Latitude 5300 not charging.
  • menthol
    • May 2023
    • 8
    • japan
    Hi guys
    Please Help me
    I cannot charge my laptop by connecting the AC adapter to it.
    [The following is the situation]
    The laptop is just connected to the AC adapter without booting.
    1. pin 19: ACIN of Charger IC does not go HIGH when connecting the AC adapter with the battery connected to MB. (sheet 44) PR4485 is not mounted.
    2. the reason why ACIN does not go HIGH is because pin 5 of PQ4423 is set to HIGH and pin 3 and pin 4 are set to ON.
    3. When supplying power from the AC adapter, 0V should be output from the OUTPUT of PU4415, but 4.7V continues to be output.
    4. 1V_CPU_CORE is outputting 0V and I think the overvoltage protection is not working.
    5. when I connect AC adapter without battery to MB, 0V is output from PU4415 and ACIN goes HIGH. However, even in this case, if I quickly turn on/off the stabilized power supply, it may keep 4.7V. When the regulated power supply is turned OFF, the OUTPUT of PU4415 rises to 1.8V and becomes 0V with decay. This itself is not a problem since this phenomenon is also seen in normal MB. In the MB in question, when the stabilizing power supply is turned on at 1.8V, the output voltage rises to 4.7V, but in the normal MB, it immediately becomes 0V.
    [Question]
     What could be the reason why the OUTPUT of PU4415 does not go to 0V with the battery and AC adapter connected to the MB?
    Please let me know if there are any other details to check, not limited to PU4415.
    [Supplemental]
     The following parts have already been replaced.
      PU4415, FD4409, PQ4423, PR4450, PR4451
    Any advice you can give me, would be greatly appreciated!
    Schematic and boardview ---> https://www.badcaps.net/forum/showthread.php?t=101483
    Last edited by Vesko356; 06-25-2023, 08:22 PM. Reason: Attached schematic removed and replaced with link.
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Latitude 5300 not charging.
    Originally posted by menthol
    Hi guys...
    Do not attach laptop schematics and/or BV in this section please!
    Schematic Requests ONLY!
    https://www.badcaps.net/forum/forumdisplay.php?f=41
    Reminder: rules and organization of this section
    https://www.badcaps.net/forum/showthread.php?t=117483
    Become a Badcaps supporter
    Thanks to all supporters.​
    • mon2
      • 14660
      Hello menthol-san.
      1) original and recommended power adapter is being used? It is important for the single wire ID check used by the logic board.
      2) measure the voltage to ground of PS_ID_R and PS_ID.
      Post the voltage measurements.
      Dell laptops use the Maxim / Dallas 1-wire communication on the PS_ID line to authenticate the power adapter details.
      • menthol
        • May 2023
        • 8
        • japan
        Hello mon2-san
        Thanks for the reply.
        A1: The adapter is a genuine DELL product.
        A2: I measured the voltage of PR_ID and PR_ID_R. It seems that the battery is doing something wrong.
         1. Only AC adapter is connected.
          PS_ID: 3.291 [V]
          PS_ID_R: 3.287 [V].
         2. Connect AC adapter and battery
          PS_ID: 0 [V]
          PS_ID_R: 0.295 [V]
        • mon2
          • 14660
          Remove all power / no battery.
          Meter in resistance mode.
          Measure the resistance across the mosfet pins to confirm if the mosfet is not defective.
          Measure:
          source (1-2-3) & drain (5-6-7-8)
          source (1-2-3) & gate (4)
          gate (4) & drain (5-6-7-8)
          for the battery mosfet @ PU4412.
          Then do the same for PU4413.
          Post each measurement. A low resistance reading = mosfet is leaky and is defective.
          • menthol
            • May 2023
            • 8
            • japan
            Hi mon2-san
            PU4412
            source (1-2-3) & drain (5-6-7-8) : 0.562MΩ
            source (1-2-3) & gate (4) : 0.602MΩ
            gate (4) & drain (5-6-7-8) : 1.002MΩ
            PU4413
            source (1-2-3) & drain (5-6-7-8) : 5.4kΩ
            source (1-2-3) & gate (4) : 52.8kΩ
            gate (4) & drain (5-6-7-8) : 95.6kΩ
            I think MOSFET seems to be fine.
            • mon2
              • 14660
              PU4413 does not look good. For mosfets, this is low resistance.
              Please flux and remove from the logic board -> allow it to cool down and measure the resistance again while it is on your workbench.
              If the resistance remains to be low, this part is defective and must be replaced.
              reference:
              https://electronicsbeliever.com/how-...0good%20MOSFET.
              See resistance check method for mosfets.
              • menthol
                • May 2023
                • 8
                • japan
                Hi mon2-san
                Thank you very much.
                Very informative and helpful.
                When measuring the resistance of a MOSFET, at what resistance level should I suspect it is defective?
                Is it necessary to have more than 200-300kΩ between each terminal to determine that it is normal?
                • mon2
                  • 14660
                  The actual resistance value can vary but should be ok if it is higher range as noted.
                    DELL Latitude 5300 Notebook 5000 Specification for Upgrade or Repair
                    This specification for the DELL Latitude 5300 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5300 boardview and 5300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5300...
                    09-06-2024, 12:13 PM
