Antec EarthWatts EA-430 and EA-500 – an easy bad caps fix
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    A while back, I found a faulty EA-500 on eBay for cheap (starting bid at $0.99), and I thought it would be another fun PSU fixing project. I ended up winning the auction for $3 (not counting the $11.50 for the shipping). So, here is a post about it.
    I have to say, sometimes eBay really surprises me with the deals one can find there. My EA-500 came complete with absolutely everything: that is, a box in very good condition, one power cable, an owners manual, and even the complimentary bag of screws. Here are the pictures, if you don't believe me:
    https://www.badcaps.net/forum/attach...1&d=1509061896
    Clearly this eBay seller cared about his/her computer stuff, as everything is in immaculate condition.
    Likewise, the PSU itself was just as clean.
    All output wires are 18 AWG, 300V.
    But looks can be deceiving! Without even tearing it open, it was easy to spot this:
    Perhaps not so obvious on this picture, but right there I was able to see a bad cap. And that shouldn't be surprising - turns out bad caps are quite common for these PSUs. Actually, there are plenty of examples here on badcaps.net as well. For instance, below are two posts made by everell, where he shows the same EA-500 model as mine.
    https://www.badcaps.net/forum/showpo...14&postcount=7
    https://www.badcaps.net/forum/showpo...15&postcount=8
    What I find even more interesting is that his has bulged caps in the same exact spots as mine, and same brand and series too: OST RLX and RLS. The smaller brother of this PSU, the EA-430, also has the same layout and caps, thus the same problems. So this is going to be more or less another recapping thread for the Antec EA-430 and EA-500 models (and possibly EA-380 too?)
    Before I open it, let's have a look at the label.
    Nice and consistent labeling that looks just like on the review websites.
    And now we dig in…
    https://www.badcaps.net/forum/attach...1&d=1509062129
    … revealing another bulged cap. Other than that, I really like what I am seeing – nice open design with plenty of space for airflow, especially on the primary side. The secondary is a bit cramped, but not that bad and nowhere near as horrible as the Aspire PSU I posted about not too long ago.
    Here is a different angle to give an idea about the size of the components:
    Looks like the bad cap we saw through the front grille is filter output for the 5VSB circuit. No wonder the seller stated in the auction that the PSU is dead. At least this PSU has a ICE2A0565z PWM-FET offline IC for the 5VSB, which is good. What's not so good-looking is the hack job with that small cap soldered directly to the opto-coupler top-side pins. But it works, so I'm not worried. It just looks... eh…
    Next, we observe the primary side:
    PFC silicone consists of two PV218N50 MOSFETs, a STTH8506d diode, and a 1N5406 bypass diode. The main PS section is double-forward, again with two PV218N50 MOSFETs. Main transformer has a 35 mm core and the 5VSB a 19 mm one.
    Moving onto the secondary side:
    We see an exclusive OST-only party. And it looks like some of these “party-goers” had little more than a few drinks, as they are looking a bit “puffy”.
    Specifically, the 12V rail cap (OST RLX 16V, 3300 uF, 12.5 mm dia.) on the left is bulging, as is the skinny 8 mm OST RLS behind it (which is for the -12V rail.)
    It is interesting to note that this PSU also has a design from 2005, just like the Aspire I posted. BUT! Notice how much cleaner this PSU is. Clearly YoungYear has a long way to go before it catches up to the quality of Seasonic here (if they are even still making PSUs). Speaking of designs, this is Seasonic's S12II platform. PCB is labeled: ATX400W PCB rev 5.
    Another short of the secondary, showing something that I don't like:
    That little TO-92 transistor with the scorched PCB around it is the drive transistor of the linear fan controller. It is a _______ transistor. Clearly, it is undersized for the 250 mA that the fan is rated for. Did that contribute to cooking these caps? I don't know, but I sure don't like it. In the picture you can also see the fan connector pulled out. I had some trouble disengaging that locking connector. What's worse: as I tried pushing the connector back in, I ended lifting up the traces on the solder side of the PCB. Lame!
    Speaking of which, let's have a look at the solder side:
    It looks pretty good, except for the few hand-soldered blobs (mostly on the primary side.) Also, some of the component leads were not cut very well and protruded a bit more than I like to see. I actually managed to pierce the skin on my hand quite a few times because of that. But it wasn't as bad as the CWT-built Corsair CX750M and Thermaltake M850W PSUs I posted here – those actually make me want to cry every time I think about doing anything to them.
    Sharp eyes may have also noticed in the last picture above where I lifted the traces for the fan connector. Nothing got ripped out, though, so no major damage.
    While on the topic of PCBs, here is the receptacle filter board;
    And last but not least, I want to make a note of the plastic insulation sheets used in this power supply: they seem to be quite sensitive to heat and easily get darkened. Once that happens, they also become quite brittle. Here is a picture of the one under the PSU's PCB:
    Mmmm. Nice and crispy on the upper left corner. Coincidentally, this is where the fan controller's drive transistor is. Who would've thought.
