Need Help Idnetifying a Component
  • ShortCircuited
    • Jan 2020
    • 101
    ZDW 38 SOT23. Can't seem to find the pdf for specs
    Re: Need Help Idnetifying a Component
    May be this one: ZD (W = China)
    https://cdn.badcaps-static.com/pdfs/...91a6652c2a.pdf
    Test it to see if it shows as PNP transistor or not.
    • ShortCircuited
      • Jan 2020
      • 101
      Thanks for the reply... The terminals sharing the same side are dead short.
        Can we see the pictures of the board so we may be able to figure out the function of this device?
        • ShortCircuited
          • Jan 2020
          • 101
          On a corsair cx600 powersupply-see arrow (Q10): https://postimg.cc/qgxkNV0D
          • ShortCircuited
            • Jan 2020
            • 101
            Also found 2n4125...but the package and SMD ID book are both wrong. PBSS5350T makes sense but the voltage on the primary side can reach around 350v dc What does the 38 suggest on it...anyone know?
            The two terminals sharing the same side are being provided with .46v and the top pen 0v by the pcb. The main cap is charging to 168vdc
            • R_J
              • Jun 2012
              • 9588
              The 38 is a date code, just because you can get 350v on the primary side does'nt mean that potential is applied to this transistor. The transistor could be used in the feedback circuit or even used as a switch to control whatever is connected to it's collector.
                You can trace out the Collector pin to see if it is connected through other component that ending up connected to the circuit ground or positive power supply then you can tell if it is NPN or PNP Transistor; same tracing for the Emitter pin.
                • ShortCircuited
                  • Jan 2020
                  • 101
                  ZD are the only letters designating this component? W appears to indicate country of manufacture.
                  • redwire
                    • Dec 2010
                    • 3912
                    It could be for low side mosfet gate drive, as the turn off transistor.
                    SMT marking ZDW PBSS5350T PNP 50V 2A(!) low Vce sat. BJT. ZD w-china, 38 as lot/date code.
                    • OniJon
                      Computer Expert
                      • Jun 2012
                      • 82
                      • Finland
                      I'll use the same thread for this question
                        Red rectangular = MICA capacitor
                        Three PBA 3002/6 = 75 Ohms resistors (marked as 2 = 75 Ohms) arrays, you can check the resistance.
                        Four PBRxxxc = Resistor array/network
                        Two Black disc = may be Thermistor, check the resistance when it is cold and when it is heated up with hair dryer.
                        • ShortCircuited
                          • Jan 2020
                          • 101
                          The primary side is not boosting so I dot think the gates are switching. No signs of life...not even stand-by. I have 0 resistance when I probe the PCB G and S traces. Unfortunately, I do not have the knowledge to trace the circuits and determine, but I do have the experience to NOT touch anything even when unplugged and not drained lol. I am thinking 50v PNP..slap one on and wait for smoke.
                          Nearly everything I probe on primary side is 168vdc
                            What did you use for Ground ref for your meter probe when you measure Voltage on the hot side?
                            • OniJon
                              Computer Expert
                              • Jun 2012
                              • 82
                              • Finland
                              Resistor networks/arrays I was aware but had to check, thanks. How do I know mica's capacitance/voltage values because my esr meter goes only down to 1uf reliably? I tried to google the text on top of them with no results.
                              101 should be 100pf but voltage?
                              • redwire
                                • Dec 2010
                                • 3912
                                In OP's CX600 pic I see fractured soldering joints to a through-hole capacitor (at ZD2 pads) that connects to Q10. Did you fix that? Is the +5VSB alive?
                                OMG this is full of CapXon. The little daughter board uses PFC controller CM6800.
                                some CX600 pc board pics:
                                https://www.techpowerup.com/review/c...-cx600m/4.html
                                  MICA caps are low capacitance cap (pF typ.), just check the capacitance with cap meter, you do not use ESR meter on MICA or ceramic cap.
                                  https://technifest.com/technical-doc...pacitor-codes/
                                  • ShortCircuited
                                    • Jan 2020
                                    • 101
                                    Heatsink and neg terminal of main cap as ground*....both provide same result...Tested again and getting .015vdc* today...maybe the weather.
                                    *EDIT: retest gets .41vdc
                                    • ShortCircuited
                                      • Jan 2020
                                      • 101
                                      It must be the image that makes it look cracked at ZD2, no caps near it. SB is not alive.
                                      • redwire
                                        • Dec 2010
                                        • 3912
                                        Check whatever part goes to these two bad joints, and a third could use a touchup.
                                        I think it's a CapXon on the other side.
                                        • Nevillet
                                          Identifying a 'FS45' SOT23 device
                                          by Nevillet
                                          Hi All,
                                          I'm trying to repair a PCB that has some surface mount SOT23 devices that apear to be transistors but testing them on the board are giving confusing results.
                                          Its named FS45 but I can't find a datasheet that seems correct.
                                          The device is used in 10 places on the PCB. In 4 cases they appear to be controling triacs and the attached picture it shows it connected to a BT136 triac with the FS45 connected to the gate leg of the BT136.
                                          Can anyone identify the device and suggest an alternative?
                                          Many thanks.
                                          PS: I have...
                                          06-19-2024, 11:42 AM
                                        • kjchatman
                                          identifying sot23 on backlight cirucuit of 17" razer rz09-0423
                                          by kjchatman
                                          this laptop was damaged by a roof leak at the repair shop that it was at while waiting for a replacement cpu fan. It was given to me to try to save the motherboard which wouldn't power up anymore. The only issue now is that an sot23 marked R1 is missing one of it's three legs. I cannot find schematics for this model but I found a mosfet that has the same label but i'm not sure if it's an actual match. CJ3401 is the one that I found but I have no clue about the true identity of the damaged one.
                                          07-28-2025, 11:47 AM
                                        • eccerr0r
                                          SOT23-5 LiFePO4 protection IC? 13D1S?
                                          by eccerr0r
                                          I have a SOT23-5 marked
                                          "13D1 S"
                                          I wonder if anyone recognizes this IC? It should be a LiFePO4 protection IC, but having problems finding the datasheet, anyone recognize this?
                                          G00gl3 returns a 6-pin LDO which is not quite right...
                                          05-14-2025, 10:41 AM
                                        • dicky96
                                          SMD code ADSH & F1FD sot23-5 identify?
                                          by dicky96
                                          Hi guys
                                          These devices are in some MAG250 IPTV boxes near the power input
                                          I have several faulty ones but they are not all identical
                                          On several I have an SOT23-5 device marked ADSH. Working anti-clockwise from the dot, Pin 2 is ground and pin 6 is 3.3V supply input. Pin 5 is missing of course
                                          On one other I have an SOT23-5 device marked F1HD in the same location but the PCB track layout is different (there are also some extra resistors/capacitors in this area). This one has Pin 1 & 2 ground (I can see they are connected to the same track on the PCB)...
                                          02-15-2022, 07:23 AM
                                        • dicky96
                                          Trying to identify two SOT23 SMD codes, devices from mining PSU
                                          by dicky96
                                          Hi guys
                                          Does anyone know what these two components are?
                                          First one is SOT23 marked LPS 6CB
                                          The other one is SOT23-6 marked S43BbbA
                                          TIA
                                          Richard...
                                          03-06-2023, 05:27 AM
