This is a sticky topic.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Originally posted by domas
    regarding picture 11: is it a temp sensor on a sink or is the sink grounded this way? A little blurry, can't see shit there
    EDIT: oh there is a component marked TH2.. a thermistor nevermind
    Yep, indeed it is a thermistor. Cheapo PSUs will exclude that, and when the PSU overheats, well, the control circuitry keeps going ... until it blows up xD
    The thermistor may actually mean the fan speed is controlled, which is a plus.
    Muh-soggy-knee
      master hoarder
      • May 2008
      • 12176
      #1622
      Originally posted by Pentium4
      Awesome Macron power supply.
      I like it too. And yay for the PowerLogic fan. Also good they provided 12.5 mm spot for what looks like the 12V rail. Many cheaper modern PSUs don't do that. One reason I love old HiPros.
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        Originally posted by c_hegge
        Note the MPT-5002 model. That's actually a 500W, and not a half bridge one (2TF topology). Macron do usually seem to rate their PSUs accurately. Nice save!
        Thanks You think it can do 500W??
        It does have two 20A schottky's on EACH 12V rail, which is pretty impressive. (There's 8 rectifiers on that secondary heatsink!) I bet this thing is pretty efficient!
        I think it's actually single forward, I think that other transistor is for the 2 transistor 5VSB. The FET is Fairchild (I'll check the model number later) It was either 14A or 16A, and it does have that nice heatsink.
        When I first plugged this thing in, I heard a loud POP! I thought to myself "shit, the fuse blew!" but it kept running.....after opening it, I realized it was that Fuhjyyu cap on the 5V rail next to that big GL cap. The PSU was giving off a funny smell and the source of the smell was coming from that Fukjyyu cap.
        Yeah I love Power Logic It was very well lubricated and spins very silently. Indeed that cap slot was 12.5mm, that KY cap fit no problem.
        • Behemot
          • 4845
          • CZ
          #1624
          Are those really independent rails or just 4 parallel rectifiers?
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            It has two 12V rails with each rail having two 20A schottky rectifiers in parallel
            • Behemot
              • 4845
              • CZ
              #1626
              So it has two +12V transformer windings? Never seen such concept before.
              • cheapie
                null
                • Jul 2010
                • 849
                Sounds like one winding feeding two sets of rectifiers. Each set of rectifiers has its own filtering, and goes to its own set of wires.
                • Behemot
                  • 4845
                  • CZ
                  #1628
                  Never seen that either, each time they all were in parallel with each other, than after rectifying there was shunt (sometimes represented by inductor), sometimes also extra capacitor for each such rail. But I have never seen separated rails from the transformer on, always after the diodes.
                  Can we get some pictures of the bottom?
                  • c_hegge
                    • Sep 2009
                    • 5219
                    Maybe not if its STF. I've never seen an STF topology design do more than about 400W before. I guess that doesn't mean it can't be done, though.
                    • Wester547
                      • Nov 2011
                      • 1269
                      • USA.
                      #1630
                      This power supply was reviewed at Hardware Secrets a few years back. It is of half bridge topology and while it looks rather overspec'd otherwise it was capable of doing almost 780W with 74% efficiency. So STF doing more than 400W with enough overspec'ing (especially on the secondary side) and decent enough cooling is definitely possible.
                      Are you saying that you think STF isn't capable of more than half bridge is in terms of power output ability, though?
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        Sorry, that Macron PSU is in a computer now! I should have snapped a solder shot...
                        That is amazing! That's a very well designed half bridge unit right there And it looks like it'd do 80+ up to 500W. I think they're using that exact design in all of the Kingwin ABT series power supplies, with 100% CapXon caps.
                        • c_hegge
                          • Sep 2009
                          • 5219
                          No. I was just saying that most PSUs Ive seen which are rated for more than 350W use 2TF, while STF is usually only seen on <350W designs.
                          I'm not saying that it's not possible make a 500W STF unit, just that it's not common.
