This is a sticky topic.
  • Behemot
    • 4845
    • CZ
    #1241
    Originally posted by c_hegge
    No, that wouldn't help. It's more to do with the topology. It's a flyback converter, not a forward converter, which produce far more ripple.
    Oh, a single transistor in there, I can see it now…
      Flyback at 350W??
      You do get single switch forward, you know, among other topologies.
      With ripple current through the caps being a concern (it is often designed so they can use cheapest off brand cap possible) no one would make a flyback computer SMPS... right? Please tell me no one has tried to do so...
      • Behemot
        • 4845
        • CZ
        #1243
        Yeah, could be single-transistor forward as well, you are right, just thought c_hegge had it in his hands before you see…
        • lti
          • May 2011
          • 2548
          http://www.jonnyguru.com/forums/show...2548#post62548
          I don't know what they did to get that kind of ripple.
          • c_hegge
            • Sep 2009
            • 5219
            http://www.overclock.net/t/1310456/p...00w-psu-review
            Phaedrus reckons it's a flyback, not single forward, which would explain the ripple. It would also explain why Leadmen often explode under <250W Loads
            • Behemot
              • 4845
              • CZ
              #1246
              The fuse might be counted as OPP or SCP, but since it's rated way too high for the 250W we have here, I'm not counting it.
              • c_hegge
                • Sep 2009
                • 5219
                Yah. I thought the same thing. I'm sure Leadman probably think that the fuse will be fine as OCP, though
                  It's often hard to tell them apart; the only difference is a flyback of that size would need a massive energy dump resistor. A forward converter would use a single return diode.
                  • Wester547
                    • Nov 2011
                    • 1268
                    • USA.
                    #1249
                    Originally posted by Pentium4
                    And it has a pretty good transient filtering stage The only reason I'm using it is because it has such a low load to power. I have a Hipro with the same exact specs on the label as yours, but it has 470uf 200V Elite caps on the primary, all the rest are Teapo. Mine was manufactured in May, 2007. They're good little supplies. Efficiency is meh, I got 72%-76% out of mine. It powered a Pentium D, 2GB RAM, 7300GT, and 3 hard drives no problem for over a year, other rigs it was in used less power and it's still kicking.
                    I know this is very far back, but... I'm curious... often, PSUs will be below 70% efficient when the load is very light... did you get 72% efficiency out of that PSU even with a very light load (when the computer was idling)?
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      That was under low to medium load. The computer that idled around 55W, the PSU only got around 69% efficiency, 76% was around 50% of its labeled wattage
                      • Shocker
                        Banned
                        • Dec 2011
                        • 635
                        #1251
                        No, I don't think it would be a flyback like everyone else suggested. If it was then it wouldn't have the large toroid.
                        • japlytic
                          • Oct 2005
                          • 2086
                          Power Systems PS-1715 from LeCroy 93xx scope
                          470uF 200V Nichicon GF x2 prinary side units.
                          820uF 6.3V Nichicon PF for soft starting.
                          2200uF 6.3V Nichicon PL before and after +5.2V (6A) and -5.2V (8A) output inductors.
                          220uF 35V Nichicon PL before and after +15V (4.5A) and -15V (4.5A) output inductors.
                          1000uF 25V Nichicon PF at 15V fan output.
                          UF5402 x2 (in common cathode configuration) each for +15V and -15V rails.
                          SB540 x2 (in common cathode configuration) for -5.2V rail.
                          20CTQ040 for +5.2V rail.
                          MAC228A AC adaptation TRIAC with MJE13003 driver.
                          MJH16006A primary switcher with BUK454-800B auxiliary switcher.
                          KBU6J primary rectifier.
                          Even the monitor section (made in Taiwan) used quality Japanese electrolytics.
                          • PeteS in CA
                            • Aug 2005
                            • 3581
                            • USA, Unsure of Planet
                            #1253
                            IIRC, the 93xx LeCroy scopes were from the early 90s. The MJH16006 is a bipolar transistor. The original MJE1300x series was dubbed by Motorola the "Switchmode series" the first series of parts they designed specifically for SMPSs (the MJE1300x was in TO-220, while the TO-3 - actually, TO-204, but the difference is subtle - parts were the 2N654x). There was a Switchmode II series, and the MJE1600x was Switchmode III series; "MJH", IIRC, means a TO-247 package. At the time this P/S was designed, Nichicon's PL series was probably its best Low-Z series; with RoHS compliance. the series name was changed to PM.
