3 standard : https://cdn.badcaps-static.com/pdfs/...53d00d3604.pdf
    this also has some good info : https://cdn.badcaps-static.com/pdfs/...62c0d0ae47.pdf
    hint : type in google "IEC 61000-3 filetype:pdf" and you get more.
    <- this seems like the official standard 61000-3-3
    • TELVM
      • Oct 2012
      • 547
      • Spain
      #442
      Pics of another gutless wonder from a friend:
      After just a year of use this wonder went and he was lucky the attached comp survived the ordeal. Keeps blowing the fuse.
      I told him to forget about repairing and don't waste any effort on it.
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        Maybe the NTC Thermistor is shorted? And man that thing sure could use some input filtering! Could you post a picture of the label?
        • Behemot
          • 4845
          • CZ
          #444
          I'd say 300-350 W?
            Not with the fake 330uF. If they are real, I put continuous power at 150W; but if they are fake 220uF (from the size they look to be around that, and I've seen it before in cheapies) I'd say squeezing any more than 100W would be asking for trouble.
            Problem is with those caps being so small, the transistors have to work in overdrive to put more current through the transformer to keep the output stable. They usually don't manage it so you see 600~1000mVp-p of ripple on the output in a 100Hz sawtooth wave. See this picture from a "430W" PSU with 350W load. It used 680uF primaries, predicting 340W max output... and the ripple is already through the roof:
            http://www.hardwaresecrets.com/artic...y-Review/332/7
            Notice how the ripple peaks every 10ms -- this is no coincidence. It is at 100Hz, so is due to lacklustre primary bulk caps.
            And of course, the transistors don't last as long... probably one of the contributions to them going bang!
            • Behemot
              • 4845
              • CZ
              #446
              U think I am stupid? Was guessing label power…
                Sorry, that wasn't obvious from your post.
                • Wester547
                  • Nov 2011
                  • 1269
                  • USA.
                  #448
                  I don't think the primary capacitors are the reason for it being so inefficient. It only has a single TO-220 switcher rather than a TO-247 or TO-3P switcher - that's going to hurt it badly. This review of the Antec/Delta VP350 shows it doing 350W (though it exploded at 475W) with only a pair of 470uF/220V/105C CapXon capacitors, and the voltage regulation, noise, and ripple suppression was excellent, though the efficiency as an overall was only 76%. With very good cooling, superb AC/DC filtering, and enough of an overspec'd secondary and primary otherwise, I think you might be able to get away with smaller primary capacitors, though certainly not with fantastic efficiency. Granted, I also know that Delta design their PSUs such that their components aren't stressed, so that also helps, but even then...
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    #449
                    This is an exception of the rule.
                      Yes, it uses a different topology though. The coincidence with capacitance =~ output power only appears to work for half bridge and flyback designs. With a different transformer design, you can get away with smaller capacitors.
                      • TELVM
                        • Oct 2012
                        • 547
                        • Spain
                        #451
                        No pic but the man tells me the label pretended to be 500W, no less .
                          Oh my. It can't even do a third of that. My favourite is this PSU claiming 1050W, but only capable of a mere ~600W...
                          http://www.jonnyguru.com/modules.php...Story&reid=187
                          And again, 1200uF, so should be 600W capable, and it just starts topping out then with ripple through the roof.
                          • TELVM
                            • Oct 2012
                            • 547
                            • Spain
                            #453
                            In fact we can see the label with a remarkably mendacious '500W' at the top of the second pic .
                            • Behemot
                              • 4845
                              • CZ
                              #454
                              It says 500W MAX But not for how big fractions of a second
                              • Wester547
                                • Nov 2011
                                • 1269
                                • USA.
                                #455
                                Even more confusing, though, is that this power supply manages 300W in what appears to be half bridge topology with only 330uF/200V/85C OST SPS input capacitors (link)! Granted, the medium speed, 80mm ADDA fan in there seems to be running at about full speed the whole time by comparison to the more temperature controlled fans seen in other PSUs, and the +12V rail's voltage regulation is somewhat dismaying (though still within spec especially since the whole PSU is at 77% efficiency), but even then....
                                  I can definitely see what looks to be a sawtooth wave on the output of the 12V, which looks too clean for normal switching noise so it's probably 100Hz. There's no obvious scale but once that starts exceeding normal ripple (~50mVp-p?) you really have a problem...
                                  • Behemot
                                    • 4845
                                    • CZ
                                    #457
                                    For +12 V/-12 V its 120 mV. Man, at 50 mV, 90 % of market would be out of spec
                                    • Wester547
                                      • Nov 2011
                                      • 1269
                                      • USA.
                                      #458
                                      I also wonder if it was because of the 20AWG wires by comparison to the 18AWG wires used - if I'm not mistaken there's about a 60% difference between what they can handle in amperage per wire (though it varies per wire even then, IIRC). Could that be the reason, rather than diverging topologies making it easier for primary capacitors to "store" energy?
                                      EDIT: Oh, well, I would think the efficiency is lowered even with a voltage drop. ^^;
                                      • Behemot
                                        • 4845
                                        • CZ
                                        #459
                                        If the wire cannot handle it, it just creates voltage drop, how can it affect power? Only way I can think of is the consuming device taking even more current when voltage goes down (that's what VRMs do though).
                                        • PeteS in CA
                                          • Aug 2005
                                          • 3586
                                          • USA, Unsure of Planet
                                          #460
                                          A voltage drop across a wire is wasted power: P = V * I. So too-small wire gauge can affect the over-all efficiency. Theoretically, the safety agencies made sure the wire gauge was adequate for the current. But if the agency marks are fake, or the P/S mfr used a smaller wire gauge than what they submitted to the safety agency ...
                                          PeteS in CA
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • serwanjaf7
                                            hp victus (la-m787p) hall sensor problem
                                            by serwanjaf7
                                            hello friends
                                            pls i need help with hp vicuts it have problem on the hall sensor i want to change it bu i dont find and i dont now what is the part no
                                            pls need help
                                            thank you...
                                            12-08-2025, 01:23 AM
                                          • x_orange90_x
                                            Samsung UN65AU8000FF fried by water
                                            by x_orange90_x
                                            I was given this tv today. It was purchased just last month and only used for 3 weeks until recently when water leaked down the back and behind the cover. I removed the boards and WHOA 😲 did this thing get fried. Unfortunately the water got directly onto the backlights portion of the PSU. The board appears to be completely unrepairable, but I'm not certain about the backlights. I managed to get the probes of my tester into the slits of the plug and I DO get readings from both strings. I'm getting 26v from both. The PSU says LED Output is 167.4v however. Would this indicate that the backlights...
                                            10-16-2025, 08:40 PM
