Manson NP-9613
  • bianchi77
    • Jun 2016
    • 1121
    Manson NP-9613
    Dear Members,
    I have an issue with Manson NP-9613,
    Everytime the voltage hit 19V, the relay is switching and voltage is going down,
    What is the issue ?
  • CapLeaker
    Leaking Member
    • 8297
    Re: Manson NP-9613
    We need pics to see what you got!
    Is it hitting a cc cutoff or what are the testing conditions?
    • bianchi77
      • Jun 2016
      • 1121
      Re: Manson NP-9613
      cc cutoff ?
      I got one burn zener diode and replaced it,
      could it be TL431 or relay is broken ?
      • CapLeaker
        Leaking Member
        • 8297
        Re: Manson NP-9613
        looks like there is a bad transistor next where VR8 is written on the board?
        • R_J
          • 9583
          Re: Manson NP-9613
          The transistor next to CN4 also looks bad, compare that transistor to Q7 and you can see Q7 has the spot along the molding line which is normal but the transistor next to it looks like it is damaged at that point
          • bianchi77
            • Jun 2016
            • 1121
            Re: Manson NP-9613
            VR8, which transistor ?
            Do you mean U2 ? that's TL431
            • bianchi77
              • Jun 2016
              • 1121
              Re: Manson NP-9613
              I can spot CN4, but which one is Q7 ?
              I saw it, it's blown isn't ? after zoom ...
              • bianchi77
                • Jun 2016
                • 1121
                Re: Manson NP-9613
                Have a look on photo please, are these, do you guys mean ?
                I'll check, and return to you guys...thanks
                • CapLeaker
                  Leaking Member
                  • 8297
                  Re: Manson NP-9613
                  Right under that cap. You are on the left of it.
                  • bianchi77
                    • Jun 2016
                    • 1121
                    Re: Manson NP-9613
                    I can't get it, the one on the blue box I'd made ?
                    • bianchi77
                      • Jun 2016
                      • 1121
                      Re: Manson NP-9613
                      I've replaced both 2N3904 and TL431, no luck, yet,
                      could it be a relay issue ? thanks
                      • bianchi77
                        • Jun 2016
                        • 1121
                        Re: Manson NP-9613
                        the relay : ,
                        I got 277 ohm on the coil
                        • R_J
                          • 9583
                          Re: Manson NP-9613
                          Is that not Q7 marked on the board? so the transistor next to CN4 beside Q7
                          • bianchi77
                            • Jun 2016
                            • 1121
                            Re: Manson NP-9613
                            I have replaced both on the blue box, no luck yet ?
                            • bianchi77
                              • Jun 2016
                              • 1121
                              Re: Manson NP-9613
                              Could it be this one is the cause ? When I tested ESR=1.5 Ohm Caps = 5400uF, suppose to be 4700uF
                              • bianchi77
                                • Jun 2016
                                • 1121
                                Re: Manson NP-9613
                                or it could be an issue withe op-amp 4558
                                • CapLeaker
                                  Leaking Member
                                  • 8297
                                  Re: Manson NP-9613
                                  I highly doubt that a 4700uf cap measures 5400uF at 1.5 Ohm ESR. Here is something off with your measuring equipment. IF that 4700uF cap really has 1.5 Ohm ESR, then it would be no good and it would have less capacitance, not more. A good large uF value cap should have something like 0.015uF ESR. An opamp could be at fault too, but right now I think a schematic would be nice.
                                  I also think, that you are focused on the relay turning the power off and the relay is not supposed to click. I think that is wrong and the relay is supposed to click, but the PSU is not delivering power for higher voltages. You can go to any of these CV CC PSU's and they will click not only once if you go from Zero Volts to 30V.
                                  Could it be the relay? Yes, we know it clicks, so it does get voltage and the coil is good. So how could it be still bad then? If the contacts inside the relay are burnt off. Take the relay out and test all the contacts on the relay powered up and no power, cording to the spec sheet.
                                  • bianchi77
                                    • Jun 2016
                                    • 1121
                                    Re: Manson NP-9613
                                    I suspect, it's 4558 op amp, I did an experiment with new LM 358, it is doing the same voltage drop...
                                    • R_J
                                      • 9583
                                      Re: Manson NP-9613
                                      Was the transistor and ic shorted? If they were, check the components that connect to them, if they are indeed bad, someting connected to the also is bad
                                      Was the Zener diode you replaced marked on the board ZD2? and connected to the U2 tl431
                                      Was the zener a 5.6v by chance, if it was, is there a resistor marked R19 (750Ω) connected between ZD2 anode and C9 negative?
                                      • bianchi77
                                        • Jun 2016
                                        • 1121
                                        Re: Manson NP-9613
                                        I replaced ZD1 12V 1W....and TL431
                                        • CoinCoin88
                                          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                          by CoinCoin88
                                          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                          09-15-2025, 03:36 AM
                                        • DodgyTech
                                          60" LG 60PB690V relay clicking issue
                                          by DodgyTech
                                          I require some help with my TV. The TV standby light blicks on and off with a clicking sound (relay?) from the back. After I opened up the TV, I set about troubleshooting by unplugging the boards to try and isolate the problem. My troubleshooting suggests that the logic board is causing the issue, but it could entirely be the YSUS board which is only activated once the logic board is connected.
                                          I have recorded a video which I thought would be an easier way to explain the problem and show the boards at the same time.
                                          I would like to try and identify...
                                          07-07-2023, 10:30 AM
                                        • CuriousJohn
                                          Burco boiler power problem
                                          by CuriousJohn
                                          Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
                                          Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
                                          This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
                                          12-22-2024, 10:25 AM
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          🛠 Original Issue
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • ugamazing
                                          by ugamazing
                                          12-17-2024, 07:05 PM
