Modifying LG Power Supply to prevent overdriving LEDs?
  • curt2199
    • Oct 2013
    • 54
    I just fixed another LG 47” by swapping bad diodes for good ones. I noticed a repair service when googling that claims to modify your LG power supply to stop it from overdriving the LEDs and burning them out. Does anyone happen to know the gist of what they're doing as I'd like to do the same. I don't like repairing and reselling these TVs knowing the same problem will most likely pop up again.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Modifying LG Power Supply to prevent overdriving LEDs?
    im not sure on lgs this thread is regarding a vizio but may give you a idea on the mod
    https://www.badcaps.net/forum/showth...ed+current+mod
      • 31028
      maybe a starting point would be the cooling,
      i'v not seen a teardown yet that shows the led strips thermally coupled to the metalwork properly.
      • vinceroger69
        • Mar 2012
        • 6714
        i wonder if when we replace/repair led strips does it matter what type of double sided tape we use as this could effect the cooling too i guess?
        • curt2199
          • Oct 2013
          • 54
          I have been pressing the strips back down and hot gluing the edges to keep them in place as well as creating some glue straps across the raised “pegs” that are used to keep the strips in the right place. As far as I can tell the cooling effectiveness should be factory. If the driver is driving them at a higher current than they’re rated for then the cooling won’t matter in the long run because they’ll still burn out. I noticed several diodes that were much dimmers than others when testing them with my multimeter so I can only assume they are next to fail as their resistance is increasing.
            • 31028
            that's not saying much these days!
              The LED PCB strip has no thermal VIA's to conduct the heat from the top layer to the bottom layer so the way it is right now the heat transfer from the top layer to the bottom layer is joke, and if they do add the VIA's then then will have to add electrical insulation between the strip and the metal chassis.
                • 31028
                i thought all the tv strips used aluminium pcb's??
                  It would have been nice but that costs more than just simple double sided copper clad board, they have to cut cost and make sure they go bad after the warranty runs out.
                  • curt2199
                    • Oct 2013
                    • 54
                    Picked up another 47 and 55 tonight. Lot of these LGs with dead leds.
                      You may find them with badly burn out LED's:
                      https://www.badcaps.net/forum/showth...hlight=latw%2A
                      https://www.badcaps.net/forum/showth...ht=LG+47LN5790
                      • curt2199
                        • Oct 2013
                        • 54
                        Just replaced one bad diode on the 55”. Time to put it back together. Gave the guy $40 for the TV last night. Alsways nice when a plan comes together. Lol. Now to do the same to the 47” to upgrade my bedroom tv.
                          Just make sure to turn down the backlights level to as low as possible on ALL input settings.
                            by sam_sam_sam
                            03-31-2024, 02:12 PM
                            by sam_sam_sam
                            07-01-2024, 06:34 AM
                          • shamsudeen
                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                            by shamsudeen
                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                            07-19-2025, 07:14 AM
                          • CMCM
                            Russound CA4 Power Supply Repair
                            by CMCM
                            Hello Everybody,
                            Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                            Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                            The outputs marked 12v and 20v are all measuring only 1v.
                            The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                            The capacitors physically look clean (no bludgesor leaks) and...
                            07-03-2025, 01:12 PM
