thermaltake toughpower 850 dented cap
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    this is a new toughpower 850 for a new build.
    customer brought it in to do a preemptive recap if needed.
    all ncc kze so not needed.but on +5 stby look at the dent in this cap.
  • Oklahoma Wolf
    • Dec 2005
    • 353
    Re: thermaltake toughpower 850 dented cap
    Oops. I bet all the heatsink mounting screws under the PCB are loose, too. Common problem with these bigger CWT based units. I keep some red threadlocker on hand for all the CWT based review units I intend to sell afterwards
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      i will be checking that when i change that cap.
      at least it does not have all that tan glue dumped on everything.
      as for looose hardware they have to have some flaw to make it go bang!
      • rodd
        Thermaltake TR2 750W -fixed 5v stby now +5v reads low and no 12v
        by rodd
        Dear all,
        I am trying to repair the ATX power supply.
        First I fixed the +5V stby, which was zero due to a shorted TNY279 and an open 2R2 resistor.
        Just in case I replaced the PWM control IC (PS223) and the PFC control IC (CM6800).
        Now the supply turns on, the +3.3V is fine, but the +5V measures only 2.5V and there is no +12V.
        I have checked every diode I could find with a DMM (in circuit) and all the capacitors (in circuit) no shorts, low ESR.
        In despair I removed the low voltage diodes which were all mounted on the same heatsink...
        08-11-2023, 12:58 PM
      • AresROC
        Thermaltake TR2 Bronze 600w low 12v voltage
        by AresROC
        https://www.amazon.com/gp/product/B00NW6W2C8
        I have a Thermaltake TR2 80+ Bronze that's been doing strange things. It would cause the computer to shot down randomly, and measures low voltage on the 12 volt rail. From 11.5 to 11volt.
        I put it on the bench with a harddrive as load, and it outputs fine with low load:
        5v - 5.17v
        12v - 12.17v
        It has all Japanese caps, but only 1 large cap for the Input supply. No obvious signs of overheating burns or bulge. Anyone know where I should start to troubleshoot? I guess I don't want to just start by replacing...
        12-02-2021, 02:07 PM
      • keldeo
        Ultra low ESR. Much confusion!
        by keldeo
        Hi badcaps! So recently, me being a butterfingers, resulted in me dropping a graphics card and having the corner land directly onto a capacitor directly above the pcie slot on my Asus p5gc 775 board. Now this caused a pretty decent dent in the top of the can, so I've decided it'd ve best to replace it. However, I've ran into an issue. The current caps are Panasonic FJS, 820μf 6.3v. These are apparently "ultra low ESR" and these aren't manufactured anymore. So it seems I'm left with a few options. Put the dented cap back in, apparently it's ESR is 0.24 ohms, but the capacitance is...
        09-03-2022, 12:56 AM
      • delturcious
        Thermaltake ATX TR2-430 Turns on by itself, squeals, & has 0.9V on +5VSB
        by delturcious
        I have an older Thermaltake PSU that has a squealing noise whenever it's plugged in, even when totally disconnected from everything else. It automatically powers on the 5V and 12V rails with full voltage, but the +5VSB circuit only has 0.9V on it. I would assume this is my first place to start troubleshooting?
        There is nothing obviously burnt/leaking that I can identify.
        I've tried to take some decent photos of the 5VSB area. Components of notes:
        • U8 at the back is marked AZ431
        • C38 is 102
        • C47 is 104
        • C34 is a Teapo 330uF 16V (I think all the cylindrical caps are
        02-11-2021, 11:26 AM
      • z32KRAzY
        Alienware 15 R3 Motherboard Issues Help Plz!
        by z32KRAzY
        Hi, I have an Alienware 15 R3 that I just bought a new motherboard for from ebay.. I have been trying to figure out this issue for 2 weeks already and I've decided I need help from the pros.
        Laptop specifics:
        Model : Alienware 15 R3
        CPU : i7 6820HK
        GPU : Nvidia GTX 1080 Max Q
        RAM : 16GB PC4-19200 (8GB x 2)
        STOR : 256GB M.2 SSD + 1TB HDD
        Motherboard : Compal LA-D753P Rev 1.0
        Problem : The laptop runs fine with most things, even GPU/CPU stress tests seem to run without problems for extended periods of time. BUT...
        08-07-2022, 06:08 AM
