Replacing 11N120CND with IRG4PH50UD
  • CidiRome
    • Jan 2015
    • 49
    • Portugal
    Hi people.
    I'm trying to diagnose a 3000VA UPS that has 3 11N120CND blown and also a few other minor components.
    Can I use IRG4PH50UD to replace 11N120CND at least for testing proposes or even permanently?
    I've been trying to compare the datasheet and the most obvious specs seem to be close enough, but I would like your opinion about this.
    Also the IRG4PH50UD were salvaged from an older APC UPS that I couldn't repair, so they should be of decent quality and recycling is always good.
    Cheers.
    Re: Replacing 11N120CND with IRG4PH50UD
    Why don't you upload the spec sheets so people here can see tell you if they will be compatible or not?
    • CidiRome
      • Jan 2015
      • 49
      • Portugal
      Hi.
      I didn't think about that because they are quite easy to find, any way.
      I attach the datasheets now.
      Cheers.
        • Jul 2011
        • 6070
        Cheers.
        Maybe look at the supporting components around both devices and see what is the same and what is different
        If for the most part they are the same then it might work or you might have to change some supporting components
        • Reintar
          Dell Inspiron 15 7567 (LA-D993P) - No power after replacing blown inductor and shorted mosfet advice needed
          by Reintar
          First of all, I'd like to mention that I'm a novice when it comes to laptop repair, although I do have some experience with soldering.
          One day, my laptop experienced a severe stutter, and after rebooting, it failed to boot into Windows. I decided to disassemble it and found that the PL900 component was blown. Later, I came across a post (https://www.badcaps.net/forum/troubl...error%E2%80%99) with the same problem, where...
          08-30-2024, 06:13 AM
        • DeXXter
          Replacing SOC SRK08 clean me needed?
          by DeXXter
          Hello, so I replaced a soc SRK08 (i3-1115G4) on a hp 14-dq because the 1.8v power supply was shorted and the pch was gone and I installed a SRK05 (i5-1135G7) that I had at hand. And I was wondering if a clean me region is needed after replacing the chip, I usually do this on laptops with separated pch, but with a soc (cpu and pch together) I have no idea. Normally I wouldn't ask this, but I have only the motherboard, no screen nor the adapter, and after I fix this I have to send it to another region so if someone knows about this, some help would be apreciated.
          Note: After doing all...
          11-19-2025, 03:16 AM
        • competition
          Replacing capacitors in Evga PSU
          by competition
          I have Evga G2 1300w and I want to replace all the electrolytic capacitors because PSU is already 12+ years old and I want to give it more life before any capacitor does damage. There are no blown capacitors, but I want to protect myself by replacing them with new ones as a precaution. And now comes the main problem. I have 5 pieces of Bulk (I think they are KZE) 16v3300uf with dimensions 10/35/5, but I can't find them in that size, only 12.5/35/5.I have one KY 16v1000uf 8.5/19/3.5, one KY 16v220uf I think it is 6/13/3.5 but it is in holes of pitch 5 I have 4 pieces of KZE 16v2200uf with dimensions...
          11-14-2025, 11:12 AM
        • doivaythoiem
          Need help with replacing the 12th generation CPU on a gaming laptop.
          by doivaythoiem
          Status: I have a 12th generation Acer Nitro laptop with the main code HH514 LA-L973P REV 1A and the CPU is faulty. I replaced a CPU from an Acer mainboard of the same type and it worked, but the CPU had an error and couldn't enter Windows. Next, I replaced a CPU from a Dell laptop that was still working but had a VGA error. After replacing it, I flashed a new bios from the Acer manufacturer, but the machine still couldn't work. Can someone answer this question? Thanks.
          11-06-2025, 01:29 AM
        • madscientist750
          Replacing electrolytic caps by solid caps on old motherboards
          by madscientist750
          I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
          I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
          I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
          10-19-2025, 06:10 AM