    On that note, I forgot to take a picture of the fan, but it is just an-ADDA (get it? ) AD0812HS-A70GL, rated for 12V and 250 mA.
    Anyways, let's have the detailed component breakdown now:
    Primary Side Summary:
    - Four 2.2 nF Y2-class certified caps
    - Two Carli X2-class certified caps (0.22 uF + 0.47 uF)
    - three common-mode chokes
    - GBU806 bridge rectifier (8 Amps @ Tc = 100°C, 600 V reverse voltage)
    - PFC section: 1 uF 450V film cap after bridge rect., two PV218N50 MOSFETs, one STTH8506d diode, one 1N5406 diode
    - Main filter cap: one Hitachi HP3, 400V, 330 uF, 30 x 40 mm (dia. x h)
    - Main PS topology/design: double-forward with two ., two PV218N50 MOSFETs
    - Transformers: main with 35 mm core and 5VSB with 19 mm core
    - Input wire: 16 AWG, 300V for Live/Neutral and 18 AWG, 600V for ground
    ICs
    - CM6800 chip for PWM+PFC function
    - ICE2A0565z off-line SMPS IC for 5VSB generation
    - HY-510N supervisor IC on the secondary side (OVP on 3.3V, 5V, and 12V; UVP on 3.3V and 5V)
    - three NEC 2561 optocouplers
    - two 431 reference shunts
    Secondary Side Summary:
    3.3 V rail:
    - mag-amp regulated
    - ST STPS30L30CT (30 Amp, 30V, TO-220) schottky rectifier
    - 1x OST RLX, 10V, 2200 uF, 10 x 20 mm before PI coil
    - 1x OST RLS, 10V, 1000 uF, 8 x 20 mm after PI coil
    - PI coil: 4-turn, 4 mm core, 14 or 16 AWG
    - load resistor: 100-Ohm SMD (3015m)
    5 V rail:
    - load resistor: 220-Ohm SMD (3015m)
    12 V rail:
    - SBR30A50CT (30 Amp, 50V, TO-220) schottky rectifier
    - 1x OST RLX, 16V, 3300 uF, 12.5 x 25 mm before PI coils
    - 2x OST RLS, 16V, 1000 uF, 8 x 20 mm after each PI coil (2 coils for “2” rails)
    - PI coils: two 5-turn, 4 mm core, 14 or 16 AWG
    - load resistor: 560-Ohm SMD (3015m)
    -12 V rail:
    - derived from output inductor winding, not main transformer
    - 1.5 or 2 Amp (?) diode
    - 1x OST RLS, 16V, 1000 uF, 8 x 20 mm before PI coil
    - 1x OST RLS, 16V, 220 uF, 6.3 x 11 mm after PI coil
    5 VSB rail:
    - SB340(?) schottky rectifier
    - 1x OST RLX, 10V, 3300 uF, 10 x 25 mm before PI coil
    And that is all I have for now. I'll post more pics with the fresh caps when I get to recap this PSU more properly. Right now, I have it recapped temporarily just for testing, and it's working well. The EarthWatts EA-430 that I have also likely needs new caps. Don't know for sure, as I haven't opened it yet. Poor guy is still sitting in a box in the garage since I bought it, which was almost a year ago.
    Anyways, these are good PSUs well worth saving.
  • mockingbird
    • Dec 2008
    • 5488
    Re: Antec EarthWatts EA-430 and EA-500 – an easy bad caps fix
    So Antec decided to take the S12 II 500, put in Chinese caps (You're absolutely right about it being an S12 II, proof), and then use their name to charge more for it.
    I found an EA-500D in an old curb PC years ago. Still going strong, though I did preemptively replace the few Taicons in it.
    Good post.
      • 31283
      what the hell is Q901 doing that managed to cook the pcb with just a TO92 package??
      • Behemot
        • 4845
        • CZ
        I think they actually just had it made with the OEM variant of the board. Seasonic uses these ultra-low ESR (motherboard grade) OSTors even today, in the OEM models.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Antec EarthWatts EA-500 – temporary recap and fan controller fix v1
          It's an H8050 NPN transistor for the fan controller, and it drops down the voltage to the fan in a linear fashion. That said, at about 20°C room temperature, the fan is fed about 4.20 Volts from the fan controller. It spins quietly, but pushes enough air. The problem is that the voltage drop across Q901 is then 12V - 4.20V = 7.8V minimum. I'm not sure how much current the fan draws at 4.2V, but it's probably around 100 mA, given that it is rated for 250 mA. At that current, Q901 would be dissipating about 0.78 Watts. It doesn't seem like much, but for a TO-92 transistor it is quite high. H8050 is rated for 1 Watt dissipation @ Ta = 25°C. As the fan controller increases the voltage to the fan with increasing temperature, the voltage across Q901 drops. However, the fan starts to draw more current. So I wouldn't be surprised if at higher voltages, that transistor is pushed right to its limit.
