Fortron FSP145-50NI microATX PSU
  • Scenic
    o.O
    • Sep 2007
    • 2642
    well.. got it for free.. wanted to use it in a HTPC project...
    set top box DVD recorder with worn out laser (no spare lasers available.. thanks phillips -.-!) -> HTPC
    well.. symptoms:
    tries to turn on (fan moves a bit) but seems to go into short circuit protection or OLP
    5V standby is up and running fine at 5,12V
    bridging green to GND (without a board, but with load on 5V & 12V (old HDDs)) results in the same minimal fan movement and nothing more..
    replaced all secondary caps with GP Rubycons (didn't wanna waste my last ZL's in there.. gonna put those in when it works properly)
    no go..
    got the secondary heatsink w. components out.. all checked ok. (well.. no shorts at least..)
    got the tiny control PCB out and removed the yellow glue crap from it and the main PCB.. put it back together... still nothing...
    the KA7912 (for -12V) seems to be ok too..
    any ideas what else to check..?
    pics:
    http://bambooz.pytalhost.net/badcaps...s/FSP145/1.jpg
    http://bambooz.pytalhost.net/badcaps...s/FSP145/2.jpg
    http://bambooz.pytalhost.net/badcaps...s/FSP145/3.jpg
    http://bambooz.pytalhost.net/badcaps...s/FSP145/4.jpg
    http://bambooz.pytalhost.net/badcaps...s/FSP145/5.jpg
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: Fortron FSP145-50NI microATX PSU
    Is the fan free to move? Some power supplies that I use will not power on if the fan won't start.
    Edit: Just looked at the pics. Where's the fan on that thing?
    A man convinced against his will is of the same opinion still.
    • 370forlife
      Large Marge
      • Aug 2008
      • 3113
      The fan is on the top of the psu
      Is the bottom of the pcb touching the case by any chance? Any bad soldering?
      • Scenic
        o.O
        • Sep 2007
        • 2642
        fan is OK. tested it already (i had to desolder the fans wires anyways..)
        it's a standard 80mm fan in the top cover...
        http://bambooz.pytalhost.net/badcaps...FSP145/fan.jpg
        edit: PCB isn't touching the bottom. there's also a piece of plastic sheet under there..
        soldering is OK.. not too sloppy too... resoldered some joints here and there that looked suspicious.. (and removed the wires to the voltage selector switch as it's not needed around here and they were getting on my nerves when i tried to get the PCB out lol)
        • Scenic
          o.O
          • Sep 2007
          • 2642
          anyone....?
          • everell
            • Jan 2009
            • 1514
            I looked at your pictures - looks like a very "compact" PSU. From photos, I couldn't tell what chips were in it. Perhaps KA7500 and LM393? Take a close look and let us know what chips are on this board.
            Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
            • piernov
              NVidia bumpgate
              by piernov
              Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
              Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
              May complete this post at a later date with more details.
              Basically issue is a combination of thermal dissipation of the chip with hotspot,...
              03-27-2021, 10:34 AM
            • saimom
              Asus FX507ZC4 DANJLFMBAB0 REV B I need photos
              by saimom
              Hello everyone!
              Please help me determine which microcontroller was in this place.
              Logically, I guess that this is a ddr4 PWM memory controller and some kind of Richtek, but which one?
              Thise motherboard came after another service, where they say that water got on the controller and it burned down and they dismantled it.
              They did not take photos before the intervention
              The DANJLFMBAB0 REV B board, schematics, boards and photos of the motherboard were not found on the network, but I may have searched badly-((
              Maybe someone has a photo of this piece,...
              12-17-2024, 08:51 AM
            • Davi.p
              Reduce the size of photos please..
              by Davi.p
              Hi all, i'm asking all to reduce photos to a more comfortable resolution before post, the better like around 2000x2000, otherwise many PC / Tablets / phones refuses often to load them or has strong defection... today's digital cameras integrated in phones especially are a mockery because them saves photos at enormous resolutions with much less the real definition, so reducing them is only a good deal.. THANKS!!...
              05-16-2024, 12:53 AM
            • smurtz
              Cambridge Audio Stream Magic 6 - Power Supply
              by smurtz
              I have here a Cambbridge Audio Stream Magic 6 which does not power on.
              When opening the case the PSU appears to be faulty:
              IC1 (ICE3BR0665J), D2, the rectifier bridge, C15,C16 are dead and T2 is fried:
              I found the schematics of the PSU in the cambridge Audio CXN Service guide which uses the same:
              My problem is that I cannot find any info on T2 (SG01323) which seems to be a choke. Anyone knows how I can find a replacement & the value of that choke ?
              Thanks very much in advance...
              12-20-2024, 02:40 PM
              ASUS H81M-A DP M11AD DP_MB MicroATX Motherboard Boardview
              ASUS H81M-A DP M11AD DP_MB MicroATX Motherboard Boardview...
              10-27-2024, 01:42 AM
