Apple ][+ Astec power supply
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Apple ][+ Astec power supply
    Originally posted by eccerr0r
    2N1136A: made in 1973 (as far as I can guess)
    466 103-9: made in 1972 (same deal)
    The 466-103-9 makes sense, I see the usual format on the bottom (international format)
    And the 2N1136A looks like different type of format, without the usual four characters. Reminds me of Intel, where the year number is often just the last digit of the year manufactured in.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      The reasons why I think 1973 is because:
      1. Germanium power transistors have not been made for decades.
      2. Bendix has been gone for decades.
      3. I think 1963 is a bit too old for the transistor, but it's possible.
      • BigTroll
        • Sep 2010
        • 1317
        • LAMBDA SOND
        heres a awful youtube video to celebrate the Rifa caps. https://www.youtube.com/watch?v=4hjnAc55lDQ
        My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Too many burst RIFAs. Why haven't I seen any dead WIMAs...
          Incidentally the BUW44 probably could work as a replacement for the PSU, it should switch at 200KHz, sustains 400V, 6A... This 200KHz is probably pretty close to the Ft though its gain is still apparently 5 at this given frequency test condition.
            • 31214
            be interesting to put a frequency counter near one of those old designs.
            just holding it over the transformer should be enough to lock on.
            • PeteS in CA
              • Aug 2005
              • 3581
              • USA, Unsure of Planet
              #26
              I don't think they were fixed frequency. That said, they were normally above 20KHz, so they would not be audible, and bipolar transistors limited the practical maximum switch frequency to around 50KHz.
              Not only are the turn-on and turn-off times of bipolar transistors slower than for MOSFETs, but there is also a turn-off delay called "Storage Time". If all those delay times are too great a % of the period, the useful on time (and range of control) is limited and the % of time when the device is dissipating power becomes too great.
              PeteS in CA
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
                03-31-2024, 02:12 PM
                07-01-2024, 06:34 AM
              • JimBanville
                Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                by JimBanville
                The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                09-13-2023, 07:21 AM
              • Andreas_de
                Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                by Andreas_de
                Hello!
                i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                04-12-2025, 10:38 AM
