Dell model L275E-01 pn: Wu142. Optiplex 755 small form factor.
  • Jackching
    • May 2017
    • 127
    The computer wouldn't turn on this morning. No visual signs of bad components. Can't get the diagnostic light to even come on. Has anyone worked with this unit?
    • 31071
    Re: Dell model L275E-01 pn: Wu142. Optiplex 755 small form factor.
    how's the fuse?
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Originally posted by stj
      how's the fuse?
      +1
      Since this is an APFC unit, first check the input fuse for continuity, along with the input inrush NTC/thermistor. If the APFC is faulty, one of those usually goes with it.
      If these are both fine, you probably have bad caps causing the 5VSB to misbehave. I see lots of blue Ltec caps, and those are known to be very problematic. Can often go bad without any visual signs too. So for this reason, I now replace all Ltec caps on sight.
      • Jackching
        • May 2017
        • 127
        Originally posted by momaka
        +1
        Tested the fuse and caps which all read good. The thermistor is what I'm unsure of. There is a big reddish brown one there and a couple of blue ones if I'm looking at the right components.?
          • 31071
          no, your not.
          the thermister is green with a rough finish - it may be hidden in heatshrink.
          you have my interest though - what reddish brown thing???
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            I think he's referring to the polypropylene/film cap (behind the bridge rectifier, on the lower left corner on the PCB in his picture.)
            The thermistor should be that green disc component next to the square light-blue X2-cap (or is that a relay?)
            That said, if you feel comfortable with working around line voltages (warning: this could be very dangerous if you're not careful), try measuring the voltage across the primary electrolytic input cap with the PSU plugged into the wall. It's located on the upper-left corner of the PCB, next to a large toroid. The voltage should be either somewhere around 160-170V DC if you have 120V AC line voltage (which you should since you are in Canada) or 340V for Euroland and countries with 220-240V AC line. Let us know what voltage reading you get on this cap. Again, be very -CAREFUL- while doing that measurement, because you will be working around line-connected components (shock hazard!) In particular, do not touch any of the PSU parts (especially heatsinks) while the PSU is connected to the wall. Also advisable you wear safety glasses, should you happen to short something by accident, which may result in solid state components to blow up and throw fragments towards your eyes/face.
            • Jackching
              • May 2017
              • 127
              Instead of blowing my face up, i just went to the local computer store and they had a used PS for $20. Thanks for all the help though.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                Well, it's not that dangerous if you take all the precautions.
                But yeah... if you can find a replacement easily like you did (as this is not exactly a standard ATX PSU), then you might as well go with that option... unless of course your intention is to learn about fixing power supplies - in which case, fixing the old one would be good for practice. But if that's not the case, then you are all set, more or less.
                P.S. maybe dump the old PSU on Craigslist or eBay for cheap/free rather than trashing it, in case anyone out there wants to try fixing it.
                  • Jul 2011
                  • 6040
                  I have repair a couple of this type and they are a pain in the ass to do everything is cramp in a small place
                  • Duranitron
                    • Jul 2014
                    • 544
                    • Philippines
                    Hello gud day! Can you help me. I also have a problem with this power supply L275E-01 of optiplex 755. can you pls. tell me the value of the thermistor that is connected to the relay, mine exploded and shattered beyond recognition. what i have is the parts number RT001 and a piece of the thermistor beginning in SCK. because without these thermistor you cannot power the supply. Open circuit. thanks in advance mate.
                    Never stop LEARNING because life never stops TEACHING!
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      I don't have an exact part number for you, but SCK 054 is a very commonly used NTC thermistor for power supplies, so you can try that first, at least as a test. (Generally, most cheapo gutless PSUs will have one, so if you have some spare junk PSUs, have a look inside them.) I see this power supply has Active PFC, though, so an NTC with lower resistance may be needed for long term reliablity. SCK 2R55A or 15SP 2R5 would be a slight upgrade in S.S. current (5 Amps vs. 4 on the SCK 054.) Or you could also try SCK 106 (10 Ohms cold, 6A S.S. current)... though, I don't know if the APFC circuit will like a cold NTC resistance that high.
                      Speaking of Active PFC (APFC), I see the pictures from the O/P in the first post shows this PSU as having a CapXon primary capacitor.
                      If your NTC thermistor has exploded, there is a very high chance that CapXon primary cap has gone either open-circuit or low-capacitance/high-ESR. If you don't have a meter to check it, I suggest you replace it. CapXon primary caps are known to go bad in APFC circuits sooner or later. For your replacement, make sure to use a 450V cap, and not anything lower, especially if the primary controller is a CM6800 variant.
                      Also, before purchasing or replacing the NTC thermistor and a primary cap, also check the APFC MOSFET(s) and APFC diode - these can go bad/shorted if the primary cap has gone O/C or high ESR. Sometimes, even the primary PS transistors and 5VSB IC can be damaged too. It all depends on if that primary cap went bad, and how quickly. But exploded NTC thermistor generally means something really must have pulled a lot of current. Therefore, it's a good idea to check as many parts on the primary side as possible.
                      Once you're done checking, and everything seems to be OK, use an incandescent or halogen bulb in series with the PSU line input. 150 to 300 Watts is recommended, as this is an APFC PSU. A 100W bulb or lower may blink rapidly when trying to turn On the PSU (even without a load) due to the APFC circuit.
