Kada 852d+ need schematic
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3607
    • slovakia
    Re: Kada 852d+ need schematic
    damn. still not solved. still running full throtle after few seconds
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3607
      • slovakia
      but why it worked after desoldering ic? maybe just another heat to make some component work normal
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3607
        • slovakia
        So i think i have broken controller of temp. I try to hook up my iron from another station and it wont turn off on temp like the hotair.
        looks like everything is controlled by that long IC in socket, but it is absolutely nothing marked on it
          • 31086
          count the pins and see where they go - or atleast the power goes on it.
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3607
            • slovakia
            loos like it have voltage from that 5V regulator LMxxxx
            Voltage looks everyvhere ok on its pins.
            i was thinking that compressor looks after sensor to cool and shut off, but after power off it cools heater right one minute before turn off, so it is not controlled by it
            so sensor driven controller circuit not work
            • NIRMAL GSM
              • Dec 2019
              • 5
              • india
              #26
              Maxx 8550 repair manual
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                #27
                I have a KADA 852D+.
                Have not torn apart into it in years... but let me know if you still need any info, like where wires connect and whatnot.
                Mine was a 230/240V version that was re-wired as a 120V version by simply changing the plug by whoever sold it to me. Luckily, I found another transformer from a similar dead station and wired the two transformer outputs in series to get the proper voltages.
                • Dreyes2020
                  • May 2020
                  • Argentina
                  #28
                  Someone has a connection to the cables, I burned a resistance, I don't know what value it is
                    • 31086
                    • redwire
                      • 3910
                      It's dead Jim
                      • cevat1
                        • May 2018
                        • 6
                        • Türkiye
                        #31
                        • liquidzorch
                          862D+ solder station iron out of control when fan on
                          by liquidzorch
                          Hello.
                          I have a soldering station, 862D+, and every time the hot air gun is on, even if it is just cooling off, the soldering iron controller stops controlling. Let me explain what has happened so far, as it took a while to get to this.
                          First, the switch that turns on the hot air gun started to fail, the light came on, but temp never rose, I would have to switch it multiple time to get the gun to start heating, this was due to the contact inside being carbonized. I opened the switch up, clean the contacts, and it would work fin for a while until carbonized again. So, I ordered a switch...
                          06-09-2022, 08:49 PM
                        • TinkerTron
                          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                          by TinkerTron
                          Hey everyone,
                          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                          Instead, here's what's been bugging me so far:
                          The schematic...
                          03-06-2025, 02:03 PM
                        • atunguyd
                          Acer x163w Monitor PSU schematic
                          by atunguyd
                          Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                          The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                          03-05-2025, 02:08 PM
                        • Thetechdude
                          MSI Ventus RTX 4080 16G Broadview schematic needed
                          by Thetechdude
                          Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                          I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                          Thanks.
                          07-15-2025, 11:15 AM
                        • ianpoultonknights
                          Zenbook Flip 15 UX562AI schematic
                          by ianpoultonknights
                          Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                          06-26-2025, 02:41 PM
