Raidmax RX-600 ringing noise and 0ms PG
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. A former workmate of mine scrounged up this PSU from a client of us. He had a look at it and found a seized up fan which is presumably the main cause of failure. A couple of caps had bulged on the secondary, so it seemed like an easy fix. He replaced them and today I had the honor of doing the test run with him. We attached an ATX tester to its output and plugged it in: it's not quite there yet. While the supply did technically fire up with no pops or fireworks, it's got a couple of issues. The most prominent one is this "ringing" or rather crackling sound it's making (sound, just like scent, is one of the toughest things to explain in words sadly ). It's pretty loud and we were afraid something might actually pop. We decided to keep it plugged in anyway, at least to check up on our tester. Ironically, all the rails are up and in spec (no way to check ripple on them though), but then we ran into the second issue: 0ms on PG....the bane of my existence, since to this day I cannot work out a definite answer as to why some ATX supplies do this !
    There's only two chips on this thing: the combined PFC/PWM IC (a CM6805)and the supervisor IC on the secondary, a ST9S313 for which I'm having trouble finding a datasheet....
    First, the squealing is the more concerning issue, so I thought I should focus on it first...what could be causing this ? There could still be a bad cap somewhere, as my colleague only replaced the visibly damaged ones...might be a good idea to recap the whole thing (not sure if it's worth saving though - looks decent and fixable enough). What else could get damaged to cause this noise ? The noise is only present when the supply is "on", so it's not caused by the 5VSB circuit. Haven't tried loading the supply yet to see how or IF the noise is affected in any way. Most likely caused by the main transformer.
    The 0ms PG issue: bad supervisor IC ? Perhaps other similar cases you might've come across ? Cheers guys.
    Wattevah...
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Raidmax RX-600 ringing noise and 0ms PG
    If the fan had failed and unit overheated, replace ALL the caps, regardless of size. This being an APFC PSU, probably also a good idea to replace the main cap too. I see it's a cheapo brand anyways, so it's unlikely to last. In fact, that could well be the cause of your noise. Bad cap on the APFC can also destroy the PSU in seconds with a bigger load. That said, if you do replace the main cap, go with a 450V one. And maybe something bigger in capacity too. Just look at all that space that the manufacturer left there on the PCB for it, but didn't end up using probably because they went ultra-cheap and grabbed an undersized cap for the job.
    As for the 0ms Power Good issue... I've seen that only on cheapo PSUs and I don't know what causes it or how to fix it. But if it's not an issue with whatever motherboard you're trying to run, then let it be. Alternatively, you could try adding an RC low pass network between IC PG output and PG lead to sort of create an artificial delay. But some motherboards may not like the fairly slow "deadzone" between high and low on PG when it's implemented with a simple method like that. Either way, I wouldn't worry much about it. And also I don't trust those PSU "testers". They really are rather pointless. I'd rather connect the PSU to an old useless Pentium 4 motherboard or something similar and test it that way.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      Good idea. Will try that. Doesn't show any signs of bulging, but then again time has proven that caps can fail even without showing any signs. Would be funny if that also fixes the 0ms PG issue
      Will need to do a bit more digging around that IC. See what that PG pin actually reads. Given that the tester shows 0ms, I'm expecting the PG pin to be "stuck on" and come on immediately as the rest of the rails, because if it didn't come on at all, the tester should show "HH" (aka "too high" a delay). The IC is probably sinking the pin (keeping it LOW) until it decides its time to "release" it, at which point it goes back up via a pull-up resistor off the 5v rail...at least that's how I imagine it based on other schematics I've seen. THIS ONE uses that same chip. Notice how R69 is tied to the 5v rail. Most MOBOs refuse to turn on with a 0ms signal, and I've messed around with quite a few at my former shop, that's why I'm trying to fix that as well.
      Wattevah...
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Yup, that's how it works indeed.
        Bad comes to worse, it shouldn't be too hard to build your own delay circuit. Something like an RC circuit and an amplifier or shunt circuit to trigger past a certain level should do.
        • R_J
          • 9625
          The ST9S313-DAG seems similar to the HY510N
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            That IC might be hard to source unfortunately and might end up costing more than the supply is worth, though I haven't looked it up on good ol' AliExpress so far....
            Designing my own delay circuit: since the delay has to be rather short (a couple of ms at most, according to ATX specs) I think it can be done with an R/C combo, with that TAU equation I always find funny for some reason Trouble is I think I'd need some hysteresis there as well, since in an R/C circuit the voltage SLOWLY increases, so the MOBO might not like a SLOW rising signal like that - it might expect something that "snaps" *bang* like that to 3.3v. If it doesn't, then even better: botch a resistor+cap there, otherwise the quickest and dirtiest thing that comes to my mind at this late hour, as I'm lying in bed wondering WTH I'm doing with my life is an op-amp with a fixed reference voltage of around 3v its Inverting pin and the R/C setup on its N/I pin. As the voltage on the R/C circuit SLOWLY increases, the output of the op-amp stays low because I is higher than N/I at this point. As soon as it hits that sweet spot, the output swings positive and that's our PG signal....again, just a scenario.
            Wattevah...
            • Dan81
              SNES-powered
              • Oct 2013
              • 1866
              • Romania
              Just checked AliExpress for you, and they have 8964 lots, so you're in luck.