          I found a similar scenario recently in an old FPS power supply (FSP400-60PFN): same transistor and the fan was rated for 240 mA. When cold, the fan was driven with about 6.5V and drawing about 18 mA. Thus, the little transistor in that PSU was dissipating about 0.99 Watts - right at the edge of the allowable Pd in the datasheet! And of course, that transistor had a burned PCB all around it too. I'll post about that PSU another day... but yeah, this is quite common.
          As such here is my temporary/partial solution to the hot transistor in the Antec EA-500:
          https://www.badcaps.net/forum/attach...1&d=1509126932
          Basically, I added a little SOT-23 diode (look at the bottom right corner of the picture, the go slightly up, and you will see a SOT-23 device with one leg floating on the PCB) connected with its Anode to the 5V rail, and the Cathode connected to the fan output. This makes the fan receive about 4.5-4.6V after the voltage drop from the diode. As such, Q901 has to pass less current to the fan, and thus heats up a little less. It doesn't really make a difference when the fan controller increases the voltage going to the fan, but at least when the PSU is cold, Q901 can take a little break. Also, if Q901 fails open-circuit, the fan would continue to spin, as it will be supplied with power from the 5V rail.
          And below is also a picture of what I did to (hopefully) dissipate the heat from the transistor a little better.
          Basically, made a heatsink made from steel sheet. It's probably not a very efficient heatsink, as steel sheet is a rather poor heat conductor compared to Aluminum, Copper, Brass, and Silver... but better than nothing, I figure. I also soldered a copper wire to the back of the steel sheet to help draw the heat away from the transistor and move it to the top of the steel sheet "fins".
          Here is a picture of this heatsink hack/mess installed in the PSU:
          I'll probably replace that whole transistor in the future with something beefier and maybe mount it on the secondary heatsink as well. But for now, this is passable.
          In the above picture, you can also see my temporary recap that I did to test the PSU. Basically, I replaced the bulging OST RLX 16V/3300u cap on the 12V rail with an old Chemicon LXZ 16V/2200u. Clearly, it's not quite a match in terms of ESR nor capacitance... but it beats a bulged OST any day.
          The cap to the left of it is an Elite ED series (25V/470u), pulled from a monitor that I recapped just in case. So the cap has healthy ESR and capacitance. I used it in place of the bulging OST RLS 16V/1000u cap that was filtering the -12V rail. Although the PCB is silk-screened for a 8 mm can, the lead-spacing is for a 10 mm cap (5 mm LS). So I figured if a 10 mm cap fits, I'll use that and not have to bend leads on an 8 mm cap to make it fit.
          Finally, and not visible in this picture - I replaced the bulging OST RLX 10V/3300u cap on the 5VSB output with a Nichicon HN 6.3V/2200u cap. Should be more than enough to keep the 5VSB circuit happy. Works fine as far as I can tell.
          With this arrangement, I even used the PSU to test an AMD Phenom X4 PC with a Radeon R9 290 GPU. I couldn't fully stress-test the R9 290 as it was faulty and kept crashing with artifacts... but that system drew up to 150 Watts from the wall and this PSU managed it fine. So I will properly recap it, as I said. I already have the caps for it too. Just have a few more projects I have to finish before it.
          • Behemot
            • 4845
            • CZ
            Maybe using larger transistor would be easier? There are the "long" TO-92, not sure what the marking is now.
              • 31283
              just pull it and put a link across the pads.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                It would have, but I was too lazy to get up and get out my box of spare transistors. Whereas the steel sheet and scrap copper wire was already right on my bench. Took me all of 5 minutes to cut, bend, and solder that contraption.
                But yes, the plan of attack is that when I open this PSU up again for a proper recap, I will also likely replace that transistor with a bigger one. I have quite a few scrap CRT TV boards here, so I do know I have spare transistors that will work.
                TO-92L, I think.
                Meh. between TO-92 and TO-92L, there isn't much difference. The surface area is still way too small for 1W of dissipation. TO-126 and TO-220 will handle 1W without overheating as much, though without a heatsink, they will still run very hot.
                And make the fan sound like a jet turbine?
                No thanks.
                I have plenty of PSUs that have been in service for over 10 years with their fan-controlled fans. There's nothing wrong with a fan controller. Moreover, besides the reduction in noise, you also get less dust inside the PSU. And the fan lasts much longer.
                That said, this PSU has an Adda fan. If I connect it straight to 12V, it will probably be a matter of months to a year at best, before it seizes completely.
                So no thanks, I'll never remove a fan controller or suggest anyone to do it. Running the fans full-max on 12V was acceptable for an 80's computer with a loud BB HDD. Today? -No way!
