Re: Task TK-940TX-DF Blowing fuse
Yeah, seems it has no APFC (please tell me it wasn't supposed to have APFC lol)
As for the 384P, yes, you do have to remove it and test for shorts.
Thanks,
Took off the Bridge rectifier - TOK
Then a K2746 - No shorts
Then had to remove the heat sink and there was a shorted K2746 field transistor on the other side of it. (managed to lift a trace - note to self: remember to dont push on soldered components)
Could the bad secondary caps (or is is the Fuhjyyu primarys?) have caused the transisor to short?
Yep, the two primary caps are LP 820uf 200V, which measure 740uf and 750uf, and about 0.05 and 0.03 ohms ESR.Last edited by Dan81; 04-04-2020, 11:17 PM.Leave a comment:
Thanks,
Yep, the two primary caps are LP 820uf 200V, which measure 740uf and 750uf, and about 0.05 and 0.03 ohms ESR.Leave a comment:
Checked the primary transistors and the bridge rectifier?
Also, replace the primary caps ASAP. This is a Andyson unit btw, and I know for a fact that they use Fuhjyyu caps (branded "LP" which is actually the series) which are asking for trouble in Andyson units. (I have one that was killed by them)Leave a comment:
I saved this PSU from a PC that someone threw out
The teapo output caps are bulged
It's got a TL384P chip on the primary side.
Plugged it in, turned it on, it worked for a few minutes, and then the 10A fuse blew (leaving the surrounding area blackened).
Then i put fuse holder in, and a new fuse, and it blew again the instant that i switched the power on.
There is no short from live to earth when it is unpowered, so what could be causing the fuse to blow?
By the looks of it, it's probably not a very good PSU but i wouldn't mind trying to get it working because it has longer power connector wires than my other ones.
Tags: None
by TipsLooking for some assistance please.
Trying to repair a PD27AOQ samsung power board.
Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
Testing it the fuse blows immediately power is turned on.
diodes dm852 and dm853 test as shorted when in the board but fine when removed.
any assistance, guidance would be appreciated. -
by corrizeHello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping... -
by Bootleg1Hi all, so i was watching tv acreen went black and no sound. Traced problem to blown tcon fuse. Replaced and it blows replaced again samething. So my tcon fuse keeps blowing. I bought a new board havent installed yet infear its just going to keep blowing the fuse. If i only connect the right side ribbon cable the fuse doesnt blow but as soon as i connect the left cable my tcon fuse instantly blows and no picture. The right side picture works clear as day and left side picture is grey (picture attatched) im hoping its a bad tcon board itself or a cable or anything and not the panel. Thank you for...
by jshhhHi guys,
I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
Anybody know how to remove this type of fuse?
(The fuse is toward the bottom of the image labeled F2)... -
by stav242Hi,
ive picked up a Samsung UE32F5500AK TV with a BN44-006056A power pcb.
It was reported as `blowing the fuse` - the 3A one in the plug.
on quick inspection of the power pcb, a ceramic capacitor CM802 has blown apart.. photo attached.
Ive found a PDF of the circuit schematic and can identify the neighbouring components (RM801, RM802) but cannot find CM802 on the schematic.
Can anyone identify what CM802 is ?
thanks.
S.... - Loading...
