Need help with Antec TruePower2.0 380W
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    #41
    Re: Need help with Antec TruePower2.0 380W
    Originally posted by PCBONEZ
    Your gripe was that the fan is too loud.
    I've never thought of those as having loud fans.
    Suspect caps problems are screwing the fan control or causing heating such that the fan is running too hard.
    Sorry, there is an error at that post I made:
    Originally posted by goodpsusearch
    In the meanwhile I am concerned about the psu fan. It is thermally controlled and usually it spins at 1100 - 1250 rpm which results in psu running really hot inside. Is there any way to make it run faster? Do you know the exapt point the thermal sensor is?
    When fan connected directly at +5v it is running too slow, ~800rpm.
    When running at 12V it was cool, 2280rpm, but way too loud...
    If only there was a way to make the thermal controller more aggresive.
    My gripe was psu getting too hot with the fan attached to the fan controller, so I tried 5V, 12V and 7V.
    Fan controller --> 900 - 1250 rpm --> too hot
    5V --> ~800rpm --> too hot
    12V --> 2280rpm --> cool but loud.
    7V --> cool and quiet --> identical but unsafe
    Sorry for the typing error
    • goodpsusearch
      • Oct 2009
      • 2850
      • Greece
      #42
      Are you sure the 7V mod is unsafe?
      120mm fans at rs are over 20 euros each and 4 euros for the postal service (nice song btw).
      I could search at Thessaloniki for fans, but I am not sure this will work. See why:
      1) I buy a more powerful fan and replace the original.
      2) When I power on antec, the fan does not spin at all with low voltage, or it spins, so the psu gets cooler than with the original fan and the fan controller lowers even more the fan volts and stops the fan or keep it working but cooling less or equal than original fan.
      Where is the fault at this thought?
      Sorry, I made a mistake there too.... I have slept only 5 hours... sorry...
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        If it's 800rpm @ 5V and 2280rpm @ 12v,, then on 7v it's going to be right around 1250-1260rpm which isn't any different than your controller.
        Why do you think 7v is unsafe?
        Mann-Made Global Warming.
        - Dr Seuss
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          #44
          strangely, it worked faster at 7V, but I couldn't meter the rpms because there was no ground for mobo connection to show rpms.
          Many users across the web claimed its not a good idea to send back current to psu. Some others said that if fan dies and gets sorted, 12V and 5V will be sorted, destroying the psu and maybe things connected to it.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            DC current goes from low volts to high volts.
            There is no 'back current'.
            That's like saying water might run uphill.
            - Dr Seuss
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Might be a minor issue with EMI from the fan motor coils but you can fix that with a couple small uF caps.
              I'm not sure what an optimal value would be.
              - Dr Seuss
              • i4004
                • Oct 2006
                • 2029
                #47
                well, because you told him he shouldn't be deriving 7v from 12v andn 5v rails, doofus.
                some discussion here
                http://hardforum.com/showthread.php?t=719830
                but i still say he needs to think about modding only AFTER he changes the caps.
                untill then we can run in circles ("what would happen if?") untill world ends.
                it's not important how did it act with old caps.
                btw. goodpsu, did you order the caps that are in the fan speed control circuit?
                if there are any there.
                btw. if you're gonan do this often, esr meter would be handy.
                this way you're just guessing what's ok, what not, what needs to be changed etc.
                let me guess, no money for that?
                <wink>
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  #48
                  I agree.
                  There is one. I am not gonna change that cap. The fan controller is working, no doupt for that. I just would like to add some speed at the fan. For example if it was made to run as it runs + 300rpms it could be great... Anyway...
                  <wink>
                  What types are available, at what prices and brands?
                  I just recapped and repaired an old linkworld 250watt just for fun, putting in place of bulging caps, some good ones I have taken out from macron power (another thread, another story :P ), so it might be useful.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Trace and draw out the fan controller circuit.
                    Odds are by changing some resistor you can change it's operating point.
                    - Dr Seuss
                    • goodpsusearch
                      • Oct 2009
                      • 2850
                      • Greece
                      #50
                      I just noticed that the 2 bulging caps I removed from antec +5vsb are different type!