                • Stefan Payne
                  • 1267
                  Re: Antec EarthWatts EA-500 – temporary recap and fan controller fix v1
                  Naa, it's way way less than that. Try measuring it - you'd be surprised.
                  The Rated Current of a fan is the worst case max current - at max rated voltage, not the nominal working current.
                  I did measure the current of a fan and the start/stopp voltages. And the current was surprisingly low...
                  • Stefan Payne
                    • 1267
                    What kinda pisses me off about that PSU is that there are two "+12V Rails" on the Label but it clearly uses Seasonics favorite protection IC: HY-510N
                    I really loathe that behavior to put multiple +12V rails on the box/label and then use one of those garbage 8pin chips.
                    So no OCP on any Rail...
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      Yeah, that's indeed a bummer about this PSU.
                      Generally, I don't find the lack of OCP to be a big deal for smaller PSUs (like 100-250 Watts). But going above 300 Watts and not having OCP makes it a bit dangerous, as you will be relying only on short-circuit protection if something goes bad (or OPP if you're lucky and the PSU has it).
                      That said, I have an old ThermalTake TR2 430W PSU that uses STF topology with UC3842 PWM and one of those 8-pin chips. I don't remember if that PSU had another chip for OCP or not, but I do remember reading reviews that said that it would shut down with anything over 18 Amps on the 12V rail. And it also had good OPP. The only thing I can attest to is that that PSU has good short-circuit protection. I have it in a PC that I use strictly for testing video cards, and it's been quite a few times where I've had a video card with a shorted MOSFET pull the PSU down.
                      Not really. I've measured a lot of fans. Most of the good brands are spot-on when it comes to current consumption at the rated voltage.
                      I also measured the fan in the FSP400-60PFN I mentioned above, and it was drawing about 180 mA @ 6.4V. At full 12V, it was just 5-10 mA shy of its 250 mA rating. Granted my multimeter could have be introducing some error into those measurements. But I doubt it would be that much, still.
                      • Behemot
                        • 4845
                        • CZ
                        Seasonic only recently finally solved the thing with multiple rails on label and in fact only single physical output +12V rail. They don't list two rails anymore with the xxGB versions
                        • mockingbird
                          • Dec 2008
                          • 5488
                          GB (S12-II Bronze) is going to be discontinued soon. GP (S12-II Gold) is already out of production. This applies to everything from 300-450 watts. Not sure about the higher-watt varieties.
                          • Behemot
                            • 4845
                            • CZ
                            Well it is being discontinued soon for some time now
                            • mockingbird
                              • Dec 2008
                              • 5488
                              Supposedly, "Core" is supposed to replace it (Core, Focus, and Prime are the new series). Unfortunately, Core, which was announced in January, now seems to have been cancelled.
                              The only good low-watt alternative I've been able to find is FSP's new 350w Hexa 85+ Bronze series
                              I tried to get a hold of one. They basically said that they haven't even begun producing it yet and won't until someone orders a large batch in the thousands.
                              So be prepared to pay through the nose if you want a low-watt PSU with Japanese caps. You'll have to get some fancy modular model that you don't need.
                                master hoarder
                                • May 2008
                                • 12175
                                • Bulgaria
                                Antec EarthWatts EA-500 – final recap and mods
                                Time for an update on the EA-500.
                                Basically, I replaced my temporary test caps (the Chemicon LXZ and Elite ED on the 12V and -12V rails, respectively) with something more permanent. I also replaced the first cap in the 3.3V and 5V rails (2200 uF each) and changed the 5VSB caps. Finally, I did a few other mods. Pictures of the handiwork below:
                                https://www.badcaps.net/forum/attach...1&d=1549078446
                                Details on the recap and mods…
                                Starting with the 12V rail… it originally had 1x 3300 uF OST RLX cap and 2x 1000 uF OST RLS caps. I didn’t touch the OST RLS caps, as I didn’t quite have anything in stock (8 mm) to replace those. But the RLX was replaced with a Chemicon KY 16V, 3300 uF, 12.5 x 35 mm. I can’t say if that’s an ideal replacement or not, as the OST RLX datasheet does not list a 16V, 3300 uF cap at all. Going by its 12.5 x 25 mm size, though, this cap is likely to have anywhere from 14 to 21 mΩ ESR and 2780 to 3000 mA of RC (ripple current). Knowing that this is a 16V cap and doing some datasheet interpolation, its ESR is probably closer to 21 mΩ ESR and RC around 3000 mA. Thus, my Chemicon KY wasn’t too far behind in terms of ESR and RC specs, as it is rated for 20 mΩ and 2880 mA. It is a whole 10 mm taller, though.