                      • Duranitron
                        • Jul 2014
                        • 544
                        • Philippines
                        thanks for the reply sir. I think these thermistor has a high resistance than normal because these thing is in parallel with the relay switch that blue plastic box. I thinks it gives off small amount of voltage to power the circuit in standby mode and by pressing the switch button located on the back of the power supply it powers the relay to switch it on at max power. that is why i need the exact part number of the thermistor. thanks again! cheers!
                        • Duranitron
                          • Jul 2014
                          • 544
                          • Philippines
                          i already replaced the mosfet 20MN60 the 180uf 420vdc capacitor, 6.3 amps fuse, quad rectifier diode GBU810, i need to test it but these thermistor is the problem, so i put an ordinary thermistor just recently the problem is the psu will not turn off. because the thermistor is in parallel with the relay switch. any suggestion?
                          • Duranitron
                            • Jul 2014
                            • 544
                            • Philippines
                            the original problem of these psu, the capacitor exploded may be it shorted out, shorting out all the parts in the high voltage area.
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              Not exactly, but close.
                              The thermistor doesn't give a "low voltage" to the standby circuit. It simply acts as a high series resistance device when the PSU is first plugged in, so that the main/primary cap doesn't pull too much current and possibly trip a breaker or blow the fuse. After this, the thermistor warms up a bit and its resistance drops drastically. Many power supplies - even a good number with APFC - do NOT have a relay in parallel with the thermistor, so these PSUs pull line current through the thermistor at all times (both for standby and main PS functions.)
                              With that said, you DON'T actually need an exact part number. If the thermistor keeps blowing, there may be other issues with this power supply. Even the relay itself could be bad (bad/high-resistance contacts or too much switch bounce.)
                              So try any thermistor you have that is close to the ones I suggested above and test the power supply. If PSU is not working correctly, then it's not the thermistor that's the issue and you'll just have to re-check everything on the primary side again.
                              • Duranitron
                                • Jul 2014
                                • 544
                                • Philippines
                                the thermistor doesn't blow up it is working perfectly now with the thermistor i pulled from a lot of cheapos psu, the psu is working perfectly now all voltages in secondary are correct i already installed it in and the pc its working perfectly. my only problem is it doesn't power off. i can hear the relay clicking but it cannot power off. may be all the thermistor i used had a very low resistance or some kind. i don't want to buy a lot of thermistor with different cold resistance just for experiment.
                                  • 31071
                                  the relay and thermister are to save power, not for turning off.
                                  the turning on/off is done by the motherboard sending a signal to the main supply that you need to follow.
                                  maybe a bad transistor or opto isolator.
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    • Bulgaria
                                    That's not how it works.
                                    If the PSU is not turning Off after turning On, first try using it on a different motherboard/PC to make sure there isn't something with the settings on the PC you are testing with. If that's not the case, then it may be as stj suggested: stuck/bad opto, or any component related to the main PS enable circuit. It is most definitely NOTHING to do with the thermistor.
                                    Not sure about that. :\
                                    A "hot" thermistor will draw about 0.5 to 1W of power, whereas a relay will draw maybe 1/2W or less, depending on the relay. I think the relay may be there for a different purpose - possibly something to do with the APFC caps charging up and drawing a lot of current when the APFC activates.
                                      • 31071
                                      it's getting pretty common in europe now to bypass hot thermisters with a fet/triac or relay just to save "something" or reduce heat output.
                                      we are under the thumb of the scum that are obsessed with carbon!!
                                      i was watching an eevblog video earlier where the government there was giving free replacement led panels to company's using flouro-tubes.
                                      dave had some and they flickered like fuck - he did an analysis of the psu and it was intentional to get the good power-factor numbers for cheap!!!!
                                      • Duranitron
                                        • Jul 2014
                                        • 544
                                        • Philippines
                                        thanks for the suggestion mates! i already repaired the psu by placing a thermistor sck054 and replacing the opto isolator 817B. now the psu is working perfectly and can be turn on and off. i think the relay is for in rush current protection an old 2005 design, now a days they omitted the relay and just place the thermistor. Thank you very much for the help and sharing your expertise.
                                        • DenSDen
                                          Bios OptiPlex Small Form Factor Plus 7020
                                          by DenSDen
                                          Hello everyone!
                                          I have a PC that does not see either a discrete card or an m2 SSD. The integrated graphics only outputs a picture to one of the three DP connectors. Someone has already flashed the BIOS. I suspect that the BIOS is crooked.
                                          Please help me figure this out. I can't figure it out myself. I am attaching backups and markings.
                                          Thanks in advance!
                                          Service Tag: H9H3R34
                                          Express Service Code: 37578223840
                                          board vh0216
                                          04-04-2025, 09:00 AM
                                        • lzeta
                                          OptiPlex 5080 Small Form Factor Bios
                                          by lzeta
                                          Hi, I need bios file for OptiPlex 5080 Small Form Factor
                                          service tag JYL58B3
                                          I don't have the original dump because I've erase the eeprom and the usb where I've saved original isn't working anymore. I'm trying to recover it.
                                          12-11-2024, 03:39 AM
                                          DELL OptiPlex 5040 OptiPlex i3-6100 Specification for Upgrade or Repair
                                          This specification for the DELL OptiPlex 5040 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 5040 boardview and OptiPlex 5040 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:44 PM
                                          DELL OptiPlex 5040 OptiPlex i7-6700 Specification for Upgrade or Repair
                                          DELL OptiPlex 3040m OptiPlex i5-6400T Specification for Upgrade or Repair
                                          This specification for the DELL OptiPlex 3040m can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3040m boardview and OptiPlex 3040m schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
