Did the fet kill this board?
  • dropfry
    • May 2009
    • 19
    I removed the bulging caps. The other side looks fine.
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Did the fet kill this board?
    It wouldn't be the first time that caps placed too close to a heat sink got their guts cooked.
    Crap caps like these are more susceptible to heat though. In your case I would say it's just crap caps. Replace all of the caps in that area (the secondary side).
    That's not a FET it's a Schottky diode package. With two diodes connected as seen printed on the case (common cathode).
    • lucky13
      • Aug 2007
      • 412
      Which way this board orients in the unit?
      Looks like the ac side is the other end so this end would be on top?
      Well, nothing like two "hot" elements baking these crap caps....
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
        by momaka
        03-15-2023, 10:17 PM
      • black6host
        Replacement caps for Samson Resolv studio monitor 65A Amp board.
        by black6host
        Good day!
        I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
        I'm going to replace the caps and I'll be the first...
        02-06-2024, 08:22 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