                                Next, the first cap in the 3.3V and 5V rails: both had an OST RLX 10V, 2200 uF, 10 x 20 mm cap each. Again, this particular cap wasn’t in the OST datasheet. So going by size one more time, ESR should likely be around 20 mΩ and RC ~2500-2700 mA. Actually, note that the OST RLX datasheet lists a 10V, 2700 uF cap in 10 x 25 mm can size and that it is rated for 22 mΩ ESR… which doesn’t really make sense! (Why is the ESR increasing?) Either way, my replacement for the 3.3V rail 2200 uF cap was the Nichicon HZ 6.3V, 2200 uF cap that I used temporarily on the 5VSB (I moved it). ESR might not be ideal being so low (7 mΩ), but it’s a mag-amp regulated rail and thus it likely won’t care too much. (Not that the 5VSB did either.)
                                For the 5V rail, I used a Panasonic FM 6.3V, 2200 uF cap with 10x25 size. It is rated for 18 mΩ and 2470 mA, which I think is a pretty spot-on replacement for OST RLX – that is, if the OST RLX ratings are even legit.
                                And finally, the -12V rail: it had an OST RLS 16V, 1000 uF, 8 x 20 mm cap. According to its datasheet, this cap is rated for 23 mΩ ESR and 1820 mA RC. For its replacement, I used a Rubycon YXJ 16V, 1000 uF, 10 x 16 mm cap with 62 mΩ ESR and 1210 mA RC specs. Obviously, this is not an ideal replacement in terms of ESR. However, this is the -12V rail, which isn’t exactly stressed a lot. As for why I went with a 10 mm cap: the PCB lead spacing for that cap spot was 5 mm (which is what 10 mm caps use), so I didn’t feel like trying to find an 8 mm cap and then bending its leads.
                                Speaking of more non-ideal replacements, I decided to go with a Chemicon KY 10V, 2200 uF cap for the 5VSB rail in place of the bad OST RLX 10V, 3300 uF (which I had replaced temporarily for testing with the Nichicon HZ 10V, 2200 uF cap that is now on the 3.3V rail). Yes, neither the temporary Nichicon NZ nor this Chemicon KY are the right capacity (2200 uF vs. 3300 uF of the original OST RLX), but I’ve seen plenty of 5VSB circuits before (from trusted manufacturers like Delta and HiPro) with a similar cap setup. Also, the Chemicon KY is a bit “tougher” (less heat-sensitive) than the Nichicon HZ, so I figured it was better-suited for a circuit that is constantly running (and without active cooling some of the time.) That said, the 5VSB in this PSU had a second cap on its output after a PI coil: OST RLS 16V, 220 uF. I pulled this cap and checked it with my TT meter – it was starting to develop bad ESR. So I replaced it with a Nichicon HE 10V, 220 uF, 6.3 x 11 mm cap. Once again, that’s not quite to spec with OST RLS… but I think you got my drift already.
                                Anyways, the important question is: does that recap work? The answer is YES. Unfortunately, I don’t have a load tester and o-scope to stress the PSU to its maximum limits and measure ripple/noise. But I doubt the replacement caps I used would make that much of a difference to make ripple/noise out of spec at full load. Moreover, the PC I intend to build with this PSU probably won’t be loading it more than 300 Watts max - if even that (most of which will be on the 12V rail). So I don’t think there will be a problem with ripple.
                                As for mods… I’m sure many of you noticed the new big primary cap up there in the pictures. If you’re asking why I did that, the answer is, because I was curious if the old primary cap was good or not. Sure primary caps don’t fail that often. But after my findings with my ThermalTake M850W and the Enermax Pro 82+ EPR525AWT (both of which had blown/bad 400V primary caps), I decided it wouldn’t hurt to pull the primary cap from this PSU (Hitachi HP3, 400V, 330 uF, 30 x 40 mm) and check it. According to my TT/ESR meter, it was showing about 0.33 Ohms ESR. Upon a second more recent check, though, it shows 0.14 Ohms ESR and slightly low capacitance (but still in spec):
                                I don’t know if this is considered okay or not for a big cap like that. IIRC, most other caps of this size typically measured lower ESR. Thus, I changed it to be sure.
                                The replacement I used for the primary cap is a Nichicon LQ, 450V, 500 uF “behemoth”. As you can see, it’s quite a bit bigger. However, this PSU uses a rear 80 mm exhaust fan and not a top 120/140 mm fan. Therefore, having a taller cap wasn’t an issue at all, unlike in the Thermatake M850W. The cap lead spacing was an issue, though. So I had to do a bit of “ugly work” to get it to fit “right”:
                                Basically, I soldered two pieces of solid 14 AWG copper wire to the leads of the cap and then ran the wires through the holes/vias. It’s shady work, yes, but it will hold. I didn’t have much of a choice either - even if the cap had the right lead spacing, I still couldn’t make it fit, because both primary heatsinks have metal stand-offs in the corners near the cap. Thus, raising the cap like this was necessary either way.
