This is a sticky topic.
Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more! -
Flyback at 350W??
You do get single switch forward, you know, among other topologies.
With ripple current through the caps being a concern (it is often designed so they can use cheapest off brand cap possible) no one would make a flyback computer SMPS... right? Please tell me no one has tried to do so...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Yeah, could be single-transistor forward as well, you are right, just thought c_hegge had it in his hands before you see…Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
http://www.jonnyguru.com/forums/show...2548#post62548
I don't know what they did to get that kind of ripple.Comment
http://www.overclock.net/t/1310456/p...00w-psu-review
Phaedrus reckons it's a flyback, not single forward, which would explain the ripple. It would also explain why Leadmen often explode under <250W LoadsI love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
The fuse might be counted as OPP or SCP, but since it's rated way too high for the 250W we have here, I'm not counting it.Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Yah. I thought the same thing. I'm sure Leadman probably think that the fuse will be fine as OCP, thoughI love putting bad caps and flat batteries in fire and watching them explode!!
It's often hard to tell them apart; the only difference is a flyback of that size would need a massive energy dump resistor. A forward converter would use a single return diode.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
And it has a pretty good transient filtering stageThe only reason I'm using it is because it has such a low load to power. I have a Hipro with the same exact specs on the label as yours, but it has 470uf 200V Elite caps on the primary, all the rest are Teapo. Mine was manufactured in May, 2007. They're good little supplies. Efficiency is meh, I got 72%-76% out of mine. It powered a Pentium D, 2GB RAM, 7300GT, and 3 hard drives no problem for over a year, other rigs it was in used less power and it's still kicking.
Power Systems PS-1715 from LeCroy 93xx scope
470uF 200V Nichicon GF x2 prinary side units.
820uF 6.3V Nichicon PF for soft starting.
2200uF 6.3V Nichicon PL before and after +5.2V (6A) and -5.2V (8A) output inductors.
220uF 35V Nichicon PL before and after +15V (4.5A) and -15V (4.5A) output inductors.
1000uF 25V Nichicon PF at 15V fan output.
UF5402 x2 (in common cathode configuration) each for +15V and -15V rails.
SB540 x2 (in common cathode configuration) for -5.2V rail.
20CTQ040 for +5.2V rail.
MAC228A AC adaptation TRIAC with MJE13003 driver.
MJH16006A primary switcher with BUK454-800B auxiliary switcher.
KBU6J primary rectifier.
Even the monitor section (made in Taiwan) used quality Japanese electrolytics.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
IIRC, the 93xx LeCroy scopes were from the early 90s. The MJH16006 is a bipolar transistor. The original MJE1300x series was dubbed by Motorola the "Switchmode series" the first series of parts they designed specifically for SMPSs (the MJE1300x was in TO-220, while the TO-3 - actually, TO-204, but the difference is subtle - parts were the 2N654x). There was a Switchmode II series, and the MJE1600x was Switchmode III series; "MJH", IIRC, means a TO-247 package. At the time this P/S was designed, Nichicon's PL series was probably its best Low-Z series; with RoHS compliance. the series name was changed to PM.PeteS in CA
****************************Comment
An early 90's Phihong PSA-1454 145W AT power supply, that thing is built like a tank, the case is made of 1mm thick steel ! It came from an unbranded case from a local assembler, and if I recall correctly, it was powering a TI 486DX2-80 based system.
The fan is a ball bearing Matsushita brushless fan.
Primary caps are large 200V 470uF Nippon Chemicon, the rest are a mix of Rubycon and Nicon (are these good?).
The main transformer is huge for such a low power :
Overall a very nice quality PSU. The weird bit is that the wiring is coming out of the side of the case instead of the back.Comment
Nicon is not a good brand I think, and 1 mm steel is pretty common amongst mediocre and better PSU's.Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Looks reasonably well built. At least the caps are adequately sized for the job, even if they aren't the best brand.I love putting bad caps and flat batteries in fire and watching them explode!!
I have a question about APFC PSUs... since (if I'm not mistaken) an APFC design increases the ripple frequency on the output as well as the input, does that mean with a half-wave rectified output (single ad two switch forward) and schottky barrier rectifiers on the secondary that the freewheeling diode is still necessary in APFC PSUs (to avert reverse voltage spikes because of half-wave rectification on the output), on the secondary, or is it different?Comment
Freewheeling diode has nothing in common with PFC at all. It has to be there to close a circuit where secondary inductor acts as a voltage source. This circuit works when switcher is off and no power is being transmitted to secondary.
The power is basically transmitted in bursts which than power the load on secondary and also charge inductor. When no power is transmitted, inductor discharges. This lowers output ripple as otherwise there will be no power at all when switchers are off and power is not transmited, resulting in regular voltage drops. You could deal with that using huge bulk capacitance, but it is somewhat non-practical as you can use just inductor and reasonable sized caps…
I have thee feeling I have already told you this, haven't I? Maybe it was not that clear…Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Acteck/Edge Systems AFB500-P 500W
Primary caps-------2x 560uf/200v
5VSB Switcher-----2N60
Primary Switchers --2x JME13007
12V Rectifier-------Mospec F12C20
5V Rectifier--------Mospec S16C45
3.3V Rectifier------Mospec S10C45
5VSB caps----------2x 470uf/10v
12V caps-----------1000uf/16V
-12V caps----------470uf/16V
5V caps------------1000uf/10V
3.3V caps----------2X 1000uf/10V
Well there's not so much to tell about this POS except that this thing actually shutdowns and don't explode when overloaded or shorted, all caps are ChengX and sadly the market in my country is flooded by this lousy brand/type of PSUs, in fact it is the most used in generic PCs, altough not by me.
It looks to me like a 180W-200W PSU but what do you think ?Comment
With some modifications it may do 350 W quite fine, 400 W max.
At what power does it shut down?Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... - Loading...