              As for the main cap, replace it as soon as possible. I have a Andyson here (Hiper 525W) that was killed by the main caps, and I just gave up with it because the 3842 was killed by them, along with the primary switchers, the WHOLE APFC board, and a boatload of the caps on the secondary. I don't have any replacement chips, and the wiring was as basic as it could get - 24 pin, 1x 8pin EPS, 2x molex, 1x SATA, and one floppy connector.
              Main rig:
              Gigabyte B75M-D3H
              Core i5-3470 3.60GHz
              16GB DDR3-1600
              Samsung SH-224AB DVD-RW
              Delux MG760 case
              • R_J
                • 9625
                What about a Texas Instruments TPS3510, might be easier to get. Or maybe a FAN7680
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  • Romania
                  8964 ? I searched for the other two types of chip (original and compatible) and found both for dirt-cheap, so I might push on with this repair. I asked my buddy to get me a 180uF 450 volter as well, so we should be good
                  Wattevah...
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    I see you've edited the post. Yeah, one of those two might be easier to source locally. Need to do some measurements first to see what actually IS there. Like I said, I'm expecting PGO to be stuck on for some reason.
                    Wattevah...
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      • Romania
                      I managed to scrounge up a 220uF 450v cap instead of the original 180uF....hope it's not TOO much It also reads 213uF on a cap meter, which I think is within tolerance, especially at such a high voltage.
                      Wattevah...
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5091
                        • New Zealand
                        Will be interesting to see if the capacitor is the problem.
                        I posted about a PSU on here once, where I heard a strange faint arcing/sizzling/crackling sound that I tracked down only to the APFC section but could not further discover its source. I had suspected the PFC coil, but could not see any corona in darkness.
                        I was advised it was likely the primary filter capacitor going shorted internally.
                        -David VanHorn
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          • Romania
                          Yup, one day I'll get around to replacing that cap and I'll be sure to update the thread. The supply is still belly-up at my old shop waiting for me, I just have to find some time to go there for a chin-wag with my former mates. This weekend would be nice hopefully.
                          The cap I found will require some work because it's got two flat metal blades for leads which are unlikely to match the holes for the existing cap, so I'll have to convince them a little
                          Wattevah...
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5091
                            • New Zealand
                            It may be easier to drill new holes in the board?
                            -David VanHorn
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              Or if you have enough space above the cap... 14-AWG solid copper wire for leads anyone?
                              ^ Picture of my modded and recapped Antec Earthwatts EA-500
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                • Romania
                                The cap already has some leads soldered to its "ox horns" so with a bit of luck, I'll be able to bend those into shape.
                                But damn - 500uF ? :O
                                Wattevah...
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8710
                                  The PG problem reminds me of one cheapo PSU that I repaired many years ago. Turned out a ceramic disc cap shorted out, and tricked the PG to always be no good. So much for annoying debug efforts! At least that PSU was easier to debug since it had no shoe horned daughter boards...
                                  • Dannyx
                                    CertifiedAxhole
                                    • Aug 2016
                                    • 3912
                                    • Romania
                                    Was that cap on the PG "wire" directly or somewhere around the supervisor chip which sends out the PG signal ? Sucks it's all SMDs in this one
                                    Wattevah...
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8710
                                      It was near the op amp on the PSU... So I guess supervisor chip on yours. Yeah SMD sucks, double sided SMD sucks more, and double sided daughter boards with SMD is worst.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        That's all I had on hand. Well, four of them, actually - came out of some industrial A/C board along with a few other goodies. The board was smashed to pieces in several places, but the caps were OK. Knowing how much one of these caps costs, I immediately snatched it when I saw it in the dumpster.
                                        Eh. At this point, I don't mind SMD that much. But double-sided PCBs for PSUs, I don't like to work on - becomes hard to trace things and especially hard to remove stuff if it's double-sided with SMD, like you said. This is one thing I do like about cheapo and old PSUs - easy to work on.
                                        • GraphicMan
                                          Pioneer A-205 faint noise/hiss issue
                                          by GraphicMan
                                          as the title says, i noticed a faint noise/hiss when there is nothing playing that i dont think i have had with this unit before ever, i have not changed its location
                                          what makes it more weird, this noise is gone almost completely if my hand gets within 5cm or less close to it (close to the panel)!!
                                          out of curiosity what does that mean?
                                          thanks
                                          05-19-2024, 11:45 AM
                                          Modification done to a EBC-A40L 5volts Battery Capacity Tester 40A for less noise when charging / discharging cycles
                                          by sam_sam_sam
                                          When I first turned this battery testing machine the fan for the switching power supply was a little bit noisy but once I recapped the switching power supply board it quiet down considerably then I put a temperature controlled fan that does the mosfets control board was really noisy but now that it is cooled with temperature controlled fan that sensor was moved from the fan to the heat sink so now that the fan is controlled this way the fan runs according to the temperature of the heat sink
                                          This switching power supply was really fun to recap the quality of the board was very good...
                                          02-25-2024, 08:55 PM
                                        • tony359
                                          by tony359
                                          11-28-2023, 05:18 AM
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          🛠 Original Issue
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • ugamazing
                                          by ugamazing
                                          12-17-2024, 07:05 PM
