Mackie mixer power supply no power
  • R_J
    • 9606
    Re: Mackie mixer power supply no power
    It is likely ok, I can't see any real way it could fail as there is very little current in that circuit. probably used to slightly adjust the power supply with temperature. I see values from 2k to 200k for similar ntc or ptc devices.
    • garrymc123
      • Apr 2010
      • 336
      • United Kingdom
      I've checked the thermister with my multimeter in the ohms selector and this is what i get is this ok
      Your never to old to learn
      • petehall347
        • Jan 2015
        • 4440
        • United Kingdom
        heat it and cool it and see if value changes
          So did you replace C9 as suggested? What dc V reading between the two legs of that C9?
          • garrymc123
            • Apr 2010
            • 336
            • United Kingdom
            i will do those checks and let you know
            • garrymc123
              • Apr 2010
              • 336
              • United Kingdom
              #26
              cheers guys Finally got a chance to do some checks on c9 I have 15.35vdc on the optocoupler I have 2.403vdc on the hot side and no voltage on the secondary side and on the thermister, its 99.60hms cold and 24.3ohms hot then rises back to 99.6ohms still to check u100 ic and u101 ..what do u mean by hot ground
                • Jul 2011
                • 6069
                Take a very close look a the transformer with the yellow tape on it
                In the last photo that was posted it looks like one of the terminals that is to the board does not look very good
                or the way the light is hitting it but it looks duller
                (and there looks like a lot of flux is there )
                than the other terminals that I can see I would recommend resoldering all of the pins for that transformer
                I would also think about replacing U100
                What is your voltage on the Optic Sensor on the input side which most of the time is pin 1 and 2
                  • 31246
                  so did you change c9?
                  • garrymc123
                    • Apr 2010
                    • 336
                    • United Kingdom
                    #29
                    Thanks, everyone for all your help. STJ was correct all along, new caps arrived today so replaced c9 10uf 50v which was open and now power supply up and working will stick it back in the mixer tomorrow and let you know if it powers up ok ..Thanks Again
                      • Jul 2011
                      • 6069
                      It might be a good idea to replace or check all the caps on this board
                      • garrymc123
                        • Apr 2010
                        • 336
                        • United Kingdom
                        #31
                        cheers I have checked the other caps and all seem to be within spec I have plugged the power supply back in the mixer and it has powered up ok.. I will let it run for a couple of hours and just to be sure..thanks to everyone again for there help and advice
                          • Jul 2011
                          • 6069
                          I am glad that you got it working again
                          • check12
                            • Nov 2012
                            • 103
                            Great you got it going ..what happened with your two behringer desks Garry?
                              by sam_sam_sam
                              03-31-2024, 02:12 PM
                              by sam_sam_sam
                              07-01-2024, 06:34 AM
                              Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                              by sam_sam_sam
                              I was working on this CNC machine today found no keyboard functioning no control relay powering on
                              The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                              Found shorted diodes on main controller relays there are 3 of them that...
                              01-07-2023, 05:43 PM
                            • JimBanville
                              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                              by JimBanville
                              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                              Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                              I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                              09-13-2023, 07:21 AM
