finally ordered a new PSU
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Well, my old Fortron 350w couldn't hold up the Prescott, 8600gt, 3gb ddr2, and 3 hard drives, so I picked up one of these from newegg-
    http://www.newegg.com/Product/Produc...82E16817703017
    Total price with a discount code was $41.99.
    I like single 12v rail PSUs, and 80 plus certified is just a bonus.
    Ludicrous gibs!
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: finally ordered a new PSU
    A fortron 350W couldn't hold up that rig?
    My crappy rosewill 350W that came free with a $25 case held up a 3200+, 8600GT, 3 hard drives and 2 dvd drives. Still running the same rig minus 2 hard drives and down to a cd-rw drive.
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      Well, I shouldn't say that it couldn't do it... It ran fine, but when the system was under heavy load, the PSU would heat up enough to kick the fan into high. Also, after some time at load, the +12v would dip slightly.
      The final straw was that the fan started groaning.
      Ludicrous gibs!
      • linuxguru
        • Apr 2005
        • 1564
        Fortron is one of the better PSU brands out there - replacement NMB or similar ball-bearing fans should last the rest of the lifetime of the system.
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          I'm surely not trashing the old one... it just wasn't adequate for my "current" (haha! get it?) needs. The new PCP&C supply fits the bill nicely, without killing my bank account...
          Ludicrous gibs!
          • ChaosLegionnaire
            I finally got one too! a new monitor! and my first ips panel to boot!
            by ChaosLegionnaire
            after bigtroll managing to score a new video card in this thread, i thought i'd get a new monitor too, since my current one has a bubbly and blurry screen that i posted in this thread.
            i tried numerous local websites to get one but many required a mobile number to sign up which i dont own. i also had issues finding the right monitor that met my requirements. it was a nightmare finding one, spending weeks looking through g00gle.
            finally, i decided to try lazada, the singapore version of jack's aliexpress. it only required an email address for signup, but whenever i...
            10-12-2021, 02:07 AM
          • bulkchart32
            i think i accidently ordered non-polarized 10uf caps for my original xbox. will this cause a problem?
            by bulkchart32
            i ordered a lot of caps from digikey to repair my xboxs. one thing i ordered was 50NXA10MEFC5X11-ND caps and i think they are not polarized. will this cause any kind of a problem? i really don't want to order new caps just because of this.
            06-16-2025, 03:09 AM
          • FeerBaron
            Got in way over my head with Supermicro server board and upgrade.
            by FeerBaron
            Last year I bought a server. It's worked fairly well but had some issues. Some pcie slots didn't work and Xeon v4 is a bit slow and missing AVX 512. Came to realize that the next version up, with skylake uses mostly the same chassis.
            A board popped up on ebay one day being sold for parts. A working board like this is over a grand at best. This particular one was about $125 and I decided to gamble.
            At first it seemed simple enough. According to the description it looked like some mechanical damage.
            Found the missing 560uf cap and thought I was...
            Starts
            01-26-2024
            Ends
            01-26-2024
            01-26-2024, 06:36 AM
          • aa10aa10
            Panasonic Toughbook CF-33 mk1 BIOS repair
            by aa10aa10
            Good day,
            I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
            I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
            01-21-2025, 06:13 AM
          • mikey5791
            by mikey5791
            Hi to all forum members,
            12-26-2024, 04:55 AM