                          • goodpsusearch
                            • Oct 2009
                            • 2850
                            • Greece
                            #1633
                            Hipro HP-A2307F3P
                            Primary caps are 2x560uF 200V Panasonic (real c: 490uF)
                            Every cap on that thing is Japanese. It is ridiculously overbuilt, 12V and 5V have 30A schottky rectifiers, 3.3V has 2x2200uF 10V KZE, 5V output caps are 1x4700uF 10V KZE & 1x2200uF 10V KZE and 12V has 1x2200uF 16V KZE & 1x1000uF 16V.
                            5vsb: 1x2200uF 10V KZE & 1x1000uF 10V
                            • Behemot
                              • 4845
                              • CZ
                              #1634
                              Good ol' times that will never come back again Or will they?
                              • Wester547
                                • Nov 2011
                                • 1269
                                • USA.
                                #1635
                                That Hipro looks very overbuilt indeed, though the primary heatsink appears to be finless. Its choice of capacitors and fan is much better than what you'd find in most Hipros (though most of the time they are equally overbuilt). That toroid looks like it's made of -52 material as well... given its high number of turns and size, that's nice.
                                • goodpsusearch
                                  • Oct 2009
                                  • 2850
                                  • Greece
                                  #1636
                                  Linkworld LPK9-3 300W
                                  I was surprised to see a full input filter on that psu. Of course MOV protection is missing and the Y caps are ordinary ceramic caps.
                                  Another thing that surprised me is the switching transistors, being ST W13009!
                                  The primary caps are fake, their real capacitance is 300uF!!
                                  The main transformer is capable of 250W, the 5vsb transformer is too small for 2A output...
                                  Secondary rectifiers:
                                  20A for 3.3V
                                  20A for 12V
                                  30A for 5V
                                  Output filter caps:
                                  5V: 1x2200uF Canicon 10V & 1x2200uF 10V Fuhjyyu TN bulging
                                  3.3V: 1x2200uF Canicon 10V & 1x2200uF 10V Fuhjyyu TN bulging
                                  12V: 1x2200uF 16V SEK Teapo
                                  5vsb: 1x1000uF 10V Canicon & 1x470uF 16V Fuhjyyu TN
                                  What do you think?
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    That kind of thing goes in the hall of shame.
                                    • kaboom
                                      "Oh, Grouchy!"
                                      • Jan 2011
                                      • 2507
                                      All the caps are fake, as far as I'm concerned!
                                      20A for 3.3V
                                      20A for 12V
                                      30A for 5V
                                      Output filter caps:
                                      What do you think?
                                      Use it at ~250W or less, after a recap. If you even want to bother.
                                      I had one of these, and a silly GSC'd Albatron board. I was junking them in a few days anyway, so why not play a little?
                                      System was a 1.3GHz duron, 512MB(?) DDR266, Nvidia GF4(?)/64MB with TV out.
                                      I figured I'd do a little burn-in with DNMP in a demo-loop, and an extra 80W or so of halogen bulbs on the +12 output. After about 15 minutes, there was the "hot transformer" smell.
                                      That was about eight years ago, and I think it was the (undersized) output inductor cooking, not the SMPS transformer.
                                      Rather amusing how it tried its best. No, I didn't run it 'til it blew up, since I wanted parts from the power supply.
                                      "pokemon go... to hell!"
                                      EOL it...
                                      All style and no substance.
                                      guilty,guilty,guilty,guilty!
                                      guilty of being cheap-made!
                                        master hoarder
                                        • May 2008
                                        • 12176
                                        #1639
                                        Leaded solder and SMD-less bottom sides?
                                        I doubt it.
                                        What do you think?
                                        It's not bad. I like that it has plenty of space on the secondary side for the caps to breathe (but I guess that still wasn't good enough for those Fuhjyyus). The heat sinks aren't too bad either. Just spread out the fins further apart, and the heat sink will actually become decent.
                                        On the negative side - 2-transistor 5VSB circuit. I don't see any critical caps in that design, though, so it may be one of the "better" 2-transistor designs.
                                        And yeah the MK input caps are trash.
                                        • Pentium4
                                          CapXon Be Gone
                                          • Sep 2011
                                          • 3741
                                          Linkworld definitely used to be better. It has TO-247 13009's, an okay-ish transformer, and good size PI coils, bridge rectifier and good heatsinks considering that fan will probably always be running full boar. Good looking secondary silicon, on 230V it may be able to do 300W