                            PeteS in CA
                            • SuperDuty
                              • Mar 2011
                              • 299
                              • France
                              #1254
                              An early 90's Phihong PSA-1454 145W AT power supply, that thing is built like a tank, the case is made of 1mm thick steel ! It came from an unbranded case from a local assembler, and if I recall correctly, it was powering a TI 486DX2-80 based system.
                              The fan is a ball bearing Matsushita brushless fan.
                              Primary caps are large 200V 470uF Nippon Chemicon, the rest are a mix of Rubycon and Nicon (are these good?).
                              The main transformer is huge for such a low power :
                              Overall a very nice quality PSU. The weird bit is that the wiring is coming out of the side of the case instead of the back.
                              • Behemot
                                • 4845
                                • CZ
                                #1255
                                Nicon is not a good brand I think, and 1 mm steel is pretty common amongst mediocre and better PSU's.
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  Looks reasonably well built. At least the caps are adequately sized for the job, even if they aren't the best brand.
                                  • Wester547
                                    • Nov 2011
                                    • 1268
                                    • USA.
                                    #1257
                                    I have a question about APFC PSUs... since (if I'm not mistaken) an APFC design increases the ripple frequency on the output as well as the input, does that mean with a half-wave rectified output (single ad two switch forward) and schottky barrier rectifiers on the secondary that the freewheeling diode is still necessary in APFC PSUs (to avert reverse voltage spikes because of half-wave rectification on the output), on the secondary, or is it different?
                                    • Behemot
                                      • 4845
                                      • CZ
                                      #1258
                                      Freewheeling diode has nothing in common with PFC at all. It has to be there to close a circuit where secondary inductor acts as a voltage source. This circuit works when switcher is off and no power is being transmitted to secondary.
                                      The power is basically transmitted in bursts which than power the load on secondary and also charge inductor. When no power is transmitted, inductor discharges. This lowers output ripple as otherwise there will be no power at all when switchers are off and power is not transmited, resulting in regular voltage drops. You could deal with that using huge bulk capacitance, but it is somewhat non-practical as you can use just inductor and reasonable sized caps…
                                      I have thee feeling I have already told you this, haven't I? Maybe it was not that clear…
                                      • SIDMX
                                        • Nov 2010
                                        • 165
                                        • Mexico
                                        #1259
                                        Acteck/Edge Systems AFB500-P 500W
                                        Primary caps-------2x 560uf/200v
                                        5VSB Switcher-----2N60
                                        Primary Switchers --2x JME13007
                                        12V Rectifier-------Mospec F12C20
                                        5V Rectifier--------Mospec S16C45
                                        3.3V Rectifier------Mospec S10C45
                                        5VSB caps----------2x 470uf/10v
                                        12V caps-----------1000uf/16V
                                        -12V caps----------470uf/16V
                                        5V caps------------1000uf/10V
                                        3.3V caps----------2X 1000uf/10V
                                        Well there's not so much to tell about this POS except that this thing actually shutdowns and don't explode when overloaded or shorted, all caps are ChengX and sadly the market in my country is flooded by this lousy brand/type of PSUs, in fact it is the most used in generic PCs, altough not by me.
                                        It looks to me like a 180W-200W PSU but what do you think ?
                                        • Behemot
                                          • 4845
                                          • CZ
                                          #1260
                                          With some modifications it may do 350 W quite fine, 400 W max.
                                          At what power does it shut down?
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                            Philips F9217L-50R speakers – build quality impressions and DIY surround repair
                                            by momaka
                                            More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
                                            02-15-2022, 12:43 AM
                                            Boston Acoustics HD8 – build quality impressions & DIY woofer surround repair
                                            by momaka
                                            Boston Acoustics fans, this thread might not be for you.
                                            A few years back (~2018 time frame), I picked up a set of free JVC speakers from someone on Craigslist that no one seemed to be interested in. The guy also had a single Boston Acoustics HD8 speaker – yes, just one cabinet. He said he had no idea where he got this one from or why it's only by itself. But like the JVC speakers, it was going to get tossed at the end of that week… so I came to collect, as usual. And that's all I know about this HD8. After all, I figured why not take it and see what's inside… show it to the...
                                            01-30-2022, 11:57 PM
                                            DVR camera recorder switching power supply capacitor failure really
                                            These cheap non brand capacitors at it again
                                            Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                                            Well at least I have the cameras back on line I to try the...
                                            01-22-2022, 06:28 PM
                                            DVR recorder Switching power supply Failure
                                            When I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
                                            Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
                                            This...
                                            05-27-2023, 03:03 AM
