Antec SL450P Smart Power Exploded!
    master hoarder
    • May 2008
    • 12175
    #61
    Re: Antec SL450P Smart Power Exploded!
    Originally posted by Behemot
    Momaka: I am not really friend of the idea of removing PFC. It has nothing in common with power factor in terms of phase change, we are dealing with harmonics here and that is some crazy stuff.
    Losses are not really problem (that is problem of phase change), harmonics are. And not only for distributors but for industry, especially the ones using motors. That is almost anybody after all (every industry machien has some motor), than you have motors in various home appliances, big old motors in elevators etc. Harmonics damage all that and it's pretty fucking expensive to change huge motor on top of elevator schaft.
    Let me tell you this (probably a stupid counter-example, but anyways)...
    I have lived a big portion of my life in Eastern Europe in one of those old concrete apt. complexes. As far as I know, our apartment building still has the same 3-phase motor that it always had - at least since the early 90's, that is (and that's only because someone stole the original motor). Now the entrances next to us still have their original elevator motors - back from when the condo complex was built in the late 50s.
    And even with the cheap crappy power supplies of the late 90's and early 2000's (when APFC was still unheard of, and a 300W gutless PSU was just as good as a 300W brand-name PSU... except there were no brand-name PSUs to be found where I lived), I haven't heard of people replacing their elevator motors just because of "bad harmonics from non-APFC PSUs". Heck, the condo complex next door had a "game cafe" in one of the apartments. You know... the type with many computers crammed into every room of the apartment, and all of the computers built in the cheapest bottom-of-the-barrel cases and PSUs. And that's not the only place I knew that was like that. Many game cafes were the same way. No scratch that... many still ARE this way.
    Most of the "damaging" harmonics you are talking about probably don't even make it past the first step-down transformer in the grid.
    If insufficient input filters are present, it will stress and damage every other single SMPS you have at home (also dozens of them - different chargers, TVs, monitors, printers etc.). So telling somebody to remove PFC is really pretty stupid thing, it will damage everybody around you, including yourself.
    Right... that's why those old tube TVs and monitors are still working and so damn hard to kill. Come over to where I live now and see for yourself. People are dumping these large TVs on Craigslist for free... and all of them are working too.
    Originally posted by kc8adu
    imho its not worth the added complexity.so when it fails no big deal to gut it and replace with a doubler here
    Exactly! Which is why I suggested to goodpsusearch to just gut it and go on without it.
    In fact, let's have us all a bit of an educated discussion why APFC is so "popular" now.
    - First off, it mimics a resitive load more or less, so better for the power company.
    - Second, it allows a PSU to be a "universal" type without needing a selector voltage switch. It will also allow the PSU to function down to very low line voltages (especially in countreis with 220/230/240 V AC).
    - Third, it allows same energy to be store on the "input" stage of the PSU with smaller caps.... Because remember, the energy stored in a capacitor is directly proportional to its capacitance and directly proportional to the square of the voltage across the capacitor. So by increasing the voltage just a little bit, you can lower the capacitance a lot. A single 330 uF 450V cap charged to 420V will hold the same energy as a pair of 1000 uF 200V capacitors in series charged to 340V total. Yes, you do have the complexity of APFC, like an extra MOSFET, diode, and torroid, but it does have the advantages mentioned above (as far as for who, that's another story). This last point especially applies to very high-wattage PSUs, where the extra capacitance can become prohibitively large (and very demanding on the NTC thermistor and other input components before it). So for those, it just makes sense to have APFC.
    • goodpsusearch
      • Oct 2009
      • 2850
      • Greece
      #62
      off topic
      So, some time ago you lived in Europe? Very interesting. Why did you move out?
        master hoarder
        • May 2008
        • 12175
        #63
        ^Yes.
        Parents found work in the US so I moved with them (I was a kid in middle school).
        That's why you'd always see me mention things both in metric and imperial units, among other things .
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          #64
          I see. Things must have been pretty tough back then.. I'm glad it worked out for you!