                                So what did I gain from this mod? TBH, I don’t know. However, all I can tell you is that after my first (temporary) recap, I noticed that the PSU would sometimes emit weird noises from the primary side that would change with the load. Doing a bit of research online suggested this is somewhat common on cheaper/ lower-tier PSUs with APFC. After changing the primary cap for the Nichicon LQ, all of the noises have disappeared. Does this mean another APFC disaster averted? – Who knows. I suppose, time will tell. (Personally, I’m inclined to say yes, because as I showed in the Enermax thread, the APFC controller won’t necessarily do anything if the APFC voltage overshoots above 400V for a few moments – possibly during load transitions.)
                                Another “ugly” mod I did… remember the overheated fan controller transistor and the metal heatsink I made for it? Well, I decided to change that mod when I came up with this:
                                Essentially, it is the H8050 transistor mounted on the secondary heatsink with some wire ties and hot glue (because I wasn’t sure if the wire ties would move with time.) Being a “test mod”, I didn’t put too much (any!) effort into the looks – hence, the Ethernet/phone wires used to connect it back to the PCB. Some of you might also have noticed a piece of used Copper braid attached to the middle wire. Well, since this wire goes to the Collector of the transistor, and since most non-tabbed BJTs are designed to cool through the Collector pin, I thought why not add a bit of extra cooling there as well. (Moreover, I wasn’t sure if the case mold of the TO-92 transistor would provide good enough heat transfer to the heatsink alone.)
                                To test this mod, I connected the 12V rail of the PSU to a 12V power adapter, essentially making the fan and its controller run. I ran it for about 30 minutes. The secondary side heatsink near where I had attached the transistor became only slightly warmer than room temperature, as did the Copper braid on the Collector pin. Thus, it looks like that transistor is finally running cool now.
                                Well… that concludes all the work I’m going to do on this PSU for now. There are still some OST RLS caps remaining on the outputs of the 3.3V, 5V, and 12V rails. But with the good caps in there too, I don’t think they will see much stress or fail. So for now, I consider this PSU done. Next stop would be recapping the Earthwatts EA-430, which I’ll probably do the same exact way. But we will see, of course, as I constantly have new “ideas”. So who knows what crazy/ugly mods I will come up with next?
                                • bogart219
                                  • May 2009
                                  • 200
                                  • usa
                                  Re: Antec EarthWatts EA-500 – final recap and mods
                                  Starting with the 12V rail… it originally had 1x 3300 uF OST RLX cap and 2x 1000 uF OST RLS caps. I didn't touch the OST RLS caps, as I didn't quite have anything in stock (8 mm) to replace those. But the RLX was replaced with a Chemicon KY 16V, 3300 uF, 12.5 x 35 mm. I can't say if that's an ideal replacement or not, as the OST RLX datasheet does not list a 16V, 3300 uF cap at all. Going by its 12.5 x 25 mm size, though, this cap is likely to have anywhere from 14 to 21 mΩ ESR and 2780 to 3000 mA of RC (ripple current). Knowing that this is a 16V cap and doing some datasheet interpolation, its ESR is probably closer to 21 mΩ ESR and RC around 3000 mA. Thus, my Chemicon KY wasn't too far behind in terms of ESR and RC specs, as it is rated for 20 mΩ and 2880 mA. It is a whole 10 mm taller, though.
                                  Next, the first cap in the 3.3V and 5V rails: both had an OST RLX 10V, 2200 uF, 10 x 20 mm cap each. Again, this particular cap wasn't in the OST datasheet. So going by size one more time, ESR should likely be around 20 mΩ and RC ~2500-2700 mA. Actually, note that the OST RLX datasheet lists a 10V, 2700 uF cap in 10 x 25 mm can size and that it is rated for 22 mΩ ESR… which doesn't really make sense! (Why is the ESR increasing?) Either way, my replacement for the 3.3V rail 2200 uF cap was the Nichicon HZ 6.3V, 2200 uF cap that I used temporarily on the 5VSB (I moved it). ESR might not be ideal being so low (7 mΩ), but it's a mag-amp regulated rail and thus it likely won't care too much. (Not that the 5VSB did either.)
                                  And finally, the -12V rail: it had an OST RLS 16V, 1000 uF, 8 x 20 mm cap. According to its datasheet, this cap is rated for 23 mΩ ESR and 1820 mA RC. For its replacement, I used a Rubycon YXJ 16V, 1000 uF, 10 x 16 mm cap with 62 mΩ ESR and 1210 mA RC specs. Obviously, this is not an ideal replacement in terms of ESR. However, this is the -12V rail, which isn't exactly stressed a lot. As for why I went with a 10 mm cap: the PCB lead spacing for that cap spot was 5 mm (which is what 10 mm caps use), so I didn't feel like trying to find an 8 mm cap and then bending its leads.
