Troubleshooting LED light issue
  • MattM
    • 41
    I have been asked to have a look at a LED Christmas light string on a 2ft snowman. It is a basic LED string wrapped around a wire frame.
    The PSU is a 240v stepdown to 24v 580ma 10.4VA.
    The voltage at the string appears to be fine but the string won't light. The string is not open circuit. I was told that it lit for about 30 minutes and then failed and has not come back again.
    I am guessing I have a duff LED/resistor in the string but have no idea how to fault find this easily. If it was AC I would have used a tester pen at each LED but clearly I can't do that as it is DC.
    Any suggestions would be gratefully received.
    Thank you
    • 31161
    Re: Troubleshooting LED light issue
    i use a pair of syringes used as needles to poke through the insulation onto the led legs - then short them to bypass the led.
    most common failures for me where blue - for some reason, as they in theory have the higher operating voltage.
    • MattM
      • 41
      Thanks very much for this, will give it a go
      • MattM
        • 41
        I spent some time with this and established that the PSU was in fact at fault along with a bridge rectifier which was inline with the cable to the lights.
        I removed the bridge rectifier and the unit now works but the lights flicker presumably because the bridge rectifiers is not in series.
        It was installed inside a weather proofing fitment and I had to cut it out. It is a DB107S. What I don't know though is what the wiring diagram for it was as I had to cut it out. Has anyone any ideas and if I simply leave it out is there any risk to lights - the flickering isn't that bad?
        Thank you
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8297
          add a capacitor? What does this thing look like? Any pics?
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • justice171
            Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
            by justice171
            I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
            Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
            1. Verified that all critical voltages are present:
              • 3.3V and 5V are always present if DC is plugged.
              • 1.8V on the BIOS chip is present.
            2. Checked the power button functionality:
              • When pressed, the voltage drops to 0V, indicating the button is functional.
            3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
              • Confirmed connectivity is intact, ruling out issues
            11-26-2024, 12:39 AM
          • ntec
            LED light issue
            by ntec
            Hi, I'm trying to fix my buddies rechargeable led work light made by olight and the model is odiance. For some reason now after a couple years of no issue, when powered off now, the led is faintly lit on 3 of the orange rows but as you can see from the first pic that's not where the leds are. The part that is faintly lit is beside the leds? Anyone know how that is possible? Is there small voltage still coming in somehow? The third pic is with the cover off....
            10-13-2024, 10:33 PM
            Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
            I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
            The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
            Now...
            06-09-2024, 10:57 AM
          • boyseth
            Troubleshooting guide for Macbook m2 A2681 - No power issue
            by boyseth
            hello mates,, need help im a new tech here.. any tips or idea on important testpoint in repairing a no power Macbook m2 A2681? Thank you in advance..
            08-14-2025, 01:28 AM
