5a lithium charger modules
  • vinceroger69
    • Mar 2012
    • 6714
    Re: 5a lithium charger modules
    just been going through some of my old purchases from aliexpress i have one of these can i use it to charge lithium batteries?
    https://www.aliexpress.com/item/LM25...72e6cd557ef8dc
    • vinceroger69
      • Mar 2012
      • 6714
      Originally posted by redwire
      Those modules use XL4015 buck-converter (step down) IC, rated 5A but those are chinese amps... so derate by 1/2 for actual use Some of these modules have tiny diodes, others have large heatsinks.
      Charging a battery, you get backfeed into the IC if input power is removed.
      It has a P-ch MOSFET inside so it should have a built-in substrate diode and not blow up if connected to a battery.
      There is a current spike when you connect only a battery at the output of the buck converter (with no input power).
      The input capacitors get charged, and maybe this is what damages the IC.
      You can add a series Schottky blocking diode at the output. Like SS54, SB540, or junkbox parts from a PC power supply.
      That diode will also make heat, several watts worth (5A*0.4V=2W) and best to have some heatsink if you are going for 5A.
      The diode will make the exact charging voltage mushy due to its voltage drop, so the IC feedback trimpot might be moved to monitor battery voltage after the new diode.
      TI Design Trade-offs for Switch-Mode Battery Chargers fig. 17-19 show the situation.
      Hi just tried this unit out unmodified using a 19v 4.7 amp laptop charger as a supply i was going to charge a 3.7v lithium battery so set output voltage too 4.2v i then tried too set the amps i cant seem too get a ready when trying too set it so i tried it on a higher output voltage 12v and could amp reading ok its just at lower voltages it dosnt seem too be able to set the amps, this module also gets hot the whole units capacitors and ic even with added heat sink maybe because im trying too lower 19v 4.7 amps down to say 4.2v 1 amp
        • Jul 2011
        • 6070
        You need to have the power supply a few volts higher than voltage that you want to use to keep from wasting the extra voltage up in heat
        This would be the way I would approach this
        Another were if you are going to use 4.2 volts as your set point then use something like this 5.5 to 7.5 or something close to it
        Or you could use something like this
        https://www.ebay.com/itm/DC-DC-5-36V...cAAOSwIIFbT2eZ
        I have used a version of this that does not have the meters on it
        You can load it up to about 4 amps and it only runs warm on the heat sink
        • budwich
          Lithium 12v tool battery charger... no negative connection?
          by budwich
          I have a drill and battery but no charger so I bought a "universal charger" 120ac in ... 12vdc out (not really universal in lithium world). Anyway it has three contacts, positive, negative and "T" (temperature sensor). I connected those contacts to the contacts on the battery. No charging happened and only the status light is on (green solid) which the label indicates "100% charged".... but the battery isn't near that at around 9v and dying. There doesn't appear to be any difference whether the battery is connected or not. I got suspicious and pulled the...
          03-18-2025, 09:12 AM
        • motormayhem
          Lenovo T460 Only Charges on One Charger
          by motormayhem
          Laptop Question
          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
          05-12-2023, 01:46 PM
          NVDC charger configuration...
          11-05-2024, 03:28 PM
        • flat-earther
          ASUS X54H laptop thinks it's always charging even with charger unplugged
          by flat-earther
          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
          Windows also shows ''Plugged in'' when charger is not connected.
          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
          If I let battery run out and say it has 3% Windows will...
          06-24-2025, 09:32 AM
        • Johndill
          Dell Inspiron 7567 LA-D993P odd charger issue
          by Johndill
          Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
          There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
          I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
          Here are the tested scenarios:
          1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
          2. With the laptop off, plug in charger (LED says on) & the front charging...
          11-16-2022, 10:55 PM
