A-power
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    A-power
    has anyone had "pregnant" caps in an A-power Power supply?
    I just had an antec kill am sweet AMD Athlon xp thorton when I decided to chek my other computers, and found a bloated dude on an A-Power 500 watt
    i am saddened by this loss- ionly paid 5 bucks for it a few years back (if u are from the US, u'd love Gooodwill stores because of this) and I didnt know about bad caps then, but i sure it was fine then, and dead now
    Also, what brands of power supply are good? I want to get a good one this time.
    sigpic
    (Insert witty quote here)
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: A-power
    a power are junk.
    sledgehammer it and toss.
    recap the antec.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Re: A-power
      Vote 2 for the sledge.
      Mann-Made Global Warming.
      - Dr Seuss
        master hoarder
        • May 2008
        • 12168
        • Bulgaria
        Re: A-power
        It's tempting to sledgehammer and throw away those piece of crap PSUs. I have to say, though, the PSU will only do more damage that way - especially if you toss it in the trash where the PSU will release who knows how many bad chemicals in the groundwater (you never know what a cheap chinese factory uses to make those things).
        Get yourself a nice power supply and be done with the problem. 250-300w Sparkle is perfect for older 5v based systems. FSP, Delta, and Corsair are also some excelent choices for newer systems.
        As for the old PSU - cut the wires from the plug to the PCB and give it to someone who can use it (or you keep it) for parts - not that there are many, but still. My favorite stuff are the screws and the fans (which can be used as a load for PSU testing, or as case fans, provided that you put oil in them before using).
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Re: A-power
          The only problem with that plan is that aluminum electrolytic caps are not currently recycled as far as I know.
          - Dr Seuss
            master hoarder
            • May 2008
            • 12168
            • Bulgaria
            Re: A-power
            That ^ and they stink when they've vented .
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Re: A-power
              i also just discovered another antec 300 with 3 bad ones
              i hate theese things
              I also discovered a lot of my stuff has bad caps but i am only 16- i can't afford recap all of them - most of them still work fine no prob
              about the one psu- the fans were also dying o its only good for wres and laughs
              sigpic
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                Re: A-power
                oh also, do i need to somehow discharge the ps before opening
                sigpic
                  master hoarder
                  • May 2008
                  • 12168
                  • Bulgaria
                  Re: A-power
                  If the PSU has been plugged in to a motherboard and then turned off, it's very likely that you won't need to discharge anything. Most PSUs also discharge automatically. Nonetheless, advise some caution when opening the PSU and avoid touching the primary heatsink. If you have a DMM, set it on DC and measure the voltage on the primary capacitors by attaching one probe to the negative lead and one probe on the positive lead on the output side of the bridge rectifier. If you get 0 VDC, it should be safe.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Re: A-power
                    Yes.
                    -Should- discharge by itself...
                    Something would have to be broken for it not to.
                    The two big caps on AC side should discharge through the rectifier diodes or the resistors on the other side of them. Only way they won't is if both resistors and diodes are open, which is possible but isn't too likely.
                    If you wanna cover your butt for 'in case' discharge the caps with a shorting bar.
                    - aka: a big-ass screw driver.
                    - Dr Seuss
                    • Wizard
                      • Mar 2008
                      • 2296
                      Re: A-power
                      PCBONEZ, that's dangerous assumpation that mains cap discharges through the rectifier diodes. I had many units hold charge for DAYS till one go POW when I accidently let desoldering wick fall across that. Ugggh!
                      Now I routinely make sure that *da-n* cap is *discharged*! Some are nice to have high resistance resistor across that cap to discharge themselves but this can fail.
                      Do not ever discharge big capacitor with jumper or tool across it. This high amp and that loud *snap!* is stressing the cap and can blow holes in the capacitor foil and blowing out nicks off tools, no thanks. Use 100K ohm resistor and jumper clip wire, just one hand. This will discharge within few seconds and not so drastic. To be safe after discharging, put jumper wire across that to keep it discharged. They "recharge" to few voltage after a time due to electrons mirgation.
                      Cheers, Wizard
                      Last edited by Wizard; 03-11-2009, 10:46 AM. Reason: added about manual discharging.
                      • Oklahoma Wolf
                        • Dec 2005
                        • 353
                        Re: A-power
                        Know what's fun? Discharging a flash capacitor in a digital camera with your thumb because you were in too much a hurry to do it properly.
                        Hey, why is the camera lying over by the wall now? I don't remember putting it there...
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Re: A-power
                          thanks
                          sigpic
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Re: A-power
                            Cheers, Wizard
                            Like I said:
                            -> Something would have to be broken for it not to.
                            If the PSU is working, but not good...
                            Then you know the rectifier diodes are working.
                            Using a shorting bar is the proper method.
                            They have a resistor built in.
