apc smart-ups voltage problems
    I have a major problem with my rack mountable APC SmartUPS 1400. It's a bit old (at lease 4 years). I'm trying to fix the problem for the last couple of weeks but I had no luck with it. Accorting to apcupsd's apctest the input voltage seems to be over 260VAC even though my V-meter shows 219V so it's on battery power constantly. It even shows the wrong battery voltage (about 50V instead od the correct 24V as it has two dual 12V 7,2Ah sealed accus).
    That could be wrong? Can it be fixed?
    I'm attaching apctest output of a working ups and the non-working one:
    working ups (it's a different model - non-rack mountable) but it's connected to the same input
    UPS Status: 0C
    Line quality: FF
    Reason for last transfer to batteries: L
    Self-Test Status: NO
    Line Voltage: 213.2
    Line Voltage Max: 214.5
    Line Voltage Min: 208.0
    Output Voltage: 240.5
    Batt level percent: 100.0
    Batt voltage: 27.60
    UPS Load: 011.4
    Line freq: 50.00
    Runtime left: 0108
    UPS Internal temp: 030.6
    Dip switch settings: 00
    Register 1: 00
    Register 2: 00
    Register 3: 00
    Sensitivity: M
    Wakeup delay: 000
    Sleep delay: 180
    Low transfer voltage: 196
    High transfer voltage: 253
    Batt charge for return: 00
    Alarm status: 0
    Low battery shutdown level: 02
    UPS Name: UPS_IDEN
    UPS Self test interval: OFF
    UPS manufacture date: 01/17/01
    UPS serial number: gs0103006739
    Date battery replaced: 01/09/09
    Output voltage when on batteries: 230
    Nominal battery voltage: 024
    Percent humidity: NA
    Ambient temperature: NA
    Firmware revision: 70.11.I
    Number of external batteries installed: 000
    Number of bad batteries installed: NA
    UPS model as defined by UPS: KWI
    UPS EPROM capabilities string: uD43132135138129uM43229234239224uA43110112114108uI43253264271280lD43103100097106lM43177172168182lA43090092081085lI43196188208204e44200155090oI43230240220225oD
    13115oJ13100oM13208s441HMLLq44202050710p443020180300600k4410TLNr443000060180300E443336168ON OFF
    The EPROM string is 253 characters long!
    Hours since last self test: NA
    non-working ups:
    UPS Status: 02
    Line quality: 00
    Reason for last transfer to batteries: H
    Line Voltage: 264.9
    Line Voltage Max: 266.4
    Line Voltage Min: 263.5
    Output Voltage: 000.0
    Batt level percent: 018.0
    Batt voltage: 55.89
    UPS Load: 000.0
    Line freq: 49.75
    Runtime left: 1338
    UPS Internal temp: 018.0
    Dip switch settings: NA
    Register 1: 40
    Register 2: 00
    Register 3: 00
    Sensitivity: L
    Wakeup delay: 020
    Sleep delay: 020
    Low transfer voltage: 182
    High transfer voltage: 237
    Alarm status: T
    UPS Name: UPS_IDEN
    UPS Self test interval: 336
    UPS manufacture date: ˙˙˙˙˙˙˙˙
    UPS serial number: ˙˙˙˙˙˙˙˙˙˙˙˙˙˙
    Output voltage when on batteries: 208
    Nominal battery voltage: 048
    Firmware revision: 1?8.3.M
    Number of external batteries installed: 255
    UPS model as defined by UPS: YWM
    UPS EPROM capabilities string: uD43127130133136uA43108110112114uI43253257261265uM43225229233237lD43106103100097lA43092090088086lI43208204200196lM43182178174170e4820015253550607590oD13120oA13100oI43230240220225oM13208s441HMLLq4820205071012151820p483020060120240480720960000k4410TLNr483000020060120240480720960E443336168ON OFF
    The EPROM string is 293 characters long!
    Re: apc smart-ups voltage problems
    Bad interface card?
    Blown µPC chip? Lost EEPROM code?
    Recent lightning storm with near strikes?
    Check this site for more schems.: http://www.upsclub.org/schem/APC
    File: http://www.upsclub.org/schem/APC/schems.txt Is an index and Points to what is where.
    Toast
    veritas odium parit
      Dear NoName
      I have the same problem with my SU1400RM2U UPS. Could you fix the problem?
