Corsair 400W PSU w/one bad cap
  • Mac29
    • Apr 2014
    • 11
    I've got a 400W Corsair that works fine. But upon blowing out bunnies I see one bad cap, bulged a bit, and I was thinking if I replace it I may save other caps and the unit itself.
    It's had a lot of use, maybe 6 years and been 'on the shelf' for 1.5 years now. All measurements are w/in spec.
    Think it's worth replacing the one cap or just use it again until it fails? As I understand it modern mobos have built in protection from bad PSU's.
    Read thru a third of 500 hits on a search and nothing quite like my situation so far. What do you think?
    Thanks,
    Mac
    • 31050
    Re: Corsair 400W PSU w/one bad cap
    replace any bulged caps asap.
    i'v never seen a motherboard that cant be slowly cooked or simply blown to shit by a bad voltage from the psu.
    specially as chances are the bad cap is for the 5v standby line that runs 24/7
    upload some photo's
    • Mac29
      • Apr 2014
      • 11
      Here's what that one cap looks like, as well as the unit.
      Thanks,
      Mac
      • CapLeaker
        Leaking Member
        • 8182
        yep, she's pregnant all right.
        • dmill89
          • Dec 2011
          • 2534
          Yep, looks like the caps (at least what can be seen in the pics.) are OSTs (mediocre brand at best) as well, if you don't replace them all now chances are they will fail in the near future (since all the caps are the same age and brand if one failed the others are likely to as well).
          • ant3202
            • Jun 2006
            • 275
            • Singapore
            Thanks,
            Mac
            awww those OST stuffs.....
            had some boards also..... left for some time... those ost caps also bloat....
            • Stefan Payne
              • 1267
              Why was the first thought I had the Original CX400??
              Well, maybe because its around 10 Years Old.
              Anyway, that's an RLX one, right?
              Ultra Low ESR one??
              • h0m3w0rk
                Random Shutdowns/Startup Failure with Corsair SFX 450
                by h0m3w0rk
                I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
                For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
                02-09-2025, 03:19 AM
              • triplefour
                JVC LT-55UE76 has bulged cap on power supply, spilled electrolyte.
                by triplefour
                got this tv from a friend who got a new one and didnt want to bother repairing this one.
                he said it sometimes would just flash color patterns.
                and sometimes it would just work
                i figured it had some intermittent mainboard issue.
                i stored it at home for a while before looking at it
                when i plugged it in for the first time, i heard some popping noises
                and then a big cloud of white smoke came out of the back of the tv!
                i noticed the smoke didnt actually smell like anything. not like when an IC blows.
                i unplugged it and took the back off and discovered...
                12-18-2022, 12:38 AM
              • hobostove
                Corsair RM1000e - Help identify 5VSB Zener diode
                by hobostove
                Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                There's a 22ohm resistor that's melted and open, but it still has the bands.
                The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                It looks like the diode connects the source and drain of a TNY284...
                03-27-2025, 02:25 PM
              • W1ngl3t
                Corsair RM850x (synchronous ATX) need help troubleshooting
                by W1ngl3t
                I have a Corsair RM850x that refuses to turn on. I have 5v stby but as soon as I try to power it up it goes 'click' and does not deliver any voltages.
                I have not been able to find any blown or shorted components and there are no bulging capacitors. I have replaced the APFC controller and for a brief period (2 or 3 on/off cycles) the PSU worked but then the fault returned. Perhaps heating the PFC area is what resulted in the temporary fix?
                The only option I see now is to start pulling components one by one, but before I proceed, perhaps someone more knowledgeable...
                03-15-2025, 04:43 PM
              • bimole
                Weird behavior on 3.3V rail of a CORSAIR CX600
                by bimole
                A colleague gave me an apparently ill CORSAIR CX600.
                He told me that he heard a banging noise, and smelt the magic smoke.
                After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                It's another story on the 3.3V rail...
                I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                02-13-2025, 04:49 AM
