apc smart-ups voltage problems
  • NoName
    • Oct 2009
    I have a major problem with my rack mountable APC SmartUPS 1400. It's a bit old (at lease 4 years). I'm trying to fix the problem for the last couple of weeks but I had no luck with it. Accorting to apcupsd's apctest the input voltage seems to be over 260VAC even though my V-meter shows 219V so it's on battery power constantly. It even shows the wrong battery voltage (about 50V instead od the correct 24V as it has two dual 12V 7,2Ah sealed accus).
    That could be wrong? Can it be fixed?
    I'm attaching apctest output of a working ups and the non-working one:
    working ups (it's a different model - non-rack mountable) but it's connected to the same input
    UPS Status: 0C
    Line quality: FF
    Reason for last transfer to batteries: L
    Self-Test Status: NO
    Line Voltage: 213.2
    Line Voltage Max: 214.5
    Line Voltage Min: 208.0
    Output Voltage: 240.5
    Batt level percent: 100.0
    Batt voltage: 27.60
    UPS Load: 011.4
    Line freq: 50.00
    Runtime left: 0108
    UPS Internal temp: 030.6
    Dip switch settings: 00
    Register 1: 00
    Register 2: 00
    Register 3: 00
    Sensitivity: M
    Wakeup delay: 000
    Sleep delay: 180
    Low transfer voltage: 196
    High transfer voltage: 253
    Batt charge for return: 00
    Alarm status: 0
    Low battery shutdown level: 02
    UPS Name: UPS_IDEN
    UPS Self test interval: OFF
    UPS manufacture date: 01/17/01
    UPS serial number: gs0103006739
    Date battery replaced: 01/09/09
    Output voltage when on batteries: 230
    Nominal battery voltage: 024
    Percent humidity: NA
    Ambient temperature: NA
    Firmware revision: 70.11.I
    Number of external batteries installed: 000
    Number of bad batteries installed: NA
    UPS model as defined by UPS: KWI
    UPS EPROM capabilities string: uD43132135138129uM43229234239224uA43110112114108uI43253264271280lD43103100097106lM43177172168182lA43090092081085lI43196188208204e44200155090oI43230240220225oD
    13115oJ13100oM13208s441HMLLq44202050710p443020180300600k4410TLNr443000060180300E443336168ON OFF
    The EPROM string is 253 characters long!
    Hours since last self test: NA
    non-working ups:
    UPS Status: 02
    Line quality: 00
    Reason for last transfer to batteries: H
    Line Voltage: 264.9
    Line Voltage Max: 266.4
    Line Voltage Min: 263.5
    Output Voltage: 000.0
    Batt level percent: 018.0
    Batt voltage: 55.89
    UPS Load: 000.0
    Line freq: 49.75
    Runtime left: 1338
    UPS Internal temp: 018.0
    Dip switch settings: NA
    Register 1: 40
    Register 2: 00
    Register 3: 00
    Sensitivity: L
    Wakeup delay: 020
    Sleep delay: 020
    Low transfer voltage: 182
    High transfer voltage: 237
    Alarm status: T
    UPS Name: UPS_IDEN
    UPS Self test interval: 336
    UPS manufacture date: ˙˙˙˙˙˙˙˙
    UPS serial number: ˙˙˙˙˙˙˙˙˙˙˙˙˙˙
    Output voltage when on batteries: 208
    Nominal battery voltage: 048
    Firmware revision: 1?8.3.M
    Number of external batteries installed: 255
    UPS model as defined by UPS: YWM
    UPS EPROM capabilities string: uD43127130133136uA43108110112114uI43253257261265uM43225229233237lD43106103100097lA43092090088086lI43208204200196lM43182178174170e4820015253550607590oD13120oA13100oI43230240220225oM13208s441HMLLq4820205071012151820p483020060120240480720960000k4410TLNr483000020060120240480720960E443336168ON OFF
    The EPROM string is 293 characters long!
  • Toasty
    • Jul 2007
    • 4171
    Re: apc smart-ups voltage problems
    Bad interface card?
    Blown µPC chip? Lost EEPROM code?
    Recent lightning storm with near strikes?
    Check this site for more schems.: http://www.upsclub.org/schem/APC
    File: http://www.upsclub.org/schem/APC/schems.txt Is an index and Points to what is where.
    Toast
    veritas odium parit
    • Master Beer
      • Aug 2010
      Dear NoName
      I have the same problem with my SU1400RM2U UPS. Could you fix the problem?
      • Fernon@Repair
        Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
        by Fernon@Repair
        i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
        VCCIO voltage ok
        VCCSA Voltage OK
        VCCPLL Voltage OK
        Ram Voltage ok
        RamVTT OK
        VPP 2.5 OK
        But No Core Voltage
        and i want to this vrm ic datasheet or pinout (ISL69269)
        anyone have this ic pinout voltages?...
        06-25-2025, 07:19 AM
        Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
        by sam_sam_sam
        I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
        The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
        Now...
        06-09-2024, 10:57 AM
      • electron_jj
        Panasonic TH-L42D25A checking the PSU output voltage
        by electron_jj
        Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
        I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
        08-29-2021, 08:13 AM
        ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
        3+1 Voltage Regulator for IMVP-7/VR12 CPUs
        Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
        core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
        configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
        serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
        Based on Intersil's Robust Ripple Regulator...
        11-05-2024, 03:24 PM
      • ruletero
        Acer a515-43 low battery charge voltage
        by ruletero
        Hi
        Acer A515-43
        LA-H801P
        Fail: Does not charge battery, has low voltaje on connector.
        Laptop didn't want to turn on, only charge led blinked.
        I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
        I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
        Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
        10-24-2022, 02:31 PM
