Laptop charger output overvoltage.
  • stuart06
    • Apr 2008
    • 7
    I wondered if anyone would be so kind to offer assistance concerning the following please.
    I have recently inherited a Toshiba Qosmio G20-115 laptop in a non functional condition.
    The machine does not power on at all with the on/off switch and I suspect the battery is totally discharged although I haven't tested it at the time of writing this.
    When the mains charger/adapter is connected to the machine the DC IN icon emits a sequence of ‘blinks' which I have managed to decipher it and it represents the 10h error code as shown below.
    I have tried removing the battery and the charger and re-connecting.
    The charger/adapter is rated at:
    Output 15v/8a/120w
    I have measured(without load)the DC output from the charger and it is 16.14v.
    I was wondering if anyone could point me in the right direction as to which component(s) I should be testing/replacing in the charger/adapter in order to reduce the output voltage back to 15v.
    Many thanks in advance.
    The below is taken from the service manual.
    DC IN icon Power supply status
    Lights blue DC power is being supplied from the AC adapter.
    Blinks orange Power supply malfunction*1
    Doesn't light Any condition other than those above.
    *1 When the power supply controller detects a malfunction, the DC IN icon blinks
    orange. It shows an error code.
    Error code Meaning
    10h AC Adapter output voltage is over 16.5V.
    11h Common Dock output voltage is over 16.5V.
    12h Current from the DC power supply is over 12.0A.
    13h Current from the DC power supply is over 0.5A when there is no load.
    14h Abnormal current has been sensed.
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • FrancescoV
    Onkyo HT-R390 no sound output, video output ok
    by FrancescoV
    Good morning everyone,
    I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
    The firmware reported is the following:
    M:1.00/11107BLP
    D:?.??/????????
    O:1.00/11107AL
    The DSP firmware given the question marks seems corrupt.
    On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
    05-11-2025, 02:59 AM
  • menthol
    Latitude 5300 not charging.
    by menthol
    Hi guys
    Please Help me
    I cannot charge my laptop by connecting the AC adapter to it.
    [The following is the situation]
    The laptop is just connected to the AC adapter without booting.
    1. pin 19: ACIN of Charger IC does not go HIGH when connecting the AC adapter with the battery connected to MB. (sheet 44) PR4485 is not mounted.
    2. the reason why ACIN does not go HIGH is because pin 5 of PQ4423 is set to HIGH and pin 3 and pin 4 are set to ON.
    3. When supplying power from the AC adapter,...
    06-25-2023, 10:21 AM
    07-01-2024, 06:34 AM
  • double_DD
    Why does my ISP router hate my "homemade" power supply??
    by double_DD
    It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
    So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
    For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
    07-12-2025, 03:09 AM
