This is a sticky topic.
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Huntkey 350W. It looks good. Can't find any info on the primary silicon, all I know is that they are MOSFETs. 30A schottky for 5V and 3.3V. Dual 12V rails with a 20A shottky on each. They used a mix of HEC, Aishi, Fcon and Samxon (Samxon GF on the 5VSB )
    Also, in the last picture, how come there are so many resistors there? I haven't seen that many resistors before on that section of the PSU.
      What is the printed capacitance of those primary caps?
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        They say 680uF. But being HEC, who knows...they are good sized though
        • cheapie
          null
          • Jul 2010
          • 849
          I used to have an almost identical Huntkey (Dynex-branded) 400W with HEC primaries and Fcon caps everywhere else. I don't know what killed it. The computer just started freezing up randomly. Not heavy load, not cold, not hot, not light load... just random. The Astec 200W that I put in solved that problem, but it was an old +5V heavy design in a +12V heavy system, and I didn't like crossloading it like that (it got very hot). The computer is now running happily with a Seasonic S12II Bronze 520W (overkill for this maybe 100W load, but it was on sale).
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            That's strange. I wonder if one of the Fcon caps died without bulging, they're only rated for 2,000 hours @ 105C, other than the caps I think they are nice PSU's especially for their price. Good thing Astec makes fantastic PSU's!
            Yeah, that's MEGA overkill
            • Wester547
              • Nov 2011
              • 1269
              • USA.
              #1486
              I prefer Huntkey's older style of heatsinks to the one in your PSU, Pentium4, but that being said, what you have is still a decent unit and at least it's double forward and not half bridge like older Huntkey units.
              The Fcon capacitors very likely killed your Huntkey. They are cheap Chinese junk. 2,000 hours @ 105*C has nothing to do with it (for the GL series? especially since those ratings are only stated with 60% confidence which means 2,000 hours could be 1,200 hours or 3,300 hours...). That doesn't take into account what happens when the impurities in the Chinese aluminum foil ruin the already subpar Chinese electrolyte. I would imagine that the Fcon on +5VSB went bad first.
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                Yeah I'm glad it's not a half bridge unit. And it runs cool with a 140MM fan too. The heatsinks are decent...Wish the primary one was a little bigger and had more fins.
                Yeah I know it's not just the temperature rating, but when a cap is only rated @ 2,000 hours, that is pretty bad and in general indicates low quality, especially when they have the role of filtering the output. They have a mix of Fcon GF and GL, they're both 2,000 hours, but the GF series have much better ripple specs for their size, and okayish ESR. I tested all the caps and the Fcon held their specs better than the Samxon GF
                • cheapie
                  null
                  • Jul 2010
                  • 849
                  Well, it ran 24x7, so that's 24 (I'll round to 20) hours a day for a total of... 100 days, or 1/3 of a year (at full rated temperature). It lasted about 2 years (at 40 or so degrees exhaust), so I think that's probably the problem. The computer (when running sort of correctly) had all sorts of issues that got worse over time, so I think maybe the ripple (or voltage or something) was way out of control on one of the main rails (probably +12V). The board (and the KZGs on it!) is still perfectly fine, and as I said, is running great with its new power supply.
                  • 370forlife
                    Large Marge
                    • Aug 2008
                    • 3113
                    It looks like to me that it is a half bridge unit, meaning it uses BJT's.
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      They each read FSW09N90AG. Can't find much info on them
                      • Behemot
                        • 4845
                        • CZ
                        #1491
                        One thing about Huntkey guys, I've managed to push them into making second revision of their flagship FX500SE, 500W 80 PLUS Platinum PSU. They should be now using completely japanese caps only.
                        I should get a sample in next weeks, probably as the only one in central Europe (maybe even whole Europe). If all goes well and I'll like them, I will hopefully become their ditributor in Central Europe.
                        I'll than make a thread on forums and if anybody will also be interested, we can establish some cooperation than…
                        • shovenose
                          Send Doge Memes
                          • Aug 2010
                          • 6575
                          The action is at the end, but you can see how the power usage climbs overall as the PSU's already poor efficiency goes downhill. And yes, it got quite hot toward the end there, even with the fan screaming (hard to hear over the loud case fans that were closer to the phone sitting on the case that I used to record this than the PSU fan)
                          http://www.youtube.com/watch?v=D37J9FZWls0
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            Very cool, keep us updated!
                            Careful man, you don't want that thing frying your nice system! Surprised that thing did over 300W, the ripple was probably over double spec, maybe more. Post pics of the carnage?
                            • lti
                              • May 2011
                              • 2558
                              You plugged that piece of crap into a decent computer?
                              • Pentium4
                                CapXon Be Gone
                                • Sep 2011
                                • 3741
                                I'm hoping it wasn't the 12V rectifier that blew. It probably had a 20A part and just the 295 by itself running furmark would overload it, and that thing has one of those horrible, classic T Leadman style heatsinks
                                • shovenose
                                  Send Doge Memes
                                  • Aug 2010
                                  • 6575
                                  lti, the hdd in that computer is on its way out anyway, the motherboard, ram, and cpu, are under warranty, and that gtx 295 is a noisy power hungry piece if crap.
                                  That said I'm running the same test on a really old (original s12 I think) seasonic 300w psu and it is doing great
                                  Pentium4, actually it was the controller ic that blew up. Everything else looks perfect
                                  And the computer still works.
                                  That's only the second half of the video... the psu lasted about 20 minutes total under those conditions. I thought it would die much quicker.
                                  • shovenose
                                    Send Doge Memes
                                    • Aug 2010
                                    • 6575
                                    Who is their US distributor?
                                    • Behemot
                                      • 4845
                                      • CZ
                                      #1498
                                      Beat me…
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        Beat me…
                                        Well, what roles does a distributor have? Would you simply be the point of contact for people to purchase Huntkey products? Or would you be in charge of shipping them, etc?
                                          Importing distributors:
                                          - arrange imports from foreign countries
                                          - arrange paperwork, tax and other documents
                                          - usually prepare marketing material
                                          - sell products to retailers/other distributors
                                          - handle certification and safety testing (though often just passing on fake documents from China)
                                          - handle recalls/returns (often by going bankrupt and avoiding the problem altogether)
