Have inherited old Dell psu. Somewhat strange in that wires to 20 pin mobo connector don't match the usual plan. PWM is UC3845 and protection chip is TSM110 - could not find data sheet for this one. 5VSB works but +5/+12/+3.3 are all dead. Date of mfg stamped on case is 12-07-00. The Dell it came out of is either unique or antique. Anyone know anything about it?
Old Dell PS 5201-7D 200 watt psu
Re: Old Dell PS 5201-7D 200 watt psu
Dell departed from the standard PSU pinout in late 1998 they are proprietary supplies. They have since returned to the standard ATX layout.
I have seen special conversion harnesses allowing you to use standard ATX supplies on these boards.Last edited by Krankshaft; 02-10-2009, 08:02 PM.Elements of the past and the future combining to make something not quite as good as either. -
Google: dell power supply adapter OR dell motherboard power supply adapter
Dell Adapter
or (cheaper)
DELL MOTHERBOARD POWER ADAPTER
Toastveritas odium paritComment
Those adapters are to use standard PSU with Mobo that everell's PSU is supposed to go to.
They don't convert his/her PSU to standard.
Dell used those on late generation P3's.
Not sure if some or all.Mann-Made Global Warming.
- Dr Seuss
Ah-ha! Gotcha.
So, if you want to go FROM Dell PSU TO ATX mobo, then it looks like it's a homebrew project.
Try here, bottom of the article:
Dell Case Mods
As I recall you can get by with switching the wires around in the plastic connector.
You should look up the pin-outs and check wire colors first because I think some of the Dells used non-standard wire colors for the voltages.
Here is the odd-ball pin-out.
http://pinouts.ru/Power/dell_atxpower_pinout.shtmlMann-Made Global Warming.
- Dr Seuss
Oops.
Either that drawing is wrong or my memory is.
There is no +3.3v shown.Mann-Made Global Warming.
- Dr Seuss
Nope, looks like that PSU has no 3.3v rail.Mann-Made Global Warming.
- Dr Seuss
The 3.3v is there, but not in the 20 pin.
3.3v is in the 6 pin mobo connector.Mann-Made Global Warming.
- Dr Seuss
Gotta love Dell just replaced 2 toasted HL Data Storage drives on 2 different Dimensions one was an 04 model and the other an 05 model. The drives weren't even heavily used.
One would read CDs but not burn CD-Rs the other wouldn't read Data CDs but would read music CDs and not would burn CD-Rs with a bit of a racket.
Dell always seems to cheap out on parts and I'm sure these proprietary supplies were no different.Last edited by Krankshaft; 02-11-2009, 09:18 AM.Elements of the past and the future combining to make something not quite as good as either.Comment
Thank you Mr. PCBonez - I checked out the website with the pinout information. The 5VSB came up just fine, and when I grounded the proper color coded wire (PS on), the other voltages came on just fine. Guess someone dumped this PS because it didn't have a standard pinout. I don't have any use for it now either, but it was great to learn that you should never plug in a power supply and turn it on without making sure it has a standard pinout!
TomOld proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)Comment
Older HL drives are pretty decent Krankshaft. Bet you didn't even try cleaning the lasers first.Comment
I had that same problem with our dell. We bought a lightscribe dvd-ram drive for it because the cd-rw it came with was acting up. I didn't know this at the time, and i swapped it out with my computer's (at that time, it was a 667mhz p3, about 3 years ago.) white compaq (lite-on) 40x cd-rom. For some reason, that dell's cd-rw would write cd's just fine, but when you tried to read, it would be very slow. I played red alert 2 just fine with the compaq 40x, but with that drive, it would read the cd so slowly the game ran really bad.Originally posted by KrankshaftGotta love Dell just replaced 2 toasted HL Data Storage drives on 2 different Dimensions one was an 04 model and the other an 05 model. The drives weren't even heavily used.
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by vieuxchoubDear friends from Badcaps
I have been searching for a long time to repair sucessfully a battery charger taking in 230V AC and outputting normally 14V DC. Its power mosfet has been shorted ( Infineon 06N80C3), probably because the bulk storage rectifier capacitor had swollen and had no capacitance anymore and a very high resistance.. The mosfet short has naturaly blown its 0.15 ohms resistor then its driver, the UC3845 IC which was shorted between pins 5 (ground) and 7 (vcc) plus 8 (Vref). Another small resistor surrounding was also dead. So, I have replaced the bulk storage capacitor, the...3 Photos -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
Channel: BIOS Requests ONLY!
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
by SMDFleaDell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
Some models have a choice of 2 different firmwares, it depends on the dell SKU.
The SKU is in brackets (****)
EDIT: NVM65...-
- Loading...
