This is a sticky topic.
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Thanks 370forlife, I was wondering who made it....I thought it looked like an Andyson at first minus the capacitor choices.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Got a decent little PSU here, well, after I modified it.... not sure who the OEM is
      Originally had 560uF input caps, replaced with 820uF. Added a heatsink to the 8A bridge rectifier. Notice how it has a Viper22A for 5VSB I forgot the model of the MOSFETS, but it has 2 on that primary heatsink rated at 14A
      Replaced all the capacitors of course, using some 3300uF 16V Samxon RS caps from behemot Originally, ALL of the caps were Asia-X.
      I replaced the two 20A schottky's on the 12V with two 30A schottky's. This thing does indeed have dual 12V rails.
      How many watts do you think this is good for? It likes to hang around 79% efficiency. I really need to get a load tester...
      • Behemot
        • 4845
        • CZ
        #1463
        I think it ExplodeGen or the other crap, looks very similar to different EuroCase PSUs on my market which also uses Asia-X. The transformer does not seem that big so I think some 400 W safe?
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          No way Codegen could make something like this Although yes 400W seems about right because of the transformer. When loaded to around 300W, the secondary heatsink got to around 50C so the fan kicked up to an audible level, but the primary heatsink was hardly warm at all
          • c_hegge
            • Sep 2009
            • 5219
            They actually can. I have seen a couple of half-decent Codegens out there before. That said, I doubt they're behind that unit. I think it should do somewhere between 300 and 400W, depending on the switchers.
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              Really? I haven't seen that many of them I'd be curious to see a decent one made by them. I remember it had 2 FET's made by some stupid name like "power chip" or something like that @14A
              • c_hegge
                • Sep 2009
                • 5219
                See http://prohardver.hu/tema/codegen_ta...z_601-650.html, about three quarters of the way down. There's some internals of one. It's a fair bit better than the gutless wonders that often come from them.
                EDIT: I have also seen another decent one. It was a little different to that one, though. I think it might have been something like this one (http://www.ebay.com.au/itm/CODEGEN-C...item4ab2e1e03f)
                Do you also think this thing would top out around 400W?
                If it has 15A (continuous) switcher, like 2SC3320s, then 400W should be OK. With 12A switchers, (13009, D209L), then I wouldn't want to push it harder than 350W.
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Cool, thank you for the link. I'm fine with 400W, I believe it has just two 6 pin PCI-E connectors. But I will still be sure to check the specs on those FET's. I forgot to put in the original post, the 3.3V and 5V rails both have a 30A schottky as well, not that those are too important
                  • PeteS in CA
                    • Aug 2005
                    • 3578
                    • USA, Unsure of Planet
                    #1469
                    Unless the fan(s) are almost sufficient for that P/S to hover, I'd agree with ~400W. Decent heatsinks, for that power level. Kind of wimpy O/P inductors - the cores, which are also -26 material rather than -52 (which would have lower losses, especially if the switching frequency is >50KHz). With those very uprated I/P lytics and 400W load you would have very decent hold-up and ride-through times for a 400W P/S. 560uF for 600W?
                    BTW, if that's a D/C on the main transformer, that thing was built this year.
                    PeteS in CA
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      The fan is a little slow, so this thing won't be doing any hovering
                      I wish that the primary and secondary heatsinks were swapped. The secondary heatsink is a little small in my opinion to have four TO-247 rectifiers attached to it. The output inductors are indeed pretty tiny. At least it has one for each 12V rail. I might swap them out for bigger ones, I just thought it was getting a little cramped in there on the secondary.
                      When you say "26 material cores" are you referring to the toroid coils?
                      I know, 560uF for "600W" ?
                      Yeah that's the date code on the transformer, very new. The date code on the other ones are fairly older
                      • PeteS in CA
                        • Aug 2005
                        • 3578
                        #1471
                        Micrometals powdered iron core materials
                        -26 and -52 material have the same permeability and the same inductance for a given number of turns, but -52 material is newer, has lower core losses above 50KHz, and costs a little more.
                        PeteS in CA
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          Very interesting. Thank you for that link
                          • PeteS in CA
                            • Aug 2005
                            • 3578
                            #1473
                            Micrometals is a US company, though I don't know where they manufacture their parts. At any rate, Micrometals -26 material was THE de facto standard material used in the P/S industry back in the late 70s and 80s, when I first worked in the industry. It was ubiquitous. Evidently, between that long-term market position and being able to keep their quality/price/availability good, Micrometals is still pretty much the industry de facto standard. One good development move was coming out with -52 material - lower losses above 50KHz - in the mid 80s, as MOSFETs were making such switch frequencies possible and MOSFET prices were coming down (and performance and reliability were improving). Micrometals was also in the forefront of recognizing and understanding the product life problem when the cores are operated at higher temperatures, and releasing high-temp materials for power products where higher temps can't be avoided (another reason to like P/Ss with really good cooling!).
                            PeteS in CA
                            • Pentium4
                              CapXon Be Gone
                              • Sep 2011
                              • 3741
                              Nice Liteon unit...Very well built for 300W. Replaced most of the caps of course.
                              • Wester547
                                • Nov 2011
                                • 1268
                                • USA.
                                #1475
                                Those finless heatsinks are somewhat disappointing, but that probably means it's an 80+ unit of sorts. The ADDA sleeve bearing fan probably will eventually fail if it hasn't been preemptively lubed. Lite-on PSUs are pretty well built, though. Their older units said on the label that they would sustain their labeled rating up to 50*C ambient. Definitely true from the way they were overbuilt inside.
                                • Pentium4
                                  CapXon Be Gone
                                  • Sep 2011
                                  • 3741
                                  True, I do not like that style of heatsink either. Yeah that thing looks like it could handle some heat. Impressive to see a 6A bridge with a heatsink in a 300W PSU. And a 220uF input cap for a 300W is pretty impressive, I've seen single 220uF in 400W PSU's (That could actually do their wattage)
                                  • Jooo
                                    • Oct 2011
                                    • 222
                                    • Finland
                                    #1477
                                    Linkworld AT psu with maximum out___put of 150W.
                                    Every single electrolytic cap in this unit are Fuhjyyu, none appear to be bulging though and the PSU still works fine.
                                    Input caps are 220uf 200V Fuhjyyu with Teapo style vents?
                                    • lti
                                      • May 2011
                                      • 2547
                                      They even have all of the markings in the same locations as Teapo caps.
                                      It might be able to handle 150W, but the ripple will probably be out of spec.
                                      • Pentium4
                                        CapXon Be Gone
                                        • Sep 2011
                                        • 3741
                                        I would say that thing looks horrible, but for being made in Dec. 1996, it looks pretty good! Minus the caps of course. They look fine but they're probably dried out or out of spec. Interesting, the Teapo style vent on those input caps...And it has a bridge rectifier, wow! How many amps is it?
                                        Looks like it'd do its rated wattage, although I think 220uF input caps are pretty wimpy even for a 150W PSU
                                          I'd say it can do 100W with a headwind reasonably continuously.
