Need alittle help with a fan transformer
  • playman
    • Jan 2011
    • 252
    Hi there, hope it's the right forum section.
    I have a what i believe a wall fan that is 230v 150w
    Could some one tell me what the brown, grey and black wire are.
    #3 had burned out so I patched it, hence the red shrink tube.
    I measured
    1-2 @ 10 Ohm
    5-6 @ 5 Ohm
    6-8 @ 14.5 Ohm
    7-8 @ 9.8 Ohm
    Are these reading ok? is it safe to plug in?
    I have no idea why it was discontinued in use other than the #3 burned out.
  • R_J
    • 9550
    Re: Need alittle help with a fan transformer
    Without seeing the rest of the fan, Is there a speed select switch? was there a capacitor connected to the motor? How do you know it is 250 volt 150 watt? is there a lablel on it?
    My guess would be it is a 2 speed fan, black is common, grey and brown are high and low speed selection. so connect a/c between black and grey are one speed or connect black and brown for the other speed.
    • playman
      • Jan 2011
      • 252
      Nope no switches or speed selector.
      It's very similar to this one.
      https://www.amresupply.com/part/F684...-ASSEMBLY-684N
      The volt and wattage is written/stamped on it, have a high res picture of it here.
      https://drive.google.com/file/d/15DD...ew?usp=sharing
      • R_J
        • 9550
        So how was it originally connected?
        • playman
          • Jan 2011
          • 252
          No idea sorry, it came from a deceased person and it was just along with other things.
          • R_J
            • 9550
            Well then your guess is as good as anyones, It could be a 2 speed, or it could be missing the capacitor?
            I can't seem to make out the brand name ??M?
            • playman
              • Jan 2011
              • 252
              I assembled it, doesn't seem there has been any capacitor, atleast no room for
              it on the inside.
              It's really hard to read on it.
              ΓIMΓ Sd 180595D
              MOD.K40 RP 0863 CL B
              230v ~ 50Hz 150W
              That's what I believe is written there.
              • R_J
                • 9550
                Well if the leads came out of the fan like that I would guess 2 speed fan.
                  +1, it is 2 speed shaded pole motor.
                  • playman
                    • Jan 2011
                    • 252
                    Awesome thanks for the help.
                    So I guess the readings were fine? and the burned wire must have happened because of overload/strain on the motor?
                      • Jul 2011
                      • 6040
                      I would recommend that you use an incandescent light bulb in series with this motor to see if it spins with way you are wiring it
                      This is for safety reasons
                      • playman
                        • Jan 2011
                        • 252
                        Could you explain that more please?
                        • playman
                          • Jan 2011
                          • 252
                          Well I just tried plugging it in, first brown and black then grey and black, and no luck
                          did not get any action from it :/
                          • R_J
                            • 9550
                            The closest motor I found was this from http://www.zhaolimotor.com/en/product-show-833.html
                            YJ84 is one type
                            Does it look like there may have been a wire on pin 5? It could be a 3 speed motor
                            • playman
                              • Jan 2011
                              • 252
                              YJ84 is one type
                              It does not look like there was a wire in pin #5.
                              Also I noticed that the grey and brown are completely isolated.
                              I can only measure between pin #1 and #2.
                              Pin #1 or #2 cannot be measured between #3 to #8
                                May be the thermal protection fuse has blown, so the owner just discard the unit?
                                • playman
                                  • Jan 2011
                                  • 252
                                  Well as I said earlier the #3 pin/wire was burned out, had to resolder it.
                                  where might that fuse be hiding?
                                  only place that I can see that could hold a fuse would be the #6 but I can measure from the #5 pin and #4 fine.
                                    Thermal fuse is usually buried under the winding wrapping.
                                    Good motor will have thermal protection, otherwise you can have problems like these:
                                    https://cdn.badcaps-static.com/pdfs/...912857388f.pdf
                                    • playman
                                      • Jan 2011
                                      • 252
                                      Ah that might explain things, then it's off to the recycling.
                                      Thank you very much for the help.
                                      • Wolf1977
                                        general question when a mosfet on primary of transformer is burned
                                        by Wolf1977
                                        hi
                                        in a welding machine i had a mosfet and four components wich connect with it burned
                                        i ordered all the damaged components and replace it but when i put the device on the plug all the components burned again i had tested before and i had not shunts
                                        i dont understand whats happen wrong
                                        more particular on the schematic q11p01 mosfet q11p02 tranzistor
                                        three paralel resistors had burned q11p07 zener shunt q11p08 open
                                        when i changed all these shunts q11po7 mosfet and tranzistors
                                        maby the transformer has problem on your opinion or something on...
                                        08-19-2023, 01:27 PM
                                      • ohren
                                        Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                        by ohren
                                        Hello!
                                        I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                        Measured voltages with no load:
                                        After rectifier diodes
                                        12V: 6.17 V
                                        5V: 5.67 V
                                        Secondary transformer pins AC measurement (really don't know if this says anything)
                                        12V: 2-2.5 V
                                        5V: 1.04 V
                                        I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                        03-18-2023, 10:33 AM
                                      • mikey5791
                                        Is it possible for transformer substitution?
                                        by mikey5791
                                        Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                        Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                        My questions are
                                        1. How do i test to see if the transformer is in good working condition?
                                        2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                        Hope you guys understand what i was asking. My intention is...
                                        11-03-2022, 02:11 AM
                                      • dennis_elx33
                                        3PHASE STEP-DOWN Transformer in Check
                                        by dennis_elx33
                                        Hello All,
                                        i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                        Problem statement: Power tripped Off
                                        Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                        Action Done:
                                        1) Replaced the faulty parts with good spare.
                                        2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                        12-02-2024, 06:52 AM
                                        ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                                        This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-06-2024, 04:40 PM
