This is a sticky topic.
  • japlytic
    • Oct 2005
    • 2086
    Microsoft Xbox 360 (Hipro HP-AW175EF3P)
    3x 2200uF 16V Chemi-Con KZE with one 1000uF 16V Chemi-Con KY.
    1200uF 6.3V Rubycon ZL and 470uF 10V LTEC LZF on +5VSB before output MOSFET.
    180uF 420V Elite GM on primary side.
    2x STP11NK50 primary side MOSFETs in push-pull configuration.
    2x STPS3045CW rectifiers in parallel for +12V 14.2A output.
    A fan is fitted inside this unit (never saw a "brick" style power supply with a fan before!)
    • Behemot
      • 4845
      • CZ
      #582
      You haven't seen my brick mode than:-D Not that it helped to solve the problem, but…now I believe it runs with greater efficiency and can even provide slightly higher output power (since rectifiers do not run on like 100 °C ).
        master hoarder
        • May 2008
        • 12175
        #583
        How did you get yours opened that far? Or did yours look like that once you opened the plastic case?
        I have a dead Lite-On built Xbox 360 brick that I can't fully open since it has thick metal EMI shields soldered all around it. It's the 203W version.
        Yes, they indeed have a tiny fan inside. I can hear it whirl when I jump-start my other working Xbox 360 power brick.
        • Jooo
          • Oct 2011
          • 222
          • Finland
          #584
          HP 365W proprietary PSU
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Awesome! And look! A TOP244 on the 5V standby!
            Atleast the caps are semi-decent in there.
            -Ben
            Muh-soggy-knee
            • ncovert
              • Feb 2011
              • 291
              Hipro HP-P150CLXA6 Rev: 02 150W ATX power supply.
              Matsushita primary caps, G-Luxon secondaries, bridge rectifier and input filtering. Another PSU with the fan blowing air into the PC case, just like the Lead Year one I posted, except it was from 1997, while this Hipro is from '99.
              • Wester547
                • Nov 2011
                • 1268
                • USA.
                #587
                ^ Hipro have done better.
                I have this power supply (these images aren't mine) but I'm wondering if the Hipro below can do 300W in earnest (it's a HP-P3527F3 that came with a dead eMachine T6536 I used to have; better than coming with a Bestec, I suppose)? I don't think it has a PFC. It only has two Teapo 470uF/200v capacitors on the primaries rated at 85C.
                Can it do what the label says?
                Or is it more like 280W continuous, 300W max?
                I see lots of Teapos in there otherwise. It's not easy to tell from the provided picture but does anyone know what else is in there cap-wise (if you click on the last image you can still zoom in more)? Does this look like a well designed PSU or have Hipro done infinitely better and is this more like a Huntkey or Bestec?
                EDIT: Thanks Scenic and Behemot.
                • Behemot
                  • 4845
                  • CZ
                  #588
                  Yes, it can. The remaining 20 W is for +5 V SB, -5 V and -12 V
                  Last image does not show.
                  • Scenic
                    o.O
                    • Sep 2007
                    • 2642
                    reuploaded the 2nd pic to my webspace, as zol.com.cn has a hotlinking protection in place..
                    http://bambooz.pytalhost.net/badcaps/HP-P3527F3.jpg
                    • ncovert
                      • Feb 2011
                      • 291
                      Got some more units in today. These are PSU's pulled from DVR/TiVo boxes.
                      3Y Power Technology CP-1074 from a DirecTV DVR R10 (made in 2005). 4 diodes, but input filtering. UCC primary cap (330uf), and a mix of Ltec's and Teapo's on the secondary.
                      Voltages and currents:
                      +3.4V 2A
                      +5V 2.275A
                      +7.5V 0.75A
                      +12V 2.5A
                      Max output 54W
                      You can see that I didn't take it out of the case, because I was lazy. But I did with the one below (it's easier to do).
                      AUTEC UPS61-1004-T from a Philips HDR212 (made in 2000). Bridge rectifier and input filtering. Hitachi HP3 primary cap (220uf), and UCC secondaries.
                      +3.3V 4A
                      +5V 2A
                      +12V 3A
                      +32V 5mA (no, I didn't mean 5A)
                      No labelled total output
                      • Behemot
                        • 4845
                        • CZ
                        #591
                        Are those Chemi-Cons or Teapos?
                        • ncovert
                          • Feb 2011
                          • 291
                          On which one and primary or secondary?
                          • Behemot
                            • 4845
                            • CZ
                            #593
                            Those brown of course:-) Seconds secondary.
                            • ncovert
                              • Feb 2011
                              • 291
                              Chemi-con.
                              • c_hegge
                                • Sep 2009
                                • 5219
                                Yup. Remember, Teapo are usually green and have small bars in the vent stamps.
                                • Behemot
                                  • 4845
                                  • CZ
                                  #596
                                  Well maybe not Teapo, I don't even remember all those crappy brands, but some look similar. Jamicon maybe? Damn, who gives a poo, change it on sight
                                  • ben7
                                    Capaholic
                                    • Jan 2011
                                    • 4059
                                    Got a dusty old compaq oem ATX PSU at school, hopefully I can get a few pics next week, its full of rubycon and NCC
                                    -Ben
                                    Muh-soggy-knee
                                    • Heihachi_73
                                      • Jun 2012
                                      • 713
                                      Nichicon switching power supply from an older model PlayStation 2 (SCPH-39002), unsurprsingly, all electrolytic caps are from Nichicon as well (the non-electrolytics are Panasonic however).
                                      A "recap" of this PCB:
                                      C003: LS 100uF 400V CE 85°C N0113
                                      C022: VZC3 1uF 50V
                                      C010: PJC3 22uF 35V
                                      C011: VZC4 0.1uF 50V
                                      C012: VZC4 0.1uF 50V
                                      C016: VZC4 0.1uF 50V
                                      C106: VZC3 1uF 50V
                                      C107: VZC4 0.1uF 50V
                                      C102: HDF2 470uF 25V
                                      C103: HDF2 470uF 25V
                                      C104: HDF2 470uF 25V
                                      C105: HDF2 470uF 25V
                                      C108: PJE4 150uF 25V
                                      This PSU was still in working condition when removed from the damaged PS2 (I found this system on the nature strip with a few missing screws and had a broken connector and ribbon cable for the power/reset button). Being an older PS2 though, the DVD drive was probably toast anyway; I have no way of testing it though. I have scavenged the 7V Matsushita fan from it since, so it's no longer complete.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        #599
                                        Doesn't look like the PS2 used that much power judging by that power supply. The PS3 PSUs are a completely different animal, though. I think I do have 1 somewhere. Will open it when I get to it someday and post pics.
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 4965
                                          • New Zealand
                                          #600
                                          Even if the DVD drive is dead you can run backups of games from hard drive if you have the right software. (That's what I do with mine now, the HDD adapter was cheaper than a new laser and loads faster)
                                          -David VanHorn