          I assume you have two native languages now
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            #65
            I replaced the 2 560uF 200V Panasonic primary capacitors with whatever I had in stock: 1x1000uF 200V Capxon (real capacity 970uF)
            & 1x1000uF 200V Panasonic UQ (real capacity 863uF).
            I also removed the 4.7Kohm resistor from the fan mod in order to make the psu more silent.
            Now while idle, the fan spins at ~950rpm and at full CPU/GPU usage without case ventilation it rotates at 2825rpm.
            Previously with 5.6kohm//4.7kohm (=~2.5kohm) it idled at 1550rpm and took off at max temperature
              master hoarder
              • May 2008
              • 12175
              #66
              Lol, that's a funny recap . Pretty cool, though the way you balanced it with the two caps. I wonder why the Panny is reading low on capacity.
              Ah, forgot to answer that one.
              No, things were okay for me, because I was a kid and didn't know any better . It was probably tough for my parents, though. Basically the early 90's crysis in Bulgaria (and also Romania).
              Yup. I speak two languages .
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                #67
                The Panasonic primary cap could be counterfeit. If you look closely at the pictures, the markings look suspicious, I bought that cap from a local electronics store so it is possible.. But I don't care as long as it works.
                  master hoarder
                  • May 2008
                  • 12175
                  #68
                  Looks kinds of small too. I guess you could check with the Panasonic UQ datasheet and verify the size. Also can remove the plastic cap underneath and see what the vent looks like. But I doubt it's worth it.
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    #69
                    https://cdn.badcaps-static.com/pdfs/...04609c7424.pdf
                    22 x 45
                    Looks legit!
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Funny you say that, actually. On the Antec Smartpowers I've had, the fans would never spin fast, even at full load on the load tester, without a resistor mod.
                      I have an SL350 in my stash where the fan controller appears to have failed. The fans wouldn't even spin up with the thermistor shorted. I ended up replacing the fan controller with one scavenged from an old FSP. Those FSP controllers have a more aggressive fan curve than the Antec SL/SP anyway, so I never worry about resistor modding them.
                      • goodpsusearch
                        • Oct 2009
                        • 2850
                        • Greece
                        #71
                        There are many versions and revisions of Smart Power. I have atm 2 identical SmartPower 450W psus, the removed pfc unit is fan modded with a 5.6kohm resistor in parallel with the thermistor and the other has 4.7kohm and they behave quite the same in terms of noise and thermal management.
                        Please note that this version has 2 thermistors, RTH2 is responsible for fan controller and RTH3 is for over temperature protection. I learnt it the hard way, I kept lowering the resistor value in parallel with RTH3 until the unit would not start at all :P
                        • c_hegge
                          • Sep 2009
                          • 5219
                          I knew that there is SL and SP. SP Smartpowers were far more common back in the day here. I think I've only ever fan modded maybe two or three SL series compared to at least a dozen SPs. I've found that 2.4K or 2.5K seems to give me the sort of fan curve I like quite consistently. Maybe there were more Smartpower models available in Europe and the US than we have here.
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • PantherDave
                            by PantherDave
                            Hi all!
                            05-29-2024, 02:01 PM
                          • GLISIT
                            by GLISIT
                            01-16-2025, 02:29 PM
                          • mrdevil
                            Crest Smart Home Single Power Adaptor SHSPM1 (rebadged Tuya device) - bad cap causing failure, how to repair
                            by mrdevil
                            Wanted to share this as I couldn't find anything on the internet about this problem, so pulled one apart and found the problem myself. Years ago I bought approx 20 or so Crest Smart Home Single Power Adapter smart switches - small 240v Tuya-compatible (rebranded) smart switch devices with power monitoring, which Big W had on sale for half price. Paid $7.50 each for these, and they've been incredibly useful for turning things on and off remotely... and monitoring how much power each device uses.
                            However, after about 12 months, I had a number of these stop working...
                            01-08-2025, 03:19 AM
                          • CWEastwood
                            Antec Smart Power SL300S capacitor replacement.
                            by CWEastwood
                            I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                            The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                            I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                            Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                            03-25-2023, 12:18 PM
