This is a sticky topic.
  • kc8adu
    • Nov 2003
    • 8829
    • U.S.A!
    continued here as the first thread got so fat it would not show options to attach pics anymore and was hammering my dual core box with 2gb ram till it hit swap!
    carry on folks.
  • KeriJane
    Mac Enthusiast
    • Sep 2008
    • 681
    Seasonic S-12 330 Rev. A1
    Hello.
    One of my older builds came in for upgrades. It's been running a Seasonic S-12 330 PSU since 2005 so I though maybe it would be a good idea to look around inside the PSU.
    All of the caps are UCC KZE series except for the Hitachi? primary and 1 or 2 small Rubycons. None are vented and all have good ESR of .02-.03
    Running it on the KeriProductions ATX338 Load tester revealed stable voltages and decent 12v Ripple of 60mv at about 330w total (full load)
    The fan barely ramped up even after 15 minutes at this load and voltages/ripple remained OK with only warm exhaust air from the PSU. (The Load Tester was blowing hot)
    It went back in the system.
    Keri
    The More You Learn The Less You Know!
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      Delta DPS-400RB
      400W for gateway, 120mm temperature controlled yate loon.
      Non-APFC, group regulation. Capxon primaries, Ltec, taicon, and capxon secondaries, decent sized heatsinks, big enough coils, good full transient filter. But definitely nothing spectacular like I would expect from delta.
      Good range of connectors, 24pin motherboard (non-detachable), 4 pin cpu, 6 pin pci-e, 5 sata power, 2 molex, 1 floppy
      All the sata connectors have these nice little black protectors over them. Good because the sata power connector is a edge connector, and could short in your case if they eat a corner of the hard drive bays or some random metal flange.
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        Rosewill Stallion series RD500-2SB
        One of the best built solytechs I have ever seen. Pretty good input filter, all YC caps (they're everywhere!) Good sized heatsinks, Non-APFC, group regulation, 120mm Globe fan temperature controlled.
        You get a good range of connectors, if not lacking sata power connectors, 24 pin (detachable), 8pin+4pin cpu connector, 2 sata connectors, 6 molex, 2 floppy, 2 6pin pci-e.
        All cables are sleeved and the sleeving goes all the way into the psu's case.
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          moarbama wants more psu pics! This sticky is dying!
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            i was cleaning out my closet when i found this old agi (hipro) 235w power supply:
            it came from an old proteva with amd k6-2 350mhz, noname mobo, and lots of other shitty parts. obviously came from a chain smoker:
            see all the nicotine?
            also, notice the second plug in foreground. this was made when at and atx were both in production.
            wimpy heatsinks:
            rubycon primary caps:
            decent amount of secondary caps (sorry this is the last pic- my camera batteries died and im out of aaa's):
            more secondaries on board (total of 10 ones with vents , one of those is tiny (dia 4mm))
            secondary caps su'scon
            no thin wiring
            i eventually put the guts in a bestec box, which will soon be home to a hipro-made 250w board with far nicer heatsinks, etc.
            sigpic
            (Insert witty quote here)
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              oh, and if that was a dis on obama, _____ you!
              sigpic
              • Phaihn
                • Jan 2009
                • 842
                This is my PSU do these ever have much problems?
                My Computer.
                AMD APU A4-3300 2.5ghz 1mb cache
                Motherboard GigaByte GA-A75M-S2V
                Kingston HyperX Blue DDR3 8GB (2x4GB)
                SB Audigy 2 ZS [B800] Sound Card
                500GB WD Caviar® Blue™
                1 Terabyte WD Caviar® Black™
                2 Terabyte WD Caviar® Black™
                • kc8adu
                  • Nov 2003
                  • 8829
                  • U.S.A!
                  1.
                  i see bad fcon caps often.
                  2
                  will go BANG if loaded to label rating.
                  • 370forlife
                    Large Marge
                    • Aug 2008
                    • 3112
                    Huntkey
                      master hoarder
                      • May 2008
                      • 12160
                      Dynex (Huntkey) are not that bad, definitely not like the dirt-cheap generic PSUs, but they're still overrated and overpriced (look it up on Hardwaresecrets.com). Should be good for about 300 watts continuous. But don't go over 350 watts if you don't want to blow up the primary switchers.
                      • Newbie2
                        • Sep 2005
                        • 885
                        Dynex power supplies (Huntkey) are good quality, a step above gutless wonder power supplies, but the price that Best Buy and Future Shop (in Canada) sell them for is too much in my opinion.
                        My gaming PC:
                        AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                        ASUS M4A77TD AMD 770 AM3 Motherboard
                        PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                        G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                        TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                        WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                        ASUS Xonar DG 5.1 Channel PCI sound card
                        Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                        Antec Three Hundred Mid-Tower Case
                        Microsoft Windows 10 Pro 64-bit
                        Microsoft Windows 7 Ultimate SP1 64-bit
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Dead
                          You will be sorry
                          Not for real use
                          EWW!
                          Xtremly S***ty
                          DYNEX!
                          sigpic
                          • Phaihn
                            • Jan 2009
                            • 842
                            Just great now what buy a new one ive bean useing this for then a year.
                            My Computer.
                            • Newbie2
                              • Sep 2005
                              • 885
                              The Dynex 400W power supply can deliver up to 437.5W of power at 48.6 degrees Celsius, tested by Hardware Secrets. Since you have the 500W model, I'm assuming that your power supply can deliver at least a little more power than the 400W.
                              Judging from your computer specifications, I would say that the Dynex 500W power supply in your computer is perfectly fine. Dynex power supplies (Huntkey made) are good.
                              My gaming PC:
                              • 370forlife
                                Large Marge
                                • Aug 2008
                                • 3112
                                They just require a recap.
                                The rocketfish 700W (@40C) Hardwaresecrets reviewed was actually a huntkey titan 650W, but it still delivered 700W @ 40C well in spec.
                                • Phaihn
                                  • Jan 2009
                                  • 842
                                  A recap? well where do i get caps for it?
                                  My Computer.
                                  • 370forlife
                                    Large Marge
                                    • Aug 2008
                                    • 3112
                                    Order them on mouser or digikey, I like mouser because you can see who the manufacturer is.
                                    Or you can get some old 200W or so newtons that really aren't of much use and pull the caps from those. I say newton because they are deltas that use all rubycon and UCC.
                                    • Phaihn
                                      • Jan 2009
                                      • 842
                                      uh i dont know whare to get that here chilliwack.
                                      My Computer.
                                      • 370forlife
                                        Large Marge
                                        • Aug 2008
                                        • 3112
                                        These are what I use mostly
                                        http://search.digikey.com/scripts/Dk...me=493-1794-ND - 16v, 2200uf
                                        http://search.digikey.com/scripts/Dk...me=493-1529-ND - 16v, 1500uf
                                        http://search.digikey.com/scripts/Dk...me=565-1649-ND - 10v, 1500uf
                                        http://search.digikey.com/scripts/Dk...me=565-1509-ND - 10v, 2200uf
                                        http://search.digikey.com/scripts/Dk...me=565-1339-ND - 50v, 47uf
                                        The only reason I use 16v, 1500uf's sometimes is because those are what I salvage out of other psu's, if I order them, I just replace them with 2200uf's.