                            Most techs are too cheap to actually buy a proper shorting bar and an insulated screwdriver works just fine for small caps.
                            You are right on big caps. - Should use a current limiting resistor.
                            Here's an easy way.
                            - Dr Seuss
                              master hoarder
                              • May 2008
                              • 12168
                              • Bulgaria
                              Re: A-power
                              If you use a DMM to measure the voltage on the cap[s], they should discharge this way as well.
                              When I was in 8th grade, some kid had a disposable camera opened up. He said, "put your finger here". I knew he was getting at something stupid, just didn't know what exatly. Surprisingly, it didn't hurt that much. All I remeber was a stinging/numbing feeling on my thumb. Perhaps it was a weak camera. A PSU capacitor will pack much more ouchies.
                              I have a couple of 200v crap caps from a few PSUs. I'm thinking about building a coil gun. Would it ruin the caps if I just shorted them straight to the wires leading to the coil (not that the caps are anything special, but still)?
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                Re: A-power
                                the psu's were "fine"
                                i just happened to look through a vent and saw the porky cap
                                so i should be fine to open them up to see what's salvageable inside
                                btw is the a-power worth doing a full recap on?
                                sigpic
                                • i4004
                                  • Oct 2006
                                  • 2029
                                  Re: A-power
                                  + for the dmm usage(ie first check if that cap still has charge...if it doesn't then you're safe) but - on the expecting that dmm will discharge it, as voltage measuring typically bleeds very lil current.....
                                  have you read the 1st reply in this thread?
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    Re: A-power
                                    >> is the a-power worth doing a full recap on? <<
                                    It's worth it's value in screws, wire, and plugs.
                                    The rest should go in 'the bin'.
                                    - Dr Seuss
                                      master hoarder
                                      • May 2008
                                      • 12168
                                      • Bulgaria
                                      Re: A-power
                                      Most likely not.
                                      My criteria for deciding weather or not a PSU is worth a recap:
                                      -PSU has marking "35" on main traffo (most cheap PSUs have a "33" transformer, which is much smaller)
                                      -has decent (thick) heatsinks and decent components attached to the heatsinks - that means absolutely no 2-diode treatment allowed
                                      -18awg wire throughout output side (except floppy connectors, of course).
                                      -As for primary side, wires must be rated for 600v. 20awg is okay for older units powering a PII/P3 or AMD equivalent, but 18awg is much better.
                                      -has proper bridge rectifier, X/Y caps, and a choke coil or 2 (MOVs are also recommended)
                                      Post a few pics of your PSU and we will tell you. If it's not worth the recap, it sure will be worth the laughs .
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        Re: A-power
                                        good call
                                        i opened it up
                                        found 5 severely vented caps
                                        at least 1 of the 2 fans was still good
                                        sigpic
                                        • sirpsychol
                                          Antec Earthwatts EA-380 smd element type/value
                                          by sirpsychol
                                          While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
                                          09-03-2023, 07:58 PM
                                        • ajdrenter
                                          Picking caps for Antec SU-380
                                          by ajdrenter
                                          In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                                          https://www.badcaps.net/forum/showthread.php?t=14159
                                          It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                                          05-13-2023, 10:40 AM
                                        • CWEastwood
                                          Antec Smart Power SL300S capacitor replacement.
                                          by CWEastwood
                                          I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                                          The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                                          I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                                          Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                                          03-25-2023, 12:18 PM
                                        • s_henya
                                          Antec VP-600P and NE550M dead
                                          by s_henya
                                          Got in these 2 nice PSUs, both died after power surge.
                                          Both seems to be suffering from the same fault.
                                          Blown main fuse
                                          Shorted N mosfet 550v
                                          VP-600P: 5R280CE short between GDS
                                          NE550M: MDF18N50 short between GDS
                                          In terns of board layout these seems pretty identical.
                                          From past knowledge, once gate get shorted, most likely the for the driver to go bad as well.
                                          I never tried to salvage blown fuse PSU with shorted Mosfet due to that.
                                          Is it worth to try and replace the mosfets? is there a chance that the...
                                          12-03-2024, 10:00 PM
                                        • GnatGoSplat
                                          Antec BP500U APFC Coil
                                          by GnatGoSplat
                                          Antec BP500U PSU fried in my wife's gaming PC. I smelled something unpleasant last night, so I had a hunch something might be amiss. Woke up this morning to a popped breaker and immediately assumed the APFC cap must have blown. I last fixed it sometime in 2011, there's a thread about it here someplace. APFC and secondary caps that time. Replaced them with Panasonic caps. 10+yrs is probably a good run. It's been running 24/7 the last 3yrs, eth mining with a 1070ti and AFK fishing in Black Desert Online, lol.
                                          Anyway, cracked it open this morning, expecting it to just be the APFC cap...
                                          11-02-2021, 09:22 AM