                      1xFuhjyyu 1000uF 10V TMR
                      1XFuhjyyu 1000uF 10V TM
                      just out of curiosity what is the exact difference?
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Is the same type actually. -> TM
                        I dunno what the R is.
                        Sometimes it's there, sometimes not.
                        - Dr Seuss
                        • i4004
                          • Oct 2006
                          • 2029
                          #52
                          i think best deal is esr micro.......old version:
                          http://preher-tech.com/esrmicro.aspx
                          contact mike about pricing..should be about 60$
                          that is still cheapest assembled esr meter with capacitance measuring one can find.
                          people seem to be satisfied
                          https://www.badcaps.net/forum/showth...4&page=4&pp=20
                          there are 2 versions now (3.1 and 4.0) and i like some elements of both, so i'm thinking about getting both for 100$...heh...
                          assembled "esr blue" (one piece, not 2) is 110$ and can't measure capacitance...
                          • goodpsusearch
                            • Oct 2009
                            • 2850
                            • Greece
                            #53
                            Recap complete and successful. My pc is now running with antec truepower 2.0 380.
                            List of caps changed:
                            1x10uF 50V Fuhjyyu --> 1x10uF 50V rubycon YXF
                            1x1uF 50V Koshin --> 1x1uF 50V rubycon YXF
                            1x22uF 16V Fuhjyyu --> 1x22uF 25V Panasonic FC
                            1x22uF 50V Koshin --> 1x22uF 50V rubycon YXF
                            1x100uF 25V Fuhjyyu --> 1x100uF 25V rubycon YXF
                            2x1000uF 10V bulged Fuhjyyu --> 2x1000uF 10V Panasonic FM
                            1x220uF 16V Koshin --> 1x220uF 16V rubycon YXF
                            1x470uF 25V Fuhjyyu --> 1x470uF 25V Panasonic FM
                            2x3300uF 16V Fuhjyyu --> 2x3300uF 16V Panasonic FM
                            4x4700uF 10V Fuhjyyu --> 4x3300uF 6.3V Panasonic FK
                            not replaced caps:
                            1x220uF 400VDC Hitachi HP2
                            fan controller board: 1x16V CB06 Fuhjyyu
                            Voltages are in specs but the psu still runs hot...
                            Now running idle with pc case open, fan runs at 1000rpm, 5.10V
                            When running 3DMark05, it runs at ~1120, ~5.7V, case open too.
                            • i4004
                              • Oct 2006
                              • 2029
                              #54
                              i was measuring some temps last nite: 50°c and you already can't hold your finger on it for more than a second or two..
                              40 and over is also not pleasant to touch for longer periods...
                              so you should move away from this perception that electronics must be luke-warm to the touch to be called ok.
                              OR you can show us the circuit that regulates the fan, and then we'll tell you to check that cap too with esr meter, and replace if faulty.
                              <wink>
                              input 400v hitachi you can leave alone.
                              oh yeah, could you say the price (with shipping, perhaps customs etc.) for the caps you got for this psu?
                              • goodpsusearch
                                • Oct 2009
                                • 2850
                                • Greece
                                #55
                                Can't tell the exact price, because they were ordered together with the replacement caps for macron power psu (see my other thread).
                                All together: 60.78Euros, including 8 euros for postal service..
                                They came at 2 packets, because some were out of stock. How stupid to send them separately.
                                Tomorrow I will try to mod the fan controller with the help of the tech guy from the university.
                                • i4004
                                  • Oct 2006
                                  • 2029
                                  #56
                                  you're aware that (for example) about 30eur will buy you decent fortron psu of 350 or 400w, with caps (and cooling) that should have no issues lasting 5-10 years, right?
                                  oh yeah, good luck with the fan mod.
                                  tell us how it went.
                                  • 370forlife
                                    Large Marge
                                    • Aug 2008
                                    • 3113
                                    When JG reviewed the 550W True Power II it too had a problem with heat:
                                    I did find out that the thermal protection is in fact set to 50°C because after half an hour in the hot box during test 6, the PSU shut off. I knew it was thermal protection because I couldn't turn the PSU back on with just a simple hand held PSU tester. I pulled the unit out of the case and it was actually so hot that I couldn't hold it in my hand. I set it down on the floor and let it cool down, and not until half an hour later did the PSU come back to life.