                                  Speaking of more non-ideal replacements, I decided to go with a Chemicon KY 10V, 2200 uF cap for the 5VSB rail in place of the bad OST RLX 10V, 3300 uF (which I had replaced temporarily for testing with the Nichicon HZ 10V, 2200 uF cap that is now on the 3.3V rail). Yes, neither the temporary Nichicon NZ nor this Chemicon KY are the right capacity (2200 uF vs. 3300 uF of the original OST RLX), but I've seen plenty of 5VSB circuits before (from trusted manufacturers like Delta and HiPro) with a similar cap setup. Also, the Chemicon KY is a bit “tougher” (less heat-sensitive) than the Nichicon HZ, so I figured it was better-suited for a circuit that is constantly running (and without active cooling some of the time.) That said, the 5VSB in this PSU had a second cap on its output after a PI coil: OST RLS 16V, 220 uF. I pulled this cap and checked it with my TT meter – it was starting to develop bad ESR. So I replaced it with a Nichicon HE 10V, 220 uF, 6.3 x 11 mm cap. Once again, that's not quite to spec with OST RLS… but I think you got my drift already.
                                  Anyways, the important question is: does that recap work? The answer is YES. Unfortunately, I don't have a load tester and o-scope to stress the PSU to its maximum limits and measure ripple/noise. But I doubt the replacement caps I used would make that much of a difference to make ripple/noise out of spec at full load. Moreover, the PC I intend to build with this PSU probably won't be loading it more than 300 Watts max - if even that (most of which will be on the 12V rail). So I don't think there will be a problem with ripple.
                                  As for mods… I'm sure many of you noticed the new big primary cap up there in the pictures. If you're asking why I did that, the answer is, because I was curious if the old primary cap was good or not. Sure primary caps don't fail that often. But after my findings with my ThermalTake M850W and the Enermax Pro 82+ EPR525AWT (both of which had blown/bad 400V primary caps), I decided it wouldn't hurt to pull the primary cap from this PSU (Hitachi HP3, 400V, 330 uF, 30 x 40 mm) and check it. According to my TT/ESR meter, it was showing about 0.33 Ohms ESR. Upon a second more recent check, though, it shows 0.14 Ohms ESR and slightly low capacitance (but still in spec):
                                  I don't know if this is considered okay or not for a big cap like that. IIRC, most other caps of this size typically measured lower ESR. Thus, I changed it to be sure.
                                  The replacement I used for the primary cap is a Nichicon LQ, 450V, 500 uF “behemoth”. As you can see, it's quite a bit bigger. However, this PSU uses a rear 80 mm exhaust fan and not a top 120/140 mm fan. Therefore, having a taller cap wasn't an issue at all, unlike in the Thermatake M850W. The cap lead spacing was an issue, though. So I had to do a bit of “ugly work” to get it to fit “right”:
                                  Basically, I soldered two pieces of solid 14 AWG copper wire to the leads of the cap and then ran the wires through the holes/vias. It's shady work, yes, but it will hold. I didn't have much of a choice either - even if the cap had the right lead spacing, I still couldn't make it fit, because both primary heatsinks have metal stand-offs in the corners near the cap. Thus, raising the cap like this was necessary either way.
                                  So what did I gain from this mod? TBH, I don't know. However, all I can tell you is that after my first (temporary) recap, I noticed that the PSU would sometimes emit weird noises from the primary side that would change with the load. Doing a bit of research online suggested this is somewhat common on cheaper/ lower-tier PSUs with APFC. After changing the primary cap for the Nichicon LQ, all of the noises have disappeared. Does this mean another APFC disaster averted? – Who knows. I suppose, time will tell. (Personally, I'm inclined to say yes, because as I showed in the Enermax thread, the APFC controller won't necessarily do anything if the APFC voltage overshoots above 400V for a few moments – possibly during load transitions.)
                                  Essentially, it is the H8050 transistor mounted on the secondary heatsink with some wire ties and hot glue (because I wasn't sure if the wire ties would move with time.) Being a “test mod”, I didn't put too much (any!) effort into the looks – hence, the Ethernet/phone wires used to connect it back to the PCB. Some of you might also have noticed a piece of used Copper braid attached to the middle wire. Well, since this wire goes to the Collector of the transistor, and since most non-tabbed BJTs are designed to cool through the Collector pin, I thought why not add a bit of extra cooling there as well. (Moreover, I wasn't sure if the case mold of the TO-92 transistor would provide good enough heat transfer to the heatsink alone.)
                                  Well… that concludes all the work I'm going to do on this PSU for now. There are still some OST RLS caps remaining on the outputs of the 3.3V, 5V, and 12V rails. But with the good caps in there too, I don't think they will see much stress or fail. So for now, I consider this PSU done. Next stop would be recapping the Earthwatts EA-430, which I'll probably do the same exact way. But we will see, of course, as I constantly have new “ideas”. So who knows what crazy/ugly mods I will come up with next?
                                  Mom, great write up. I'm new at this. My EA-500 stopped working. I took it apart and found some questionable caps. I'm confused though. Could you point out in the picture which rails are 12v, 5v and 3v? I don't know how you can tell. Also, which caps should I change while I have it turn apart. You wouldn't have made a list did you? Thank you for your time!
