So I've got a 2000 watt ampeak inverter...when I supply it with 12 volts it powers on as it should and shows how many volts it's receiving...but when I plug something in it's supposed to show home many volts that item is using, but the screen stays at 0 volts and does not power the item at any of the 3 power outlets...Can anyone tell me what would be the cause of this issue?
Inverter is receiving power, but does not supply power to outlets?
Re: Inverter is receiving power, but does not supply power to outlets?
It should say watts? volts on output theoretically should be constant no matter what the load is, until it's overloaded.
so, fuse on secondary?
gfci?
burned output transistors?
so many possibilities...Last edited by eccerr0r; 02-26-2020, 03:54 AM.
by BTubbs200Hello,
Dell Latitude 5420 P137G
Board: LA-K491P REV A01
I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
Board seems to have no shorts, all power rails are fine and show high resistance.
When charger is plugged in, voltage is present in 3.3V rail but absent in others.... -
by u666saLaptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
Platform: ipa32 la-m024p rev 1b
Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
I found a short on the other side:
...10-04-2025, 05:03 PM -
by x_orange90_xI just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
I don't know how exactly to test the inverter itself. Is it... -
by supermattchHi everyone.
I am diagnosing my personal laptop, because it wont power on and no leds light up.
At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.09-23-2025, 12:13 PM -
by MisterAILHi everyone,
Brought a non functionnal PS5. Apparently only a bad PSU...
No beep, nothing.
After some tests i found this :
- PSU is fine (12 volts stable)
- 12 volts line is shorted
- DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
- By the way, nothing change. No signal, no power, no beep.
Mesuring all rails with my workbench psu (12 volts input)
- 0.00 amp drawing
- 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...5 Photos - Loading...
