Dell D550p Not Starting
    • 30991
    Re: Dell D550p Not Starting
    depends on the current going through it in relation to the heatsink.
    programable loads use a fet and can run for hours continuously.
    • mmartell
      • Oct 2013
      • 3189
      Since I can't find a shorted component I was wondering if the gate of the fet was holding the fet on and blowing it up at startup.
      • mmartell
        • Oct 2013
        • 3189
        Is there any way to test the PFC inductor without a ring tester ? It measures on my dmm the same as putting the probes together.
        Is that what one would expect or should it be a couple of ohms at least ?
          • 30991
          i would think a couple of ohms with that wattage going through it would get very hot - besides, it's thick copper that probably has a much lower resistance than your test leads.
          • mmartell
            • Oct 2013
            • 3189
            Ok I'll rule that out for now and order some control ic's from China.
            Speaking of that chip, I have the riser card out and fed 19v to pin 4 of that chip (DNA1005A) and it didn't draw any current. Was trying to determine if it was functioning but not certain it would run that way as I think it starts of the rectified mains voltage.
            • mmartell
              • Oct 2013
              • 3189
              After leaving this for a while I inadvertently plugged it straight to mains (actually to an isolation transformer, was going to scope the gate signal to the pfc fets...) and blew up a ground trace and popped the fuse. No other damage that I can see.
              At first I thought I had everything hooked up incorrectly but there was no damage to the scope. But so I get this right... the DUT into an isolation transformer but the scope doesn't have to be (or the other way round is ok too I think ?) Ground for the scope on main filter cap negative lead, positive lead to gate of fet. Right ?
              Is the blown ground trace telling me something important as to what the actual issue is ? It went directly to the ground pins of the DNA1005 PFC controller ic.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4951
                • New Zealand
                #27
                It's better to float the DUT than the scope. In terms of not blowing your equipment, either one will work, but it's safer for YOU to only float the DUT, which is the main concern.
                My guess is that your probe's extra capacitance made the FET gate stay charged longer than it should have, or caused unstable operation in some other way, ultimately making it conduct for too long and blow up, going shorted. Or exacerbated an existing fault with the circuit...
                That probably sent mains voltage out of the gate of the now dead FET, and into the PFC IC, which also shorted, and the voltage took the easiest path: to ground, blowing the trace connected to those pins.
                -David VanHorn
                • mmartell
                  • Oct 2013
                  • 3189
                  The fet didn't blow and the pfc ic is somewhat protected from the fet as it actually drives two smaller transistors which switch the gate on and off.
                  But you are right, I forgot two check those transistors again. Please refer to the schematic on post 9.
                  How can I check the waveform output driving the gate ? Would removing the fets do the trick ?
                    • 30991
                    i disagree.
                    i know why you said that,
                    but it could mean not noticing earth-faults / shorts to earth on the DUT.
                    (just keep your fingers off metal parts of the scope! )
                    • mmartell
                      • Oct 2013
                      • 3189
                      I've read there are differing opinions on this.
                      In any event, is it safe to plug the DUT into a dim bulb tester and THEN into the isolation transformer so I can scope the gate waveform before the unit resets itself ?
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • repair-it
                        TOSHIBA DLP 52HM95 How to reset timer module on bulb
                        by repair-it
                        I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                        Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                        10-11-2023, 07:18 PM
                      • Gatolina
                        Low Standby voltage on Dell PSU
                        by Gatolina
                        Hello! I'm trying to fix this Dell ATX PSU H235PD-01 which had a burned tny279 for the 5V Standby.
                        I've changed it, checked the capacitors and diodes. Now I have 5.8V in pin 2 (bypass), 358V in Drain (pin 4), reaching the primary of the transformer but only 0.7v outputting to Standby purple wire.
                        What could be the problem? Thank you...
                        01-28-2023, 06:01 PM
                      • diamon
                        Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                        by diamon
                        I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                        Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                        Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                        Pictures of these boards:
                        Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                        Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                        Dell...
                        02-28-2024, 12:51 PM
                      • lalle-
                        Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                        by lalle-
                        Hello!
                        I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                        [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                        I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                        The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                        I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                        08-11-2024, 02:01 PM