                                  • Behemot
                                    • 4845
                                    • CZ
                                    You already learned the wiring colors according to voltage from ATX standard?
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      Thanks bogart!
                                      Here is a cap diagram of all the output rails:
                                      It is applicable to both Antec EA-430 and EA-500 models.
                                      You should change all of the output capacitors in the PSU (the ones I pointed to above), along with all of the small electrolytics as well. The big cap doesn't need to be changed. I just did it anyways, because I already had a bigger and better cap.
                                      Unfortunately, I didn't make a cap list, as I used whatever caps I had in stock (hence the mix/mismatch in capacity and size mentioned in post #16).
                                      But going by the parts summary I made in Post #1 above, here is one example list of all the caps you will need for the output rails:
                                      2x 6.3V or 10V, 2200 uF, 10 mm diameter, 5 mm LS (lead spacing)
                                      2x 6.3V or 10V, 1000 uF, 8 mm diameter, 3.5 mm LS
                                      1x 16V, 3300 uF, 10 mm or 12.5mm diameter, 5 mm LS
                                      2x 16V, 1000 uF, 8 mm diameter, 3.5 mm LS
                                      1x 16V, 1000 uF, 8 mm or 10 mm diameter, 3.5 mm or 5 mm LS (can be same as above 16V/1000 uF caps)
                                      1x 6.3V or 10V, 2200 uF or 2700 uF or 3300 uF, 10 mm diameter, 5 mm LS
                                      1x 6.3V or 10V, 220 uF or 330 uF, 6.3 mm diameter (note: possible height restriction)
                                      For ESR and ripple current requirements, see post #16 above, which details what replacements I used and what other ones are possible.
                                      And for the small electrolytic caps, you will need the following:
                                      1x 50V, 47 uF, 5 mm or 6.3 mm diameter
                                      1x 50V, 22 uF, 5 mm or 6.3 mm diameter
                                      Hope that clears it up. Let me know if not.
                                      • bogart219
                                        • May 2009
                                        • 200
                                        • usa
                                        Thanks bogart!
                                        Mom, That those pictures are perfect. Thanks again for the help!!!
                                        • sirpsychol
                                          Antec Earthwatts EA-380 smd element type/value
                                          by sirpsychol
                                          While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
                                          09-03-2023, 07:58 PM
                                        • GnatGoSplat
                                          Antec BP500U APFC Coil
                                          by GnatGoSplat
                                          Antec BP500U PSU fried in my wife's gaming PC. I smelled something unpleasant last night, so I had a hunch something might be amiss. Woke up this morning to a popped breaker and immediately assumed the APFC cap must have blown. I last fixed it sometime in 2011, there's a thread about it here someplace. APFC and secondary caps that time. Replaced them with Panasonic caps. 10+yrs is probably a good run. It's been running 24/7 the last 3yrs, eth mining with a 1070ti and AFK fishing in Black Desert Online, lol.
                                          Anyway, cracked it open this morning, expecting it to just be the APFC cap...
                                          11-02-2021, 09:22 AM
                                        • chth96
                                          How can I test coil whether it is really broken or not?
                                          by chth96
                                          I have old game console which have connected to 220v outlet by previous owner and It is not able to turn on.
                                          I checked continuity of fuse in PSU unit with a multimeter which is shown in the below picture with a orange circle around it, and It seems that fuse became open circuit.
                                          I also found that as well as bulging capacitor, there is unidentified coil which has residue all over its surface
                                          I want to replace this round black fuse and unidentified coil if it got broken.
                                          02-20-2024, 01:07 AM
                                        • waterchill
                                          What part is this coil from a MacBook A2681 ?
                                          by waterchill
                                          Hi everyone
                                          I'm struggling to point out what part is this? It is a coil, but the parameters say: 10OHM - 50% - 1A - 0.05Ohm
                                          So it is a coil with 0201 dimensions, 1A max current, 0.05ohm resistance but what is 10ohm? For a coil we need specs like 1uH or so.
                                          IAny ideas? It is from a MacBook A2681
                                          Thank you...
                                          08-08-2024, 01:46 AM
                                        • Gjackson
                                          ADP-160FR ps4 slim PSU, shuts down under load and has severe coil whine.
                                          by Gjackson
                                          Hi all, the PSU originally had a no 12v issue where as soon as I bridged the 5v standby to the ACDC_stby the psu would switch itself off completely. I monitored the voltage on the main filter caps while doing this and saw that the PFC was bringing the voltage up to around 360vdc before shutting down. Given that I saw that as a little low I replaced the PFC feedback resistors from a donor PSU and that got it to power on, without a load no coil whine is present and there is a stable 12v however as soon as I put it in the PS4 it starts whining really badly, however 12v remains stable but after a...
                                          01-13-2024, 10:34 AM
