This is a sticky topic.
    master hoarder
    • May 2008
    • 12176
    #2381
    Originally posted by Dan81
    20AWG wires for everything
    When I see that in a PSU, I can be almost certain it's a cheapie.
    200 W continuous, 300 W peak. Could probably do 250 W continuous, but it will likely run hot.
    Also, in the event of a short circuit, those 20 AWG wires rarely hold up well. I have an L&C like that melt the wires without shutting down at all.
    Also,the fan uses a 2 pin connector,but on this PCB (X-B2002 Rev:2.3) they seem to have traced the + pin to 5v as opposed to 12v on the Y-B200ATX versions.
    Check where the (-) wire on the fan goes. Could be wired to -5V (to give 10V total). I doubt it, though.
    Originally posted by goodpsusearch
    I wasn't referring to the secondary section of the psu. The combination of 33 sized transformer and 470uF primary capacitors (assuming they are real 470uF caps and not 330uF) makes it a 250W power supply.
    Exactly.
    Originally posted by pfrcom
    No comments on the Asus A-36F ?
    Looks fine to me. Definitely okay for up to 300 W continuous (which should be good enough for a decent CPU and mid-to-high end graphics card)... Provided the 12V rectifier is rated accordingly, though.
    • c_hegge
      • Sep 2009
      • 5219
      Yup, the primary side on yours (Dan81) will probably limit you to about 250W. pfrcom's unit has much larger 820uF primary caps and an ERL-35 transformer. His probably will handle 350W due to the beefier primary side. I'm guessing that the secondary side is probably a bit beefier too.
      • Dan81
        SNES-powered
        • Oct 2013
        • 1866
        #2383
        Oh well,at least can I trust it to run this rig? (given I install a beefier 12v rectifier):
        Athlon 64 x2 5600+
        GT440 1GB
        2GB RAM
        MSI K9N-SLi
        1TB HDD
        CD-RW\DVDROM & DVD-RW drive
        Main rig:
        Gigabyte B75M-D3H
        Core i5-3470 3.60GHz
        16GB DDR3-1600
        Samsung SH-224AB DVD-RW
        Delux MG760 case
        • c_hegge
          • Sep 2009
          • 5219
          Yeah, it would probably work.
            master hoarder
            • May 2008
            • 12176
            #2385
            Athlon 64 x2 5600+: 89W TDP
            GT440 1GB: 65W TDP
            HDD: 5-12W
            total minimum 12V rail wattage: about 160W (13.3 Amps)
            Multiply by a "fudge factor" of 1.5 to have some headroom for optical drive, chipset, RAM, and etc.
            Total PSU wattage: 160 * 1.5 = 240 Watts. So yeah, that PSU should run it. Might get a little warm, though.
            • Stefan Payne
              • 1267
              Acquired these two recently - seem like reasonable quality to me - interested to know what the power supply aficionados think of them
              Asus A-36F
              First three pics - apologies for the blurriness
              Teapos in the secondary look OK
              Looks a bit like my ST-65ZF...
              • Stefan Payne
                • 1267
                Annyone know who did this unit?
                Has all Fuhyyju and JunFu caps, though a decent Power Logic fan...
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Looks like it could be Jou Jye, not 100% sure though. What does the writing on the main transformer say? Do you have a picture of the label?
                  • Dan81
                    SNES-powered
                    • Oct 2013
                    • 1866
                    #2389
                    Maybe ATNG or Topower?
                    Main rig:
                    Gigabyte B75M-D3H
                    16GB DDR3-1600
                    Delux MG760 case
                    • Stefan Payne
                      • 1267
                      hm, could be. Seems pretty decent to me, what's your oppionion?
                      ERL39-10A, nothing more.
                      Nope
                      Says:
                      +5VDC/30A
                      +12VDC/14A
                      -12VDC/1A
                      -5VDC/0,5A
                      3,3VDC/14A
                      VSB/1,5A
                      No Combined power ratings...
                      Modelname is SH300A8H+P4.
                      Has an FCC Number though, D711121, but that didn't turn up anything...
                      Datecode seems to be from 2001, August...
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        You know, this thing actually reminds me of a Sky Hawk PSU I saw a while back. I think it also had SH before the standard "EEL" markings on the transformers. They were pretty active as well back in 2001.
                        What are the switchers, 2SC2625?
                        Input capacitors look like 820uF or even 1000uF.
                        I think it could do 350W no problem if it has those switchers. It'd probably need a 12V rectifier upgrade though if you wanted to use it in a modern system. Nice that it has at least PPFC. I bet if there's two slots for 12V, two schottkys would probably bring this thing over 80% efficiency on 230V.
                        I like that it uses a Power Logic fan. Is it sleeve bearing or ball bearing?
                        • Stefan Payne
                          • 1267
                          Switchers are 2SC3320 (or something like that)
                          Input caps are indeed 1000uF, but those F-thingys...
                          I didn't see a slot for a second +12V Schottky, just one it seems...
                          And the fan is a sleeve bearing, of course
                          But yeah, it is a Sky Hawk PSU...
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            Whoops, that's what I meant, the 15A ones. 15A is plenty for 300W. It's probably down rated because the airflow must be atrocious in that thing.
                            Yuck. Should be fine in the voltage doubler though, the only place Fuhjyyu can last.
                            It does look pretty good. If you're going to use it, I'd oil that sleeve bearing fan. If you were thinking about tossing it, I bet you the member goodpsusearch would gladly pay you shipping for it
                            • Behemot
                              • 4845
                              • CZ
                              #2394
                              Seems like some FSP too.
                              Connecting primary and secondary heatsink, yeah baby! Is there any insulation?
                              • Stefan Payne
                                • 1267
                                naa, just a plate between those two and the screws, no insulation of any kind.
                                • Dan81
                                  SNES-powered
                                  • Oct 2013
                                  • 1866
                                  #2396
                                  Final guess from me would be Hipro.
                                  Anyways,I found a quite similar PSU:
                                  https://www.badcaps.net/forum/showth...&pp=40&page=28
                                  It's the Modecom on the top.
                                  EDIT:Finally found the oem of both - Dee Van Electronics. Notice the DVE logo on the Modecom label. I googled the Skyhawk's label and it has it as well. (look for a small triangle with the DVE letters in it)
                                  Main rig:
                                  Gigabyte B75M-D3H
                                  16GB DDR3-1600
                                  Delux MG760 case
                                  • Stefan Payne
                                    • 1267
                                    Something different. The OEM was more or less easy to find -> used their UL File Number on the label.
                                    This is a 250W PSU. Guess who did it ;-)
                                    • Pentium4
                                      CapXon Be Gone
                                      • Sep 2011
                                      • 3741
                                      Hmmm. Looks like an old Bestec
                                      • Stefan Payne
                                        • 1267
                                        That's because it is
                                        Got those two with another FSP one, all rather old (pre Y2K ones, it seems).
                                        • Pentium4
                                          CapXon Be Gone
                                          • Sep 2011
                                          • 3741
                                          Yeah, looks like 1998. I think it looks good for 250W. They were a little ahead of their time for a low end unit, not using half bridge in 1998. Funny how their cap choice was better 17 years ago. CEC>CapXon
