This is a sticky topic.
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 Pro -
Deer has made worse. But like most YC input caps, the ratings are probably exaggerated, they're most likely 330uF. And it probably has 13007's, so I'd trust it with 225W. Surprised it has a fan controller thoughComment
Seasonic SS-250SFD
Unless otherwise specified, all electrolytics are OST RLS Series.
2200uF 16V OST RLP on +12V rail.
1000uF 16V before -12V rail inductor with 220uF 16V after it.
2200uF 10V OST RLX before +5V output inductor with 2200uF 10V OST RLP after it.
2200uF 10V before +3.3V output inductor with 3300uF 6.3V after it.
2200uF 10V JP CE-TUT before +5VSB output inductor with 220uF 16V after it.
150uF 400V Hitachi HP3 primary unit.
STPS30L45CT rectifiers for +3.3V and +12V outputs.
STPS4045CW rectifier for +5V output.
CM6800G PFC/PWM controller with HY510 secondary side output voltage supervisor.
FQP9N50 PFC boost stage with 2SK3533 primary switcher.
VIPer22A +5VSB primary side regulator.
GBU406 primary side bridge rectifier.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
Only one 2200uF, 16V capacitor on the +12V rail? That's it? That's kind of lacking in terms of output filtering for a 250W unit whose +12V rail is rated for 16A, but in all fairness, a 30A part is quite overkill for 16A.Last edited by Wester547; 03-05-2013, 02:53 AM.Comment
Winsis KWT-200. TFX psu that comes with the Winsis WI-02 Mini-itx case. For a PSU that comes with a case that only cost $60 this thing is pretty impressive. It even has pi coils and a full input filter!
I think I've just learned new capacitor brandLess jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
I've seen those <BH> Caps before. They are Bad, Honestly.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
I meant them ZhiCheng or what is that signLess jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
I've seen ZhiCheng caps before but just recently found their website
Sort of... I haven't had time to log in BCN all week.
I'm still sticking to my point - that PSU is just "different". Look at those small traffos - it's more than likely some high frequency shit. That makes it possible to design a filter that uses totally different capacitors and coils. There are indeed PI coils in there. And you have Chemicon PSCs. Obviously a completely different animal that has very little to do with what you'd see in a generic crap PSU.
Anyways, do tell your secret
Originally posted by c_heggeI've seen those <BH> Caps before. They are Bad, Honestly.Comment
Yup. I'm dumb as a bucket, alright
I did. Figured it may be for a magamp circuit for one of the rails. Can't tell everything from one picture, though.Comment
Who gives a fuck what it's for?! You'been talking 'bout some problems squeezing inductors somewhere. Here you have some crazy ghetto shit coming directly from factory in server grade PSU.
So stop talking about nothing, just admit you're blind and any inductor is perfectly squeezable into any cheap shit power supplyLess jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Whole point was in the bloody coil, or more to say, some wire strangely flying in there having ferite glued to it. Why you keep repeating obvious that it's DC-DC which has NOTHING in common with how it's done?
It was you coming with all the crazy stuff all the time, remember? After all, what else that could be when I replied to quotation of you talking about not squeezing inductors somewhere…Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
-David VanHornComment
But it works obviously so you can use it whenever you need as wellLess jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Yet another Key Mouse (K-Mex) unit, this one is labeled as 450Wbut they were dumb enough to leave the real model in one of the stickers that reads PX230 so this is a 230W unit from their PX Series also this unit is a little bit smaller than average ATX PSUs with only 120mm depth, all caps are ChengX except the primaries which are HEC branded and at least in this case the manufacturing quality is horrendous, there are cracks in the PCB and loose solder drops all over this thing
the rest as follows:
No EMI/Transient filter ...even website says it's "optional"
4-diode treatment
only two "Y" caps but fake ones
Primary caps 470uf-200V
Primary switchers 13007
SB switcher 2N60
Supervisor+PWM CG8010 ...is it just me or this is a chinese-equivalent version of WT7520?
Main transformer EI-28
SB Schottky SB340
12V Schottky F12C200
5V Schottky MBR2045
3.3V is generated by 40N03 mosfet
All positive rails use one 1000uf cap except -12V which uses one 470uf cap
No output coils (and/or space to stuff them) except for SB
I've seen this kind of small PSU before under brands like ULTRA or Maxpower all with pretty much the same stuff inside just small changes like bigger main trafos' (EI-33 or EI35) and higher rating rectifiers, some of them use real bridge rectifier instead of 4-diodes but so far all low-end Key Mouse made PSUs I've seen use EverPower trafos' so what do you think? Everpower inside equals to Key Mouse made?Last edited by SIDMX; 03-12-2013, 12:57 AM.Comment
If run above 200-250W it might glow.PeteS in CA
****************************Comment
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by CMCMHello Everybody,
Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
The outputs marked 12v and 20v are all measuring only 1v.
The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
The capacitors physically look clean (no bludgesor leaks) and... - Loading...
