Gophert Power Supply and testing led problems
  • tmhobadcap
    • Apr 2019
    • 146
    • CANADA
    Today, I found my led light bulb not working and so I replaced it with a new one. Out of curiosity, I opened the damaged one to see what was inside. I saw a series of 16 leds. I have experience in checking the leds strips for using as backlight in tv. Therefore, I would like to do the same to check which led in the bulb is not working. Initially, I set my bench power supply to 3V and 200mA, and test each led. I found that I needed to raise the voltage to 7V so as to make the led to light up dimly. I found one led did not light up, and I think that one has been damaged. When I went to test the next led or the second next one, it was lighted up very brightly. I thought that one was shorted (but when I tested it with a multimeter, it is not shorted) and so I lowered the current of the power supply to 100mA and test again hoping that this will avoid damage to the power supply . I found that led was still lighted up very brightly. Then I further reduced the current of the power supply to 10mA and test again. I got the same result and the power supply is not working after that.
    My power supply is Gophert CPS-6005. The maximum output voltage is 60V and maximum current is 5A. It should have over voltage and over current protections according to the manual. Was I not using it properly and so it was damaged? Or was it the power supply problem (not providing current protection)?
    Now the power supply output voltage is 0.08V. The setting can change the voltage but after that it will return back to 0.08V. Visually, I cannot see any damaged component. The fuse is also normal. Which component will probably be damaged if I want to fix the power supply?
    • Jul 2011
    • 6025
    Re: Gophert Power Supply and testing led problems
    I personally I do not like computer controlled power supply I find that they have nothing but problems
    I personally prefer the manually set ones
    That being said do you know if you have a short on the output of this power supply
    How you find this out is take a multimeter ( if you have a multimeter ) put the meter leads on the power supply leads and check for a short ( with the meter turn the ohms position) with the power supply unplug from the wall
    If you do have a short in the output you need find where it is coming from
    One note on some these type of power supply they have a TV diode on the output terminals if this power supply has one check this diode first that this diode has not shorted out
    If you can please show a picture of output terminals of this power supply where the power supply wires hook on both ends thanks
    Because I want to see if this is one wire for positive and one for negative or does it have two wires on each terminal
    Because if has two wires on each terminal then it probably has a voltage feedback circuit
      • Jul 2011
      • 6025
      On separate note
      On the LED light that you are working what is ic chip number
      • tmhobadcap
        • Apr 2019
        • 146
        • CANADA
        On separate note
        The markings on the ic chip is EG1000E 8WP3 1749. But I could not find any information from the internet on it.
        • tmhobadcap
          • Apr 2019
          • 146
          • CANADA
          When I put the multimeter leads to the outputs and check for resistance, I can see that the resistance is jumping between 0 and about 50 k ohm.
          Attached please see the photos for your reference.
            • Jul 2011
            • 6025
            β€œ0” ohms really are you sure take your meter if it auto range turn it off and read it again
              • Jul 2011
              • 6025
              The link that I might have found safari will not page because it says that it is not secure page
              • tmhobadcap
                • Apr 2019
                • 146
                • CANADA
                To be more exact, zero ohm just show up about half a second. Most of the time is jumping between 1 k and 5 k ohms.
                • RJARRRPCGP
                  • Jul 2004
                  • 6301
                  Electromechanical, FTW!
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  "Β‘Me encanta "Me Encanta o Enlistarlo con Hilary Farr!" -MΓ­ mismo
                  • rastar77
                    • Sep 2021
                    • 3
                    • australia
                    So i was testing firmware upgrades/fault fix that I made to ksger t12 soldering iron with the power supplied by gophert NPS 1602 at max current limit 3.1A. After some time I noticed 0 current. Now the NPS 1602 has the cc red light on always and constant current limits to 0.0 A.
                    • rastar77
                      • Sep 2021
                      • 3
                      • australia
                      Users of gophert NPS 1602 need to Check the thin output wires and connections!
                      My issue was caused by factory clamping of a few wires on top of the cable insulation. With supply around 3A current the few copper wires burnt out. As for the CC 'on' operator error...
                      • captainKKK
                        • Sep 2018
                        • 287
                        So, back to the LED bulb. I did the same thing and for each bad LED, I just soldered those over and continued until the next burned out and did the same again and nw there are only 4 working. So I soldered two wires and used the bulb as my inverter to light a strip of leds. The wires put out 57vdc but not much power.
                          by sam_sam_sam
                          07-01-2024, 06:34 AM
                        • JimBanville
                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                          by JimBanville
                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                          09-13-2023, 07:21 AM
                        • Gust zhang
                          Mid 2014 A1398 MacBookPro,Is it feasible to remove the battery from the MBP and connect it to an external power supply?
                          by Gust zhang
                          ​I have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
                          02-16-2025, 08:39 AM
                        • madan1
                          555 based power supply getting too hot
                          by madan1
                          Good day.
                          I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
                          The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
                          After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
                          When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
                          06-23-2025, 04:38 PM