                                    This brings up another concern. Channel Well built Antec's typically use Fuhjyyu capacitors on the secondary side. If there's anything Fuhjyyu caps don't like, it's heat. Given the high temps of this unit, one has to question the longevity of the unit. I'd hate to taint a review with speculation, but it's not as if stories of long term failure are nonexistent on the web.
                                    Probably just antec's try to make it as silent as possible by turning down the fan way too far.
                                    • i4004
                                      • Oct 2006
                                      • 2029
                                      #58
                                      50° measured where?
                                      if it's on cooler surface it's nothing.
                                      if it's air outlet it's something.
                                      • 370forlife
                                        Large Marge
                                        • Aug 2008
                                        • 3113
                                        Yup the output temp of the psu.
                                        • goodpsusearch
                                          • Oct 2009
                                          • 2850
                                          • Greece
                                          #60
                                          We had no luck modding the fan controller. We added resistors in parallel with the thermal sensors but no change was observed. When added a very small one, the psu did not start at all (overheat protection was enabled).
                                          After many tries, I decided just do the 7V mod, as seen in photo.
                                          Recap photos also available...
                                          Volts measured when connected to my main pc, athlon XP 2200+ 1GB DDR 600MHZ, ATI 4650 AGP, 2xIDE 7200 and 2xDVDROM/RW:
                                          V-------------------------Idle---------------3DMark05
                                          5vsb--PCoff:5.06-5.08-5.03-5.05--------5.03-5.05
                                          12V----------------------12.16-12.18-----12.14-12.16
                                          12VB*-------------------12.21-12.23-----12.21-12.24
                                          5V------------------------5.06-5.09--------5.06-5.08
                                          3.3V---------------------3.35-3.37--------3.35-3.36
                                          *mobo connector
                                          One last concern I have about this power supply is that its voltage outputs are constantly going up and down, at very small steps of course, but I have seen more stable outputs in psus..
                                          For example, the +5V line (when pc idle) goes like this at my cheap polymeter lcd screen: 5.06 -> 5.08 -> 5.09 -> 5.06 -> 5.07 -> 5.09 -> 5.06 -> 5.09 -> 5.07 -> 5.08 -> 5.09 etc
                                          Values change in less than a second.
                                          Is it due to the active pfc maybe? Is it safe and good?
                                          I really need to finish working on that antec...
                                          • sirpsychol
                                            Antec Earthwatts EA-380 smd element type/value
                                            by sirpsychol
                                            While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
                                            09-03-2023, 07:58 PM
                                          • ajdrenter
                                            Picking caps for Antec SU-380
                                            by ajdrenter
                                            In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                                            https://www.badcaps.net/forum/showthread.php?t=14159
                                            It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                                            05-13-2023, 10:40 AM
                                          • s_henya
                                            Antec VP-600P and NE550M dead
                                            by s_henya
                                            Got in these 2 nice PSUs, both died after power surge.
                                            Both seems to be suffering from the same fault.
                                            Blown main fuse
                                            Shorted N mosfet 550v
                                            VP-600P: 5R280CE short between GDS
                                            NE550M: MDF18N50 short between GDS
                                            In terns of board layout these seems pretty identical.
                                            From past knowledge, once gate get shorted, most likely the for the driver to go bad as well.
                                            I never tried to salvage blown fuse PSU with shorted Mosfet due to that.
                                            Is it worth to try and replace the mosfets? is there a chance that the...
                                            12-03-2024, 10:00 PM
                                          • CWEastwood
                                            Antec Smart Power SL300S capacitor replacement.
                                            by CWEastwood
                                            I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                                            The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                                            I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                                            Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                                            03-25-2023, 12:18 PM
                                          • RUllER
                                            chemicon produced by fuhjyyu
                                            by RUllER
                                            This is not a fake Chemicon, it is genuine
                                            Many companies are outsourcing to Chinese factories....
                                            01-29-2024, 12:22 AM
