Power Adapter Sony VGP-19V10 Not Working - Help Please
  • SoporteHR
    • Sep 2018
    • 80
    • Venezuela
    Hello to all friends of the forum.
    I consult the following:
    I have a Sony Brand Laptop adapter, model VGP-AC19V10. Departure from 19vdc to 4.7Ah
    The fault is that it does not turn on, disarm it to verify the fuse and it is correct, I was measuring voltages and the 160 vdc that comes out of the bridge rectifier is present, after that they pass through a resistor network forming a voltage divider and I have 50vdc. of that voltage, through another resistance low to 1vdc and arrives at the integrated one that in the photo is not present (L6562 PFC).
    This integrated is not receiving the supply voltage in its pin number 8, which comes from the transistors that are up, but these transistors also do not get voltage.
    I went further to the right and I do not have any tension in the winding of the transformer.
    The large capacitor also has no voltage.
    I already take out the basic components, diodes, some resistances, the power mosfet, all are fine. They are not open or short.
    I understand that this integrated must receive voltage in an instant to activate, close the mosfet and pass the 160vdc to the primary winding of the transformer, and then feed back, but it is not doing it.
    So, my question is, really, how can I prove that chip? to know if it's okay.
    What else can I check?
    Attached photo of the card. The yellow dots are the ones I checked and I put the ones that have tension and the ones that do.
    there are 50 volts that are lost, they do not go anywhere, then there is a voltage of 1vdc that reaches IC1.
    The red dots are the components that you remove from the card and verify with the multimeter.
    Thanks in advance and I remain attentive to your valuable comments
    • Jul 2011
    • 6059
    Re: Power Adapter Sony VGP-19V10 Not Working - Help Please
    Ok
    Can you please post a photo of other side of the board
    Also can you please post the part of the IC chip that on this side of board
    • SoporteHR
      • Sep 2018
      • 80
      • Venezuela
      Only integrated on side tracks
      • SoporteHR
        • Sep 2018
        • 80
        • Venezuela
        Hello, SAM_SAM_SAM
        I post new Photo. Thanks
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Close, but it functions a bit differently.
          You should have 160V on the primary cap and on one of the transformer pins. From what I traced, that transformer pin should be the one next to the "R12" resistor marking.
          That fact that you don't have 160V going to the primary cap suggests the problem is before that, because the primary cap should always be connected to the mains.
          That said, I think your power adapter might have an APFC circuit. And if I am correct, then the APFC inductor should be L2, which I see is remove from your power adapter. Without this inductor, you will NOT get 160V on the primary cap. So make sure that is in there and report back if you get 160V DC on the primary cap and that transformer pin.
            Need clear straight shot of the WHOLE top and bottom side of the board.
            • SoporteHR
              • Sep 2018
              • 80
              • Venezuela
              Re: Power Adapter Sony VGP-19V10 Not Working - Help Please - Solved
              Hi all.
              Thank you very much for the time it took to help me.
              The case is already resolved.
              The problem was coil L1 (marked in green). The PCB pad was broken, very close to the welding point, so I did not see it initially.
              When you told me to revise the energy intake stage again, I noticed that cut because the pad moved.
              I cleaned the solder mask and corrected the damage in the PAD that connects the coil L1 with the resistance R51, I did the same with the other end of L1 with R20.
              When connecting the adapter to the electrical power, the power was established at one end of the transformer and at the C1 capacitor of 160vdc.
              The output remains stable at 19.4vdc.
              I include photos with the voltages measured for future reference to anyone who has an adapter that is similar or similar to this model.
              Thanks again everyone for the help.
              Case closed.
              Sorry, i used google translate.
              Spanish / Español.
              Hola a todos.
              Muchas gracias por el tiempo que se tomaron en ayudarme.
              El caso ya está resuelto.
              El problema era la bobina L1 (Señalada en verde). El pad del PCB estaba roto, muy cerca del punto de soldadura, por eso no lo vi inicialmente.
              Cuando ustedes me indicaron que revisara nuevamente la etapa de entrada de energía fué que me percaté de ese corte ya que el pad se movió.
              Limpié la mascara de soldar y corregí el daño en el PAD que une la bobina L1 con la resistencia R51, hice lo mismo con el otro extremo de L1 con R20.
              Al conectar el adaptador a la energía electrica, se establecio la alimentación en uno de los extremos del transformador y en el capacitor C1 de 160vdc.
              La salida se mantiene estable en 19.8vdc.
              Incluyo fotos con los voltajes medidos para futuras referencias a quien tenga un adaptador igual o similar a este modelo.
              Gracias nuevamente a todos por la ayuda.
              Caso cerrado.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                Good job with the repair!
                And thanks for providing some voltage measurements - those could come pretty handy if someone needs to troubleshoot one of these.
                Looks like the power adapter must have been dropped for that trace damage to occur. Such things can be hard to spot, but you did it anyways.
                • SoporteHR
                  • Sep 2018
                  • 80
                  • Venezuela
                  Hello Momaka
                  Receives a warm greeting.
                  Thank you very much for your words.
                  It really is difficult to detect that type of failure and I agree with you, most likely it was a fall, because the L1 coil is large, it should move when the adapter fell and despite having the silicon to hold it, if I move it lightly with my finger , the coil moves.
                  I already put glue on top to prevent movement and to affect the welds again.
                  To order, it seems correct to publish the tensions, it is a great guide for future references.
                  Greetings and thanks for your time and help.
                  • Fernon@Repair
                    Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                    by Fernon@Repair
                    i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                    VCCIO voltage ok
                    VCCSA Voltage OK
                    VCCPLL Voltage OK
                    Ram Voltage ok
                    RamVTT OK
                    VPP 2.5 OK
                    But No Core Voltage
                    and i want to this vrm ic datasheet or pinout (ISL69269)
                    anyone have this ic pinout voltages?...
                    06-25-2025, 07:19 AM
                  • electron_jj
                    Panasonic TH-L42D25A checking the PSU output voltage
                    by electron_jj
                    Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                    I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                    08-29-2021, 08:13 AM
                    Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                    by sam_sam_sam
                    I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                    The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                    Now...
                    06-09-2024, 10:57 AM
                  • Carlos#2003%
                    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                    by Carlos#2003%
                    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                    02-15-2024, 07:52 PM
                    ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                    3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                    Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                    core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                    configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                    serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                    Based on Intersil's Robust Ripple Regulator...
                    11-05-2024, 03:24 PM
